Hurry up, only 1 item left in stock.
✔5G Octa-core MediaTek Dimensity 7300 4nm Up to 2.5GHz
✔Built-in 400LM Camping Light & Night Vision Camera
✔30000mAh Big Battery w/ 55w Fast Charge
✔Sound By Harman AudioEFX®
✔Adjustable Aluminum Alloy Bracket
✔MIL-STD-810H Certified & IP68 & IP69K Waterproof
The Active 10 Pro is built for users who need reliable performance when visibility, power, and connectivity matter most. Designed for night shifts, outdoor operations, and emergency-ready situations, it combines a night vision camera with a built-in camping light to support work in low-light environments. Its massive 30000mAh battery keeps you powered through long days in the field, while 5G connectivity helps teams stay connected, responsive, and productive wherever the job takes them.
| Design | |
| Product | Active 10 Pro |
| OS | DokeOS_P 4.0 Based on Android 14 |
| Color | Black, Orange |
| Weight | 1214g |
| Dimensions | 267.6*179*19.5mm |
| Screen | |
| IC | ICNL9951R |
| Panel Type | IPS |
| Display Resolution | FHD+ |
| Screen Size | 10.95 inch |
| Screen Resolution | 1920x1200 16:10 |
| PPI | 207 |
| Refresh frequency | 90HZ |
| Screen to Body Ratio (%) | 83% |
| Glass | CORNING® GORILLA® GLASS 5 |
| Connectivity | |
| 2G | GSM: B2/B3/B5/B8 |
| 3G | B1/B2/B4/B5/B6/B8/B19, CDMA:BC0/BC1/BC10 |
| 4G | FDD:B1/B2/B3/B4/B5/B7/B8/B12/B13/B17/B18/B19/B20/B25/B26/B28A/B28B/B30/B66 TDD:B34/B38/B39/B40/B41 |
| WIFI | IEEE802.11 a/b/g/n/ac/ax(WiFi6) |
| Bluetooth | V5.4 |
| Hardware | |
| CPU | MediaTek Dimensity 7300(MT6878) |
| CPU Clock | 4*A78@2.5GHz; 4*A55@2.0 GHz |
| GPU | Arm Mali-G615 GPU |
| RAM | 12GB |
| RAM Type | LPDDR5 |
| ROM | 256GB/512GB |
| ROM Type | UFS3.1 |
| TF Card Slot | Support |
| Max TF Card Capacity | Up to 2TB |
| USB | TYPE-C |
| Speaker | Dual Harman Kardon Stereo Smart-PA BOX Speakers |
| Camera | |
| Front Camera | 50MP |
| Front Camera Aperture | F2.5 |
| Rear Camera | 108MP Main + 20MP Night Vision |
| Rear Camera Sensor | Samsung® ISOCELL HM6 + SONY IMX376 |
| Rear Camera Aperture | F1.9/F1.8 |
| Rear Flash | Yes |
| Power | |
| Battery Capacity | 30000mAh |
| Max Charging Current | 20V/2.75A, 55W Fast Charging |
| Multi-media | |
| Video | mp4\3Gp\3gpp\avi\x-flv... |
| Audio | ogg\aac\imy\amr\x-flac\mp3.... |
| Image | jpeg\png\gif\bmp |
| Features | |
| Navigation | GPS+Glonass+Beidou+Galileo |
| Motor | YES |
| Sensors | Light, G-sensor |
| Gyroscope | YES |
| Magnetic | YES |
| Air pressure sensor | YES |
| Hall | NO |
| Compass | YES |
| Fingerprint | YES |
| RGB | YES |
| NFC | YES |
| Hotkont | NO |
| Coulomb Counter | YES |
| Wireless Charging | NO |
| Sim-Card Type | two nano card ,one TF card |
| FM | YES |
| OTG | YES |
| Earphones Jack Type | 3.5mm jack |
| Accessories | |
| User Manual | x1 |
| USB Cable | x1 |
