Available in stock (18)
✔Latest Thermal Imaging FLIR® Lepton 3.5 & MyFLIR® Pro APP
✔50MP OIS Anti-shake Rear & 50MP Selfie Cameras
✔5G 6nm Octa-core MediaTek Dimensity 8020 CPU
✔Dual Band WiFi 6 & USB 3.0 Support
✔Dual Harman Kardon Smart-PA Speakers
✔Corning® Gorilla® Glass 7 (Victus®)
The Blackview BL9000 Pro turns a rugged 5G phone into a serious field tool. Powered by FLIR® Lepton 3.5 thermal imaging, it helps reveal heat, leaks, moisture, blockages, and hidden problem areas that ordinary cameras can’t see. Its 6.78-inch 120Hz display, 12GB RAM, 512GB storage, 8800mAh battery, and 120W fast charging keep performance strong through long workdays and outdoor adventures. With MIL-STD-810H durability plus IP68/IP69K protection, it’s built for professionals, explorers, and anyone who needs more than a regular smartphone.
BL9000 Pro
The World's First Highest-resolution Thermal Imaging 5G Rugged Phone with Android 14
Thermal Imaging Pro, Daily & Outdoor Life Comfort ProMax!
No.1
The Clearest Thermal Imaging Upgrades
No.2
The Smoothest-ever Performance Upgrades
No.3
All-new Android 14 OS Upgrades
No.4
Immersive Entertainment Upgrades
No.5
Top-tier Ruggedness Upgrades
No.1
The Highest-resolution Thermal Imaging Ever Backed by The Latest FLIR® Lepton 3.5
Epic Thermal Conquest. Invisible Made Visible
The Latest Thermal Imaging Backed by FLIR® Lepton 3.5
With the latest FLIR® Lepton 3.5 thermal sensor, Blackview BL9000 Pro captures thermal images in unprecedented detail, quadrupling the resolution and expanding the field of view to 57°, enhancing its ability to identify leaks, moisture, and blockages.
in Thermal Imaging Rugged Phones
FLIR® Lepton 3.5
The Latest FLIR® Thermal Imaging
MyFLIR® Pro
Cutting-edge Thermal Imaging App
Wider Horizontal FOV
160x120
4X Higher Thermal Resolution
Temperature Warning Alerts
Pinpoint Problem Areas
& Generate Reports
<50mK
Increased Thermal Sensitivity
-10°C to +400°C
Thermal Sensing Range
Teledyne FLIR Mobile
SDK Support
Convenient for further development by
Android/iOS users
Enhanced FLIR MSX®
FLIR Vivid-IR
Enhanced Sharpness ↑
More Precise ↑
Picture-in-Picture Mode
Visible/Thermal Alpha Blending Adjustment
MSX® Strength Adjustment
Thorough Upgrade across Points, Lines, and Areas
Min/Max Flags
Easier to Compare and Analyze
Moveable
(Locked Size) ROI
Temperature Alerts
Real-time Alerts & Reports When
Temperature Surpasses Threshold
Isotherm
Under, Span, Over
Hold Icon Help
9 Kinds of Palettes
Vivid-IR ON/OFF,
Flexibility↑
Rjpeg
The Ultimate Thermal Insight
Elevate your thermal imaging with BL9000 Pro, which allows for customizable MSX® intensity, merging thermal and actual images effortlessly, and utilizes VividIR™ technology to enhance image clarity for a peerless thermal viewing experience.
Single Point
Monitor temperatures at up to 5 points simultaneously, with the ability to freely move, label, and delete each point
Horizontal/Vertical Line
Record the average temperature along the same horizontal or vertical line
All-new Customizable Square Area
Monitor the temperature range within a square area, with the freedom to move and adjust its size
All-new Customizable Circular Area
Monitor the temperature range within a circular area, with the freedom to move and adjust its size
Full Infrared Mode
MSX
(Multi-Spectral Dynamic Imaging)
All-new Picture-in-picture
Visible Light
Sharp Focus, Vision Beyond Limits
Next-level imaging with VividIR™
With advanced image processing VividIR™, BL9000 Pro empowers users to observe finer components from greater distances, delivering the additional details and perspectives necessary for making crucial maintenance decisions quickly.
Teledyne FLIR Mobile SDK Support,
Convenient for further development by Android/iOS users
The Quick Fix to Heat Tricks
Temperature Alerts
Use the BL9000 Pro's temperature alarm to quickly detect and record temperature anomalies and generate readable reports.
step 1
Set warning temperature
step 2
Automatically take photos
step 3
Send reminder
step 4
Generate report
Monitor the safe temperature of infant formula
preparation and consumption beyond visual inspection
Treat your baby to the most enjoyable feeding moments
Identify the most comfortable
home temperature beyond visual assessment
Enjoy the utmost comfort at home to maintain good health
either too high or too low
immune system
Detect and prevent the invisible spread
of flu and fever in public spaces
Keep yourself, your family, and friends safe from
infection in public areas to maintain good health
Rapidly locate rescue targets in the early stages of a
fire amidst dense smoke that's visually imperceptible
Ensure the safe evacuation of stranded individuals, securing their safety
Quickly locate the pet's position in low-light
conditions where visual identification is difficult
After locate the pet in low-light conditions, ensure higher efficiency
Identify electrical circuit issues in the home
junction box that are not visually apparent
Prevent potential circuit damage or even fires, ensuring higher efficiency
Monitor the uncertainty of genuine
interest when expressing feelings
Avoiding emotional harm in relationships
Quickly spot clogs in faucet pipes
not apparent to the naked eye
Promptly restore regular use while also saving money
water flow
replacement
Quickly identify individuals or animals encountered
during night runs that are not visually discernible
Avoid potential hazards and run safely during the night
Quickly identify whether campfire embers are fully
extinguished after camping, beyond visual confirmation
Being aware that all lights on Mars are off helps minimize the occurrence of accidents
Quickly identify the fish comfort zone
beyond the naked eye's perception
Faster detection of the fish comfort zone leads to more successful fishing
Snap a cool Van Gogh-style selfie
Drop it on social for more likes and views
Identify aging issues not apparent to
the naked eye during vehicle checks
Timely resolution of aging concerns saves
on potential future repair or replacement expenses
No.2
5G Hyper-speed & 512GB ROM & 120W Super-fast Charging
Octa-core 5G MediaTek Dimensity 8020
Fast, Fierce, Flawless
Enjoy fluid and fast performance with Blackview BL9000 Pro, equipped with TSMC's 6nm octa-core processor up to 2.6GHz, delivering smoothness in both everyday apps and demanding games.
4 Super Cores
ARM Cortex-A78 up to 2.6GHz
4 Efficient Cores
ARM Cortex-A55 up to 2.0GHz
6nm TSMC
Flagship Process
9-Core GPU
Arm Mali-G77
AnTuTu 805,428
Highest Score Ever
512GB ROM Supported by Flash UFS 3.1
Gear up! New Chapter of Super Storage and Speed
Gear up for a new chapter of super storage! The 512GB ROM of BL9000 Pro lets you store more photos , videos, and apps without worrying about space constraints. Say goodbye to deleting files!
12GB RAM + 24GB Expansion =Up to 36GB RAM
The End of Slowdowns and Delays!
Supercharge your efficiency with BL9000 Pro's up to 36GB RAM, ensuring smooth multitasking and quick handling of complex tasks without any lag.
MediaTek HyperEngine Lite Gaming Tech
Get lost in the world of intense gaming, intricate scenes, and resource-demanding game engines, all while enjoying remarkably fluid performance
X-axis Linear Motor
Immerse yourself in a unique gaming experience with advanced X-axis linear motor , delivering extraordinary haptic feedback.
Atomized Memory 2.0
Efficiency Unleashed
BL9000 Pro's Atomized Memory 2.0 intelligently manages RAM, enhancing performance and creating up to 5-9% additional capacity for other tasks or multiple background apps.
Smart Pre-Loading
Start Faster, Stay Ahead
Designed to anticipate your app preferences, BL9000 Pro's intelligent Pre-Loading enhances startup speeds by 23%
23%
Dual Band WiFi 6
Game. Stream. Connect,Makes it Flawless
Boost your digital life with BL9000 Pro's WiFi 6, delivering stronger, faster connections for quick downloads, superior gaming, fluid streaming, and flawless video conferencing.
8800mAh Mega Battery
Fueling Your Adventures from Dawn till Dusk
Enrich your adventures with 8800mAh mega battery, providing long-lasting performance for all your endeavors, from outdoor exploration to daily tasks, without the hassle of frequent recharging.
Greet the Day Fully Charged in Minutes
Overnight charging is a thing of the past. With the BL9000 Pro's 120W super-fast charging , you can completely recharge your phone in just a quick morning break.
Integrated Cooling System
Ice Down, Speed Up
Maximize your gaming performance with the 3D copper pipe liquid cooling technology . Its cutting-edge design efficiently dissipates heat, ensuring sustained high-speed functionality and longer device life.
30,841mm²
Cooling Graphite & Copper Foil
2,794mm²
Cooling Copper Pipe
735mm²
Cooling Silicon
60fps
Continuous 1-Hour Average Frame Rate
42°C
Comfortable Grip Temperature
No.3
Seamless Operations with DokeOS 4.0 Based on Android 14
No.4
6.78-inch 2.4K FHD+ Display
Cinematic Magic. as Natural as Breathing
Immerse yourself in breathtaking visuals with 6.78-inch 2.4K FHD+ screen, providing vivid colors and sharp details for your browsing, gaming, or entertainment needs.
120Hz Smart Dynamic Refresh Rate
Where Every Pixel Flows Perfectly
Activate smart dynamic 120Hz refresh rate of BL9000 Pro for power-efficient task handling. It saves power during reading, then springs to life when you watch a blockbuster movie, offering impressive, uninterrupted visuals.
TÜV SÜD Low Blue
Light Certified
The Gateway to Eye-Relaxing
Improve your screen experience with BL9000 Pro's TÜV SÜD Low Blue Light and three eye-care modes,reducing eye strain and fatigue during late-night work or extended movie sessions.
Reading Mode
Night Light
Dark Mode
Sound By Harman AudioEFX®
Tune into Timeless, Feel the Beat
Dive into superior surround audio with Harman AudioEFX®, delivering unrivaled clarity and depth to music, movies, and games, transforming each listening session into an exceptional sonic journey.
Superior Clarity Image System
Record your creative thoughts with steadfast clarity, in every scenario.
50MP
Selfie Camera
13MP
Ultra-wide &
Ultra-macro Camera
50MP
Samsung® ISOCELL GN5
OIS Anti-shake Camera
50 MP True-Color
Selfie Camera
Be Vivid, Be True, Be You
Capture your moments in true vibrancy with 50MP high-definition True-Color selfie camera, ensuring each self-portrait reflects the authentic you with vivid clarity and lifelike colors.
50 MP
Rear Camera
Capture Every Detail, Miss Nothing
Capture stunning clarity with BL9000 Pro's 50 MP Samsung® camera, revealing sharp details in dense urban landscapes or intricate rock textures, with high-definition that stays clear even when zoomed in.
True-Chroma Image 2.0
What You See is What You Get
Capture nature's true hues with True-Chroma Image 2.0 , offering precise outdoor color accuracy and detail. Ideal for enthusiasts and creators, BL9000 Pro simplifies editing, making every outdoor adventure visually striking and authentic.
OIS Anti-shake
Ready, Steady, Action
Capture every moment with clarity using OIS Anti-shake, ensuring smooth shots from moving cars or during fast-paced action. No more shaky hands blurring your photos and videos.
4K Video Recording with Beauty Mode
Crisp, Clear, Cinematic
Bring your memories to life in vivid 4K main and front-facing cameras. Perfect for vloggers and selfie lovers, every frame is captured with crystal-clear detail, turning moments into cinematic masterpieces.
Ultra-wide for Ultimate Vistas
Capture the grandeur of sprawling natural vistas or iconic cityscapes with 120° Ultra-wide rear camera, ideal for immersing fully in the scene and preserving every awe-inspiring detail.
Pro
Complete command over camera settings for a fully tailored creative experience.
Mono
Evoking deep nostalgia and emotion.
Underwater Camera
Confidently take BL9000 Pro on any adventure; its underwater camera lets you snap stunning shots in pools or lakes, offering the liberty to discover and record every moment.
* Supports underwater photography up to 1.5m.
No.5
Ready to Conquer the Toughest Games
Reinforced rubber corners improve shock resistance and grip comfort.
Secure port covers block water, dust, and debris.
A sturdy one-piece design minimizes loosening or cracking, prolonging device life.
Aluminum alloy frame reinforced with screws to minimize disassembly risks.
Top-tier MIL-SPEC 810H
No Challenge Too Tough
Up to 1.2-Meter
High Death Broke Drop-proofness
Leading IP68 & IP69K Waterproofness
Operate in Extreme Temperatures
Unyielding in Any Climate
Tougher Corning® Gorilla® Glass 7(Victus®)
Built to Defy Drops and Scratches
Drop Height Resistance
Gorilla® Glas Glass Victus®
67%
Gorilla® Glass 5
Scratch Resistance
orilla® Glass Victus®
2X
Gorilla® Glass 5
Glove Mode 2.0
Stay Connected, Stay Cozy
30%
Sensitivity
Useful Toolkit
Enhance productivity with professional apps.
Customized Shortcut Button
Increase efficiency by customizing BL9000 Pro's key programming to your liking
Start Soundrecording
Open Flashlight
Screenshots
Open Underwater Camera
Open PTT
Open sos
Open Game Mode
Discover More to Love
Multifunctional NFC
Access a multitude of features with NFC, enabling your phone to act as a replacement for bank cards, transit cards, access cards, and a variety of other cards.
Dual SIM Slot
Embrace Dual SIM Slot for seamless connectivity and endless possibilities. Effortlessly manage two numbers, work, play, and stay globally connected with lightning-fast 5G.
International Coverage
GPS+Glonass+Galileo+Beidou
Navigate effortlessly with the help of 4-in-1 navigation system, ensuring you find the most suitable routes for your driving, hiking, or biking trips to your destination.
L1+L5
Dual-frequency GPS
≤10 Meters
↑More accurate positioning
Corning ® Gorilla ® Glass Victus ®
120Hz Refresh Rate
13MP (120° Ultra-wide & up to 2cm Ultra-macro)
2G Band:
GSM: 850/900/1800/1900
(B2/B3/B5/B8)
3G Band:
WCDMA: B1/B2/B4/B5/B8
CDMA: BC0/BC1/BC10
4G Band:
18/19/20/25/26/28A/28B/30/66
LTE-TDD:B34/38/39/40/41
5G Band:N1/3/5/7/8/20/28/
38/40/41/77/78/79
| Specifications | |
| Model | Blackview BL9000 Pro |
| Color | Splendid Gold, Interstellar Black |
| Dimension | 179.5*82.6*17mm |
| Weight | 412g |
| OS | DokeOS 4.0 Based on Android 14 |
| Main Display | 6.78-inch 2.4K FHD+, 1080*2460 Resolution Corning® Gorilla® Glass Victus® 120Hz Refresh Rate |
| Thermal Imaging | FLIRe Lepton 3.5,160x120 Thermal Resolution, MyFLIR® Pro Support |
| CPU | MediaTek Dimensity 8020 (6nm), Octa-core, Up to 2.6GHz |
| RAM & ROM | 12GB RAM & 512GB ROM, LPDDR4X+UFS3.1 |
| RAM Expansion | Up to 24GB |
| Battery | 8800mAh, 120W Super-fast Charge |
| Front Camera | 50MP(SK Hynix 5022Q) |
| Rear Camera | 50MP (Samsung® ISOCELL GN5) 13MP (120° Ultra-wide & up to 2cm Ultra-macro) |
| Speaker | Dual Harman Kardon Smart-PA Speakers, Sound By Harman AudioEFX® |
| Rugged Rating | MIL-STD-810H & IP68 & IP69K Waterproofness |
| Navigation | GPS+Beidou+Glonass+Galileo |
| Card Slot | Dual Hybrid SIM Slots |
| Glove Mode | Support |
| NFC | Support |
| Dual 5G VoLTE | Support |
| WiFi | WiFi 6, 2.4/5GHz (802.11a/b/g/n/ac/ax) |
| Network Connectivity | |
| 2G Band: | GSM: 850/900/1800/1900 (B2/B3/B5/B8) |
| 3G Band: | WCDMA: B1/B2/B4/B5/B8 CDMA: BC0/BC1/BC10 |
| 4G Band: | LTE_FDD: B1/2/3/4/5/7/8/12/13/17/18/19/20/25/26/28A/28B/30/66 |
