Blackview ROCK 2 Pro 6.67-inch 120Hz Display 8+256GB 400LM Camping Light 15000mAh 5G Rugged Phone
Sale price £210.00 Regular price £262.00
ROCK 2 Pro
Faster 5G, Brighter Light, Unstoppable Power
Go Beyond Limits, Conquer Every Challenge
ROCK 2 Pro
ROCK 2 Pro
Why Choose Blackview ROCK 2 Pro?
ROCK 2 Pro
No.1
IP69K, IP68 & MIL-STD-810H Certified,
Built to Conquer Any Extreme.
ROCK 2 Pro
No.2
Blazing 5G with 6nm UNISOC T8100,
Experience Unmatched Speed
ROCK 2 Pro
No.3 6.67" 120Hz Smart Eye-Care Display,
Smooth and Stunning
ROCK 2 Pro
No.4 Massive 15,000mAh Battery, Up to 50
Days Standby.
ROCK 2 Pro
No.5 Capture Every Moment, Anytime,
Anywhere
ROCK 2 Pro
No.6 Exclusively Self-Developed Doke AI
2.0, Intelligence Beyond Limits
ROCK 2 Pro
No.7 Exclusive Self-Developed DokeOS 5.0
Based on Android 16
ROCK 2 Pro
No.1
ROCK 2 Pro
400lm Camping Light
Bright, adjustable, and reliable — designed to illuminate your camp and ensure safety in every outdoor adventure.
ROCK 2 Pro
Lighting ModeThree Brightness Levels:Low/Highlight/Extremely bright
Low for power-saving, High and Ultra-Bright for versatile outdoor lighting needs.
ROCK 2 Pro
Outdoor Camping
ROCK 2 Pro
Outdoor Repairs
ROCK 2 Pro
Night Hiking
ROCK 2 Pro
SOS Mode
Sends a clear, visible distress signal to ensure your safety in critical outdoor situations.
ROCK 2 Pro
Lost in the Wild
ROCK 2 Pro
Vehicle Breakdown
ROCK 2 Pro
Severe Weather Distress
ROCK 2 Pro
Quick Flashing Mode
Ideal for emergency warnings, deterring potential threats, or quickly attracting attention.
ROCK 2 Pro
Outdoor Defense
ROCK 2 Pro
Roadside Warning
ROCK 2 Pro
Emergency Evacuation
ROCK 2 Pro
Dive. Spray. Soak. It just works.
IP69K & IP68 Certified
ROCK 2 Pro is engineered for the toughest conditions, delivering unmatched protection against water, dust, and high-pressure jets.
ROCK 2 Pro
ROCK 2 Pro
ROCK 2 Pro
Seamless Screen Sealing: Flawless
waterproof performance.
ROCK 2 Pro
Corrosion-Resistant Aluminum Buttons:
Reinforced with premium silicone seals.
ROCK 2 Pro
TPU Sealed USB Port: Maximum dust
and water resistance.
ROCK 2 Pro
Underwater Camera: Capture unforgettable
moments below the surface.
ROCK 2 Pro
Speaker Cleaning: Auto-expels water and
debris for crystal-clear audio.
ROCK 2 Pro
Drop-Proof. Dust-Proof. Battle-Ready.
From -20°C Arctic sites to 60°C desert heat, from 1.2m concrete drops to sandstorms — ROCK 2 Pro survives where others fail.
ROCK 2 Pro
Proven through these extreme tests
ROCK 2 Pro
Rain
ROCK 2 Pro
Sand and Dust
ROCK 2 Pro
Vibration
ROCK 2 Pro
Shock
ROCK 2 Pro
Humidity
ROCK 2 Pro
Altitude
ROCK 2 Pro
Acceleration
ROCK 2 Pro
High Temperature
ROCK 2 Pro
Low Temperature
ROCK 2 Pro
Immersion
ROCK 2 Pro
Reinforced Rubber Corners:
Shock absorption at its best.
ROCK 2 Pro
Ultra-Durable Composite Back:
Built to endure.
ROCK 2 Pro
Aviation-Grade Aluminum Frame:
Strong, lightweight, and impact-resistant.
ROCK 2 Pro
Panda Glass Display: Scratch-resistant and
shatterproof for ultimate durability.
Glove Mode 2.0
Operate flawlessly —
even with thick gloves on.
ROCK 2 Pro
ROCK 2 Pro
Useful ToolBag
Compass, Torch, Magnifier, and more —
your all-in-one practical toolkit.
ROCK 2 Pro
No.2
5G 6nm UNISOC T8100
Speed You Need. Power You Trust.
Experience blazing-fast 5G with the 6nm UNISOC T8100 chipset, featuring a powerful 2.2GHz CPU for seamless multitasking and smooth performance in demanding apps!
ROCK 2 Pro
ROCK 2 Pro
4*A76@2.2GHz
+ 4*A55@2.0GHz
ROCK 2 Pro
Arm Mali G57
ROCK 2 Pro
748,099
AnTuTu Benchmark
Up to 32GB LPDDR4X RAM
Multitask Like It's Nothing.
Multitask effortlessly—launch apps instantly, switch seamlessly, and power through work and entertainment with unwavering speed.
Up to 32GB RAM=8GB RAM + 24GB Expansion
Atomized Memory 2.0
9% More RAM Available
ROCK 2 Pro
256GB UFS 3.1 Storage
Upgraded to UFS 3.1 for 2.4x faster speeds, lower power consumption, reduced latency, and accelerated write performance—store more, load faster, and work smarter.
ROCK 2 Pro
ROCK 2 Pro
UFS 3.1
ROCK 2 Pro
ROCK 2
UFS 2.2
2.4x Faster Data Transfer Speed ROCK 2 Pro
Efficient Heat Dissipation
Cool Under Pressure
With a 1700mm² cooling area, enjoy rapid heat dispersion for stable, smooth performance no matter how intense the task.
ROCK 2 Pro
ROCK 2 Pro
No.3
Smooth and Stunning
6.67" HD+ IPS Display
Broader View, Sharper Details
Equipped with a 6.67" HD+ IPS screen, ROCK 2 Pro delivers immersive visuals with 120Hz smart refresh and 650nits brightness — perfect for gaming, streaming, and everyday tasks.
ROCK 2 Pro
120Hz
AI Smart Refresh Rate
650nits
Brightness
85%
Screen-to-body Ratio
720*1604
Resolution
120Hz AI Smart Refresh Rate
Smoother, Faster, Smarter
Say goodbye to lag—smart refresh adapts to your needs, ensuring silky scrolling while optimizing battery life.
120Hz ROCK 2 Pro 60Hz
Twice the Refresh Rate,
Twice the Smoothness
ROCK 2 Pro
Eye-Care Modes
Comfort That Lasts All Day
Protect your eyes with four tailored modes designed for reading, working, and relaxing.
ROCK 2 Pro
ROCK 2 Pro
Reading Mode
Paper-like comfort for long hours of reading
ROCK 2 Pro
Night Light
Gentle lighting to reduce blue light strain
ROCK 2 Pro
Dark Mode
Perfect for low-light environments
ROCK 2 Pro
Light Mode
Bright and clear for daytime use
2W High-Power Box Speaker
Powerful Sound, Exceptional Clarity
ROCK 2 Pro delivers bold, crystal-clear audio with its 2W high-power speaker, cutting through noisy environments to ensure top-tier sound for both communication and entertainment.
ROCK 2 Pro
ROCK 2 Pro
No.4
Up to 50 Days Standby.
15,000mAh Massive Battery
Power That Keeps Up. With a gigantic 15,000mAh battery, ROCK 2 Pro effortlessly handles work trips, outdoor adventures, and daily use—no outlet hunting required.
Intelligent Charging
Protection
AI Power Saving
Algorithm
ROCK 2 Pro
ROCK 2 Pro
28hrs
Game
ROCK 2 Pro
43hrs
Call
ROCK 2 Pro
97hrs
Music
ROCK 2 Pro
34hrs
Web Browsing
ROCK 2 Pro
26hrs
Video Playback
ROCK 2 Pro
50 days
*Data is tested by Blackview Lab based on continuous use. The actual use may vary depending on real-world usage conditions.
ROCK 2 Pro
Class-Exclusive Intelligent Deep
Power-Saving Mode
ROCK 2 Pro intelligently adjusts power consumption with advanced optimization during idle periods — delivering longer battery life without sacrificing performance.
Longer Light-Use Time
Less Overnight Drain
5W OTG Reverse Charging
Share Power On the Go
ROCK 2 Pro doubles as a portable power bank, letting you charge earbuds, smartwatches, or even your friend's phone on the go.
ROCK 2 Pro
ROCK 2 Pro
No.5
Anytime, Anywhere
ROCK 2 Pro
16MP AI Main Camera
Capture Perfectly. Share Instantly.
The 16MP AI main camera of ROCK 2 Pro delivers crystal-clear, vibrant images—whether you’re capturing professional shots or chasing the perfect sunset.
16MP
13MP AI Front Camera
Be You—Just Brighter.
ROCK 2 Pro's 13MP AI front camera adjusts to any lighting condition, ensuring your selfies remain sharp, natural, and effortlessly stunning.
ROCK 2 Pro
Beauty Mode
Glow Effortlessly, Naturally.
AI beauty mode enhances your skin and tone with subtle, natural adjustments—highlighting your best features with finesse.
ROCK 2 Pro
Portrait Mode
Focus on You, Blur the Rest.
AI depth sensing highlights your subject while creating a smooth, studio-quality bokeh effect—no extra equipment needed.
ROCK 2 Pro
Night Mode
Master the Night, Every Detail Counts.
AI night mode reveals hidden details in the dark—bright skies, sharp edges, and perfectly stable shots, no matter how dim the scene.
ROCK 2 Pro
ROCK 2 Pro
No.6
AI 2.0, Intelligence Beyond Limits
By integrating three cutting-edge AI models, Doke AI leverages cutting-edge technology to deeply understand user needs, delivering faster, smarter, and more tailored solutions.
ROCK 2 Pro
DeepSeek-R1
ROCK 2 Pro
ChatGPT-4o mini
ROCK 2 Pro
Gemini AI 2.0 Flash
Your Exclusive Smart Life Manager
ROCK 2 Pro
Voice Activation &
Voiceprint Recognition
Unlock effortlessly with your voice —
touch-free and highly secure!
ROCK 2 Pro
AI Global Smart Control
Manage apps and settings with ease using simple voice commands, streamlining your daily tasks.
ROCK 2 Pro Compatible Apps:
AI Full-Screen Assistance
Instantly provide answers and insights related
to your current screen content.
ROCK 2 Pro
ROCK 2 Pro
AI Real-Time Interaction
Enjoy seamless, real-time communication,
enhancing productivity in every moment.
Four Innovative Doke AI Apps to
Elevate Your Experience
ROCK 2 Pro
AI Chat App
Your Always-Available AI Chat Companion From task planning to creative brainstorming, AI Chat is your trusted intelligent assistant, always ready to help.
ROCK 2 Pro
ROCK 2 Pro
Next-Gen
DeepSeek-R1
ROCK 2 Pro
AI Online Search
ROCK 2 Pro
Document Parsing
ROCK 2 Pro
Tutoring Assistant
ROCK 2 Pro
Chat with AI
ROCK 2 Pro
AI Photos App
Your Portable AI Photo Editing Tool With 18 advanced AI features, AI Photos transforms ordinary photos into stunning visual creations, ready to impress and share.
ROCK 2 Pro
AI Remove Objects
ROCK 2 Pro
AI OutPainting
ROCK 2 Pro
ROCK 2 Pro
AI Blur Photo
AI Replace Background
ROCK 2 Pro
AI Animate
ROCK 2 Pro
ROCK 2 Pro
AI Video App
Your AI Video Creation Tool
Transform text, images, and everyday moments into cinematic videos effortlessly — no expertise required!
ROCK 2 Pro
ROCK 2 Pro
AI Music App
Your AI Music Creation
Platform
No instruments or studio needed—AI Music empowers you to create unique music effortlessly, tailored to every occasion.
ROCK 2 Pro
ROCK 2 Pro
No.7
Latest DokeOS 5.0 Based on Android 16
From DokeOS 4.2 to 5.0, we've rebuilt the experience: faster, cleaner, smarter, and deeply personal. This isn't just an update—it's a leap forward in how you interact with your ROCK 2.
Do What Matters. Without the Noise.
ROCK 2 Pro
Side Key Function
One Press. Instant Access.
Quickly activate flashlight, SOS, underwater camera, PTT, or your favorite app. Always ready, no waiting.
ROCK 2 Pro
Start Soundrecording
ROCK 2 Pro
Open flashlight
ROCK 2 Pro
Screenshots
ROCK 2 Pro
Open Underwater Camera
ROCK 2 Pro
Open PTT
ROCK 2 Pro
Open SOS
ROCK 2 Pro
Quad-Core Navigation
Global Precision. Always On Track.
Powered by GPS, Beidou, Galileo, and Glonass for accurate positioning — anywhere, anytime.
Beyond the Purchase, We’ve Got You Covered.
ROCK 2 Pro
Android Version Update
ROCK 2 Pro
Hotline Assistance
ROCK 2 Pro
24/7 Online Service
ROCK 2 Pro
Trusted Offline Repair Center
Blackview ROCK 1 Specifications
Model ROCK 2 Pro
Color Black/Yellow
Dimension 187.6 * 85.8 * 26mm
Weight 558g
OS DokeOS 5.0 Based on Android 16
Display 6.67-inch HD+ IPS, 720 * 1604 Resolution
120Hz Smart Refresh Rate, 85% Screen-to-body Ratio
CPU Octa-core 5G 6nm UNISOC T8100
RAM & ROM 8GB RAM + 256GB ROM, LPDDR4X + UFS3.1
TF Expansion Up to 512GB Expandable Storage
Battery 15000mAh; 33W Fast Charging
Front Camera 13MP
Rear Camera 16MP
Speaker 2W Box Speaker
Navigation GPS+GLONASS+Galileo+Beidou
Card Slot Two; 2SIM/1SIM +1*TF Card
NFC Support
Wi-Fi & Bluetooth (IEEE802.11a/b/g/n/ac) (2.4GHz/5GHz) ; BT 5.0
3G Band: WCDMA: B1/B2/B5/B8
4G Band: TDD:B38/B40/B41
FDD:B1/B2/B3/B4/B5/B7/B8/B12/B17
B19/B20/B26/28A/28B/B66
5G Band: N1/2/3/5/7/8/20/26
28/38/40/41/66/77/78
