Hurry up, only 3 items left in stock.
✔FLIR® Lepton 3.5 Thermal Imaging Camera & FLIR SDK Mobile Support
✔Super-bright Dual LED Flashlights
✔6.78" 120Hz Main & 2.01" Multi-functional Secondary Display
✔6nm 5G MediaTek Dimensity 7050 & 20,000mAh Battery
✔Leading IP68 &IP69K & MIL-STD-810H Certified
The Blackview XPLORE 1 Pro is built for users who need dependable mobile performance in demanding environments. It combines a 6.78-inch 120Hz main display plus a 2.01-inch secondary display with MediaTek Dimensity 7050 5G performance and a 20,000mAh battery for work, travel, navigation, and outdoor use. Key field-ready features include FLIR Lepton 3.5 thermal imaging, 170LM dual LED flashlights, and IP68 & IP69K & MIL-STD-810H protection. Designed for job sites, remote trips, and everyday toughness, it gives users the confidence to stay connected, capture details, and keep going when regular phones are not enough.
| Design | |
| Product | Blackview XPLORE 1 Pro |
| OS | DokeOS 5.0 Based on Android 15 |
| Color | Black, Orange |
| Weight | 640g |
| Dimensions | 184×83×29.5mm |
| Screen | |
| Main Display | |
| LCD panel | BOE I680EBQ-12Q01X |
| IC | ILI7807S-10000IA |
| Panel Type | IPS |
| Display Resolution | FHD+ |
| Screen Size | 6.78 Inch |
| Screen Resolution | 1080*2460 20:9 |
| Screen to Body Ratio (%) | 86% |
| PPI/DPI | PPI: 396 |
| Refresh frequency | 120HZ |
| Glass | Corning® Gorilla® Glass 5 |
| Secondary Display | |
| Screen Size | 2.01 Inch |
| Screen Resolution | 240*296 |
| Glass | Panda Glass |
| Connectivity | |
| Bluetooth | V5.2 |
| 2G | B2/B3/B5/B8 |
| Hardware | |
| CPU | MediaTek Dimensity 7050 (6nm), Octa-core, Up to 2.4GHz |
| CPU Clock | ARM Cortex-A78 cores @ 2.4GHz*2, ARM Cortex-A55 cores @ 2.0GHz*6 |
| GPU | ARM Mali-G68 MC4 |
| RAM | 12GB/16GB |
| RAM Type | LPDDR5 |
| ROM | 256GB/512GB |
| ROM Type | UFS3.1 |
| TF Card Slot | YES |
| USB | TYPE-C |
| Camera | |
| Front Camera | 50MP |
| Front Camera Aperture | f2.45 |
| Rear Camera | 64MP main camera FLIR® Lepton® 3.5 Thermal Camera |
| Rear Camera Sensor | OV64B40-GA5A-002A + Thermal imaging mode |
| Rear Camera Aperture | f1.79 |
| Rear Flash | Yes |
| Video | 4K Video Recording |
| Thermal Imaging Camera Datasheet | |
| Model | Lepton 3.5, 160×120, 57° with shutter |
| Thermal Imaging Detector | Uncooled microbolometer |
| Pixel Size | 12 μm |
| Frame Rate Options | 8.7 Hz (commercial application exportable) |
| Thermal Spectral Range | Longwave infrared, 8 μm to 14 μm |
| Scene Temperature Range | High Gain Mode: -10 °C to 140 °C (14 °F to 284 °F) Low Gain Mode: -10 °C to +400 °C (14 °F to 752 °F) at room temperature |
| Power | |
| Battery Capacity | 20,000mAh, 55W Fast Charge |
| Max Charging Current | 20V/2.75A |
| Multi-media | |
| Image | jpeg\png\gif\bmp |
| Features | |
| Motor | Flat motor |
| Sensors | G/P/L-sensor |
| Gyroscope | YES |
| Magnetic | YES |
| Air pressure sensor | NO |
| Hall | NO |
| Compass | YES |
| Fingerprint | YES |
| RGB | NO |
| NFC | YES |
| Hotkont | NO |
| Coulomb Counter | YES |
| Wireless Charging | NO |
| FM | YES |
| OTG | YES |
| Infrared Remote Control | YES |
| Accessories | |
| User Manual | x1 |
| USB cable | x1 |
Does the Blackview XPLORE 1 Pro Support Fast Charging?
Does the Blackview XPLORE 1 Pro Support 5G?
What Navigation Features Does the Blackview XPLORE 1 Pro Support?
Is the Blackview XPLORE 1 Pro Waterproof and Dustproof?
Can the Blackview XPLORE 1 Pro Be Used in Cold or Hot Environments?
Is the Blackview XPLORE 1 Pro Suitable for Construction Work?
Is the Blackview XPLORE 1 Pro a Rugged Phone for Outdoor Use?
Who Is the Blackview XPLORE 1 Pro Rugged Phone Best For?
Does the Blackview XPLORE 1 Pro Have a Thermal Imaging Camera?
What Can You Use the XPLORE 1 Pro Thermal Camera For?
Can the XPLORE 1 Pro Thermal Camera Detect Heat in the Dark?
Can the XPLORE 1 Pro Thermal Camera Find Hot and Cold Spots?
Is the XPLORE 1 Pro Thermal Camera Useful for Inspections?
Can the XPLORE 1 Pro Thermal Camera Be Used Outdoors?
Is the Blackview XPLORE 1 Pro Good for Fieldwork?
What Is the Difference Between the Blackview XPLORE 1 Pro and BL8800 Pro?
The Blackview XPLORE 1 Pro and BL8800 Pro are both rugged 5G smartphones equipped with thermal imaging capabilities, but they cater to different needs. Below is a comparison of the key features of these two models to help you choose the one that best suits your outdoor activities, fieldwork, or thermal imaging inspection needs.
XPLORE 1 Pro vs. BL8800 Pro
| Feature | Blackview XPLORE 1 Pro | Blackview BL8800 Pro |
| Thermal Camera | FLIR Lepton 3.5 | FLIR Lepton 2.5 |
| Network | 5G | 5G |
| Processor | MediaTek Dimensity 7050 | MediaTek Dimensity 700 |
| Operating System | DokeOS 5.0 based on Android 15 | Doke OS 3.0 based on Android 11 |
| Battery | 20,000mAh | 8,380mAh |
| Fast Charging | 55W | 33W |
| Main Camera | 64MP | 50MP |
| Navigation | L1 + L5 dual-frequency GNSS | Standard GNSS |
| Rugged Protection | IP68, IP69K, MIL-STD-810H | IP68, IP69K, MIL-STD-810H |
| Best For | Long fieldwork, thermal inspections, outdoor trips | Daily thermal checks and general rugged use |
