Available in stock (17)
✔Two-Way GEO Satellite Voice/Text/Location Messaging Communication with Skylo
✔Built-in 467 Lumen Dual Camping Light
✔6.73" 120Hz 3.2K LTPO AMOLED Display
✔MediaTek Dimensity 8300 4nm 5G Octa-core & WiFi 6E
✔20000mAh Battery w/ 120W Fast Charging
✔50MP Main+20MP Night Vision Camera
✔IP68 &IP69K & MIL-STD-810H Certified
✔Physical SIM & eSIM Support
The Blackview XPLORE 2 Satellite is built for people who go beyond regular signal coverage. With two-way GEO satellite voice, text, and location messaging, it helps you stay connected during remote travel, field work, outdoor adventures, and emergencies. Its massive 20,000mAh battery, 120W fast charging, and built-in 467-lumen camping light make it ready for long days and dark nights. Add a 6.73-inch 120Hz 3.2K AMOLED display, Dimensity 8300 5G performance, 20MP night vision, and IP68/IP69K durability, and it becomes a true off-grid rugged flagship.
| Design | |
| Product | Blackview XPLORE 2 Satellite |
| OS | DokeOS 4.2 Based on Android 15 |
| Color | Black |
| Weight | 675g |
| Dimensions | 186*87.8*29mm |
| Screen | |
| Main Display | |
| LCD panel | CSOT |
| IC | NT37801 |
| Panel Type | AMOLED |
| Display Resolution | FHD+ |
| Screen Size | 6.73 Inch |
| Screen Resolution | 1440*3200 20:9 |
| Screen to Body Ratio (%) | 85% |
| PPI/DPI | PPI: 521 |
| Refresh frequency | 120HZ |
| Glass | Corning® Gorilla® Glass 5 |
| Connectivity | |
| WIFI | WiFi 6E(IEEE802.11a/b/g/n/ac/ax-2020) |
| Bluetooth | V5.4 |
| 2G | B2/B3/B5/B8 |
| 3G | WCDMA: B1/B2/B4/B5/B6/B8/B19(RXD) CDMA: BC0 |
| GEO Satellite | Two-Way Satellite Messaging with Skylo Satellite Voice / Text / Location Message Support 120° Ultra-Wide Satellite Alignment Angle Global Coverage - Reliable Links Across 36 Countries within North America, Europe, Asia, South America, Australia, and New Zealand. |
| Hardware | |
| CPU | MediaTek Dimensity 8300 (4nm), Octa-core, Up to 3.35GHz |
| CPU Clock | ARM Cortex-A715 cores @ 3.35GHz*1, ARM Cortex-A715 cores @ 3.2GHz*3, ARM Cortex-A510 cores @ 2.2GHz*4 |
| GPU | Arm Mali-G615 MC6 core @ 1400MHz |
| RAM | 12GB/16GB |
| RAM Type | LPDDR5X |
| ROM | 256GB/1TB |
| ROM Type | UFS4.0 |
| TF Card Slot | YES |
| USB | TYPE-C |
| Camera | |
| Front Camera | 50MP |
| Front Camera Aperture | f2.45 |
| Rear Camera | 50MP main camera 20MP Night Vision Camera |
| Rear Camera Sensor | S5KGN9SP03-FGX9 + IMX376 |
| Rear Camera Aperture | f1.88 |
| Rear Flash | Yes |
| Video | 4K Video Recording |
| Power | |
| Battery Capacity | 20,000mAh, 120W Fast Charge |
| Max Charging Current | 20V/6A |
| Additional Tool | |
| Camping Lights | Dual LED 467 lumen (LM) |
| Infrared Remote Control | supports most IR-controlled devices |
| Multi-media | |
| Image | jpeg\png\gif\bmp |
| Features | |
| Navigation | GPS/GLONASS/BeiDou/Galileo |
| Motor | Flat motor |
| Sensors | G/P/L-sensor |
| Gyroscope | YES |
| Magnetic | YES |
| Air pressure sensor | YES |
| Hall | NO |
| Compass | YES |
| Fingerprint | YES |
| RGB | NO |
| NFC | YES |
| Hotkont | NO |
| Coulomb Counter | NO |
| Wireless Charging | NO |
| FM | YES |
| OTG | YES |
| Accessories | |
| User Manual | x1 |
| USB Cable | x1 |
What Is a Rugged Satellite Phone?
How Does a Rugged Satellite Phone Work?
Can a Rugged Satellite Phone Work Without Cell Service?
Can You Make Satellite Calls with the Blackview XPLORE 2 Satellite?
Can the Blackview XPLORE 2 Satellite Send Text and Location Messages?
Does the Blackview XPLORE 2 Satellite Support Emergency SOS?
Can the Blackview XPLORE 2 Satellite Communicate with Regular Smartphones?
Where Can You Use the Blackview XPLORE 2 Satellite?
Is the Blackview XPLORE 2 Satellite Waterproof and Drop-Resistant?
How Long Does the Blackview XPLORE 2 Satellite Battery Last?
Is the Blackview XPLORE 2 Satellite Good for Hiking, Camping, and Remote Travel?
Who Should Buy the Blackview XPLORE 2 Satellite?
What Is the Difference Between the Blackview XPLORE 2 Satellite and XPLORE 1?
The main difference between the Blackview XPLORE 2 Satellite and XPLORE 1 is satellite communication. Both are rugged 5G phones with large 20,000mAh batteries, but XPLORE 2 Satellite adds two-way GEO satellite messaging and also offers stronger performance and faster charging.
XPLORE 2 Satellite vs. XPLORE 1
| Feature | Blackview XPLORE 2 Satellite | Blackview XPLORE 1 |
| Satellite Communication | Two-way GEO satellite messaging with Skylo | Not supported |
| Satellite Functions | Voice messaging, text messaging, location messaging | Not supported |
| Satellite Coverage | Supported across 36 countries | Not applicable |
| Processor | MediaTek Dimensity 8300, 4nm | MediaTek Dimensity 7050, 6nm |
| Display | 6.73-inch 3.2K AMOLED, 120Hz | 6.78-inch FHD+ IPS, 120Hz |
| Battery | 20,000mAh | 20,000mAh |
| Fast Charging | 120W | 55W |
| Rugged Protection | IP68, IP69K, MIL-STD-810H | IP68, IP69K, MIL-STD-810H |
| Navigation | L1+L5 GPS, GLONASS, BeiDou, Galileo | L1+L5 GPS, GLONASS, BeiDou, Galileo, QZSS |
| Best For | Remote travel, camping, overlanding, fieldwork, and areas with poor cell coverage | Everyday rugged use, outdoor activities, and users who do not need satellite communication |
More Stable
