Blackview Active 12 Pro 5G Rugged Tablet with Built-in Projector (12+256GB/16GB+1TB) 11-inch FHD+ Display MediaTek Dimensity 7300 108MP Camera & Built-in Camping Light
Available in stock (16)
✔5G Octa-core MediaTek Dimensity 7300 4nm Up to 2.5GHz
✔Built-in 200LM 1080P 120″ Autofocus Projector & 400LM Camping Light
✔30000mAh Big Battery w/ 120w Fast Charge
✔108MP Samsung HM6 AI Main Camera
✔Adjustable Aluminum Alloy Bracket
✔UL94 HB Flame-Retardant Certificated
The Blackview Active 12 Pro is a rugged 5G tablet built for field work, presentations, outdoor entertainment, and emergency power. Its 11-inch 90Hz FHD+ display, Dimensity 7300 processor, 30,000mAh battery, and 120W fast charging give it strong endurance and performance for demanding users. The built-in 1080P autofocus projector supports up to 120 inches, while dual 400LM camping lights add night utility. With a 108MP rear camera, 50MP front camera, WiFi 6E, NFC, GPS, and a reinforced rugged design, it is a mobile workstation for serious use.
| Design | |
| Product | Active 12 Pro |
| OS | DokeOS_P 4.2 Based on Android 15 |
| Color | Black |
| Weight | 1522g |
| Dimensions | 267.7*179*28.3mm |
| Screen | |
| IC | ICNL9951R |
| Panel Type | IPS |
| Display Resolution | FHD+ |
| Screen Size | 11 inch |
| Screen Resolution | 1920x1200 16:10 |
| PPI | 207 |
| Refresh frequency | 90HZ |
| Screen to Body Ratio (%) | 83% |
| Glass | CORNING® GORILLA® GLASS 5 |
| Connectivity | |
| 2G | GSM: B2/B3/B5/B8 |
| 3G | B1/B2/B4/B5/B6/B8/B19, CDMA:BC0/BC1/BC10 |
| 4G | FDD:B1/B2/B3/B4/B5/B7/B8/B12/B13/B17/B18/B19/B20/B25/B26/B28A/B28B/B30/B66 TDD:B34/B38/B39/B40/B41 |
| WIFI | IEEE802.11 a/b/g/n/ac/ax(WiFi6E) |
| Bluetooth | V5.4 |
| Hardware | |
| CPU | MediaTek Dimensity 7300(MT6878) |
| CPU Clock | 4*A78@2.5GHz; 4*A55@2.0 GHz |
| GPU | Arm Mali-G615 GPU |
| RAM | 12GB/16GB |
| RAM Type | LPDDR5 |
| ROM | 256GB/1TB |
| ROM Type | UFS3.1 |
| TF Card Slot | Support |
| Max TF Card Capacity | Up to 2TB |
| USB | TYPE-C |
| Speaker | Dual-BOX Speakers |
| Camera | |
| Front Camera | 50MP |
| Front Camera Aperture | F2.25 |
| Rear Camera | 108MP |
| Rear Camera Sensor | Samsung® ISOCELL HM6 |
| Rear Camera Aperture | F1.9 |
| Rear Flash | Yes |
| Power | |
| Battery Capacity | 30000mAh |
| Max Charging Current | 20V/6A, 120W Fast Charging |
| Additional Tool | |
| Projector | Up to 120'' 1080P 200LM Autofocus Projector, Built-in Distance Sensor (Recommended throw distance: within 2 meters) |
| Camping Lights | Dual 400 lumen (LM) LED, Multiple Modes: Illumination/ SOS/ Strobe |
| Multi-media | |
| Video | mp4\3Gp\3gpp\avi\x-flv... |
| Audio | ogg\aac\imy\amr\x-flac\mp3.... |
| Image | jpeg\png\gif\bmp |
| Features | |
| Navigation | GPS+GLONASS+Galileo+Beidou(L1+L5) |
| Motor | YES |
| Sensors | G-sensor/Light/Ditance-sensor |
| Gyroscope | YES |
| Magnetic | YES |
| Air pressure sensor | NO |
| Hall | NO |
| Compass | YES |
| Fingerprint | YES |
| RGB | NO |
| NFC | YES |
| Hotkont | NO |
| Coulomb Counter | YES |
| Wireless Charging | NO |
| Sim-Card Type | Dual nano, 2*SIM or 1*SIM + 1*TF Card |
| FM | YES |
| OTG | YES |
| Accessories | |
| User Manual | x1 |
| Aluminum Alloy Bracket | x1 |
| Stylus Pen | x1 |
| OTG cable | x1 |
| USB Cable | x1 |
Does the Blackview Active 12 Pro Rugged Tablet Have a Built-In Projector?
How Large Can the Blackview Active 12 Pro Projector Display?
How Bright Is the Blackview Active 12 Pro Projector?
Does the Blackview Active 12 Pro Projector Support Autofocus and Keystone Correction?
How Long Can the Blackview Active 12 Pro Run the Projector?
Can the Blackview Active 12 Pro Be Used for Outdoor Movie Nights?
Can the Blackview Active 12 Pro Be Used for Worksite Presentations?
Does the Blackview Active 12 Pro Have a Built-In Camping Light?
How Long Can the Blackview Active 12 Pro Camping Light Stay On?
What Can the 180° Stand on the Blackview Active 12 Pro Be Used For?
Can the Blackview Active 12 Pro Be Used as a Portable Workstation?
Does the Blackview Active 12 Pro Support PC Mode and Multi-Window Use?
How Long Does the Blackview Active 12 Pro 30,000mAh Battery Last?
Can the Blackview Active 12 Pro Be Used for Fieldwork and Construction?
What Can the Blackview Active 12 Pro Be Used For Outdoors?
Who Is the Blackview Active 12 Pro Rugged Tablet Best For?
