Blackview AceBook 8 15.6" Intel® 3.6GHz Processor 16GB DDR4 RAM 512GB SSD Windows 11 Home Laptop
Out of stock
✔ 15.6" 1.6kg Light & 18.2mm Slim
✔Intel® 3.6GHz Processor
✔16GB DDR4 RAM + 512GB SSD
✔Windows 11 Home OS
AceBook 8 is built for professionals, students, and creators who need reliable performance wherever work takes them. Featuring a spacious 15.6-inch FHD+ display, Intel® Processor N150, 16GB RAM, and a 512GB SSD, it delivers smooth multitasking, efficient productivity, and dependable mobility. With Windows 11 Home, versatile connectivity, and a lightweight design, AceBook 8 helps you work smarter and achieve more every day.
AceBook 8
Work Smarter, Create Greater
Efficiency Soars
with 15.6-Inch Screen & N150
Sleek Yet Modern Appearance
Lightweight to Carry,
Big on Performance
with 15.6-Inch Spacious FHD+ IPS Display
512GB SSD for Faster Working Speed
Super-Quiet Working Environment
Enhanced Work Multitasking Capabilities
Larger Screen, Better Visibility
Imagine you’re seamlessly transitioning between tasks with minimal scrolling and window switching. Wonderful, right? Sized at 15.6 inches, the screen of AceBook 8 allows you to have ample space for multitasking, improved work efficiency, and more.
Body Ratio
PPT Presentation with
Complex Graphs
Leave Every Detail Seen Clearly
Multiple Apps Management
Side by Side
More Organized and Effective
Simultaneous Data Analysis
and Report Creation
Real-time Data Reference
Market Research and Web
Browsing Together
Streamlined Workflow and Less Error-prone
Elevated Face-to-face Work
Communication
Broader Visual Workspace
Optimized Creative Design
and Editing
Improved Detail Visibility and
Immersive Editing
Swift, Strong, and Smart
AceBook 8 comes equipped with Intel® Processor N150, which handles light office work with smooth, responsive performance. Easily draft an email while analyzing complex data spreadsheets, or join a video conference with multiple tabs running in the background.
7nm Photolithography
Architecture
Lower Power Consumption
Up to 3.6GHz Burst Frequency
Quicker Boot Time,
Processing & Read Speeds
6MB Smooth Cache
Minimized Data Access Latency
4 Cores 4 Threads
Improved Multitasking Capabilities
16GB RAM for Improved Capability
More Memory, More Possibilities
Your laptop will freeze up and need to be restarted for a lack of RAM. Boasting 16GB RAM, AceBook 8 is much more capable and allows you to do tasks simultaneously without slowing things down. You can compare information in two Word documents on one hand, and edit a video clip on the other, yet your laptop runs smoothly.
Vast 512GB SSD with 1TB Expansion
Space to Explore, Freedom to Store
It’s quite easy to eat up space if you obsess over saving videos or installing lots of apps. Owing to its 512GB SSD (expandable up to 1TB), Acebook 8 offers you enough storage for files, software, and more. Store as many as possible if you want with Acebook 8.
38Wh Battery Capacity
Ideal Companion for Your Mobile Lifestyle
Worrying about nowhere to charge your device when working on flights or in transit? This is not such a hard-to-handle problem with AceBook 8. With 38Wh battery capacity, it offers sustained and reliable power for daily office tasks, enabling you to focus on work even for a business trip or during a commute. Plus, on a single charge of 3.3 hours, its battery can be fully charged, ready to empower your digital life over and over again.
on the actual usage situations.
Power Saving Mode
When the battery is low, it will automatically switch to power saving mode.
16800mm2 Total Cooling Area
No More Overheat, Just Stay Quiet
With a total cooling area of 16800mm2, AceBook 8 which dissipates heat by its inner copper pipes and fan can rapidly transfer heat from the processor, avoid unexpected restart or dreaded blue screen of death while maintaining low noise levels. Efficient, stable, and quiet, it’s perfect for your work where concentration and efficiency are of utmost importance.
Sufficient Eight Ports
Connect More, Do More
Various ports make your laptop versatile, allowing it to connect with a wide array of devices such as monitors, projectors, external hard drives, and more. AceBook 8 with 8 ports can meet various connectivity needs of yours without carrying a slew of dongles. A great chance for you to stay connected, productive, and entertained anytime anywhere.
HDMI 2.0
Connect, Display, Impress
With 4K resolution for a smoother and more detailed viewing experience, multiple displays connection available, and 18Gbps high bandwidth for fast data transmission, it really brings advantages to your office work. Whether for PPT presentations, immersive video conferences, or dynamic multimedia projects, this HDMI 2.0 port transforms your workspace into a hub of productivity and clarity.
Full-featured Type-C
Connect, Power, Play
One that does it all: from rapid data transfers at the rate of 10Gbps and fast charging to connecting multiple peripherals and external displays. One port that makes your digital life way easier.
Work-Friendly Windows 11 Home
Streamline Success,
Where Work Meets Ease
Productivity
Security& Privacy
Pre-installed
Microsoft Office
Office Ready, Success Steady
AceBook 8 comes with Microsoft Office pre-installed, which eliminates the need for time-consuming setups and installations. You can dive straight into productivity mode the moment you power up.
Focus Session
Sharpen Your Concentration
You can set, track, and achieve your goals correctly by choosing which period you decide to improve your concentration during work or study.
Do Not Disturb Mode
It makes it possible for you to control and limit notifications, pop-ups, alerts, and more. By minimizing distractions, you are assured of a quieter, and more focused environment when working.
Windows
Security Center
Your Digital World Guardian
Windows 11 Home features an integrated Security Center that offers comprehensive protection, including virus and threat protection, account protection, firewall and network protection, and more. Ensure the safety of your data and privacy.
Windows
Defender Firewall
Shield with Security
Always maintain it in active mode to prevent unauthorized access and network attacks, so you can keep your laptop and content within safe.
Windows Hello
Your Presence is the Key
It offers more secure sign-in options than traditional passwords, such as facial recognition, fingerprint identification, or a PIN. These secure methods can reduce the risk of account compromise.
Snap Layouts and
Snap Groups
Snap into Efficiency
With a single click, they ensure that all your essential applications, documents, and communications are precisely where you need them, when you need them. Work smarter, tackle more in less time, with less effort.
Virtual Desktop
One Screen, Multiple Worlds
You can create and manage multiple desktops for different purposes —work, personal, or gaming. By way of that, you can segregate tasks and concentrate on specific activities without clutter. Time to create dedicated environments for each project, client, or task without being distracted by unrelated applications and files.
Task View
Command Center for
Productivity
Accessible via the Task View button on the taskbar or by pressing Win + Tab, this feature provides an overview of all open windows and virtual desktops, making it easier to switch between tasks and manage your workspace.
New Widgets
Digital Assistant to Keep
You Informed
With personalized news, weather, calendar, to-do list provided, you can quickly know what’s happening without the need to fully switch tasks. Stay informed even if you’re working hard.
Live Captions
Communicate Across Barriers
By generating captions for audio content and offering a visual text, this feature can help you with better information acquisition. So when you have video conferences, online presentations with international colleagues, or work in a noisy office or public spaces, missing out on crucial information can be a little bit harder.
Narrator
Accessibility
Meets Productivity
Sometimes, you may have eye fatigue after prolonged screen exposure. By reading out text on the screen, such as emails, documents, web pages, you can promote work efficiency. Plus, you can listen to reports while engaging in other tasks like taking notes, thus enhancing multitasking capabilities.
| Model | AceBook 8 |
| Color | Gunmetal Grey, Frost Silver |
| Dimension | 359.52*233.83*19.90MM |
| Weight | 1.6KG |
| Display | 15.6-inch 1920*1080 FHD+IPS 84% Screen-to-body Ratio |
| CPU | Intel® Processor N150 |
| GPU | Intel® Graphics |
| Memory | 16GB, DDR4 |
| Storage | 512GB NVME/SATA SSD, up to 1TB Expansion |
| Camera | 1MP Front; 1280*720P Resolution |
| Battery | 38Wh; 36W Charge |
| Audio | 2 x Box Speakers/Stereo; 2 x Microphones/Noise Reduction |
| Port | 2 x USB 3.0, 1 x USB 2.0, 1 x USB-C, 1 x HDMI 2.0, 1 x DC Jack, 1 x Audio Jack,1 x MicroSD |
| Connectivity | IEEE 802.11 a/b/g/n/ac; BT 4.2/5.0 |
| OS | Windows 11 Home |
| AceBook 8 Specifications | |
| Model | AceBook 8 |
| Weight | 1.6KG |
