Hurry up, only 3 items left in stock.
✔FLIR® Lepton 3.5 Thermal Imaging Camera & FLIR SDK Mobile Support
✔Super-bright Dual LED Flashlights
✔6.78" 120Hz Main & 2.01" Multi-functional Secondary Display
✔6nm 5G MediaTek Dimensity 7050 & 20,000mAh Battery
✔Leading IP68 &IP69K & MIL-STD-810H Certified
The Blackview XPLORE 1 Pro is built for users who need dependable mobile performance in demanding environments. It combines a 6.78-inch 120Hz main display plus a 2.01-inch secondary display with MediaTek Dimensity 7050 5G performance and a 20,000mAh battery for work, travel, navigation, and outdoor use. Key field-ready features include FLIR Lepton 3.5 thermal imaging, 170LM dual LED flashlights, and IP68 & IP69K & MIL-STD-810H protection. Designed for job sites, remote trips, and everyday toughness, it gives users the confidence to stay connected, capture details, and keep going when regular phones are not enough.
Lepton 3.5 — Wider. Smarter. Tougher.
<50 mK Sensitivity | –10 °C – 400 °C Range
(Multi-Spectral Dynamic Imaging) Alpha Fusion Mode
(All-New Picture-in-Picture) Full Visible Mode
Focus on Whats Matters Whether monitoring large areas or focusing on specific spots, each mode gives you control, clarity, and actionable insights. Spot Measure temperature at an individual Spot
Add up to five spots per image simultaneously Full Frame Display temperature for the entire scene
Time-lapse
[Industry’s Only]
Tailored to Your Needs
Boilers leaks Identifying
Resistance, 1.5m Death-broke Drop-proof,
Protection, 6m Free-fall Durability Beyond the Limits, Conquer Every Extreme
1.5m Death-broke Drop-proofness
Please note that real-world performance may vary.
Touch
Sensitivity
Every Chosen Material, Rigorously Tested and Proven,
Fearless of Any Challenge
aperture earpiece mesh
Waterproof Even Without the Plug
camera and side buttons
5 Screen
Aluminum Alloy Shell
Unscratched
500kg of Pressure
5000+ Times
10,000+ Times
1000+ Times
Certification
Dual LED Flashlights Light up Your Way, Stay Safer All the Way
rescues in the deep dark.
Detect Dangerous Creatures in Advance
Avoid Stepping into Pits and Traps
Use SOS Mode in Emergencies to Get Yourself Spotted
Help Night-shift Workers Perform Tasks More Accurately
device that uses an IR remote, including
TV
Air conditioner
Set-top box
DVD player
Projector
Fan
IR-controlled lighting
Others
Immersive Visual Experience from Every Detail Dual Screens, Doubled Efficiency
Everything You Need, Right on Your Sub-screen
& Alerts
Weather
Compass
and Easier Selfies
Your Watch Faces
for Any Adventure Power Beyond Limits,
Charge Quicker than Ever
≈ 4x mobiles of regular battery capacity
Computing 2.0
Protection Extended Battery Life
Protection Algorithm
a seamless power-up experience.
Charging
Dock Charging 45W Wireless
Charging Dock
Ready for Everything You Do
Power Through Tasks, Speed Through Games
Accelerator
Higher Efficiency
& Wider Coverage
Energy-saving AI Features
6*A55@2.0GHz UP to 2.4GHz Clock Speed ARM Mali-G68 MC4
Dual-band
WiFi 6
WiFi 5 Tech
Up to 2TB TF Expansion Power Through Anything, Store Everything
More Songs
16GB RAM + 32GB Expansion
Faster Response Speed
Every Moment, Vividly Captured From True Color to True Heat
All Scenes, All Mastered
(f/1.79)1/2″
6P
Samsung® JN1
(f/1.8)1/2.76″
5P
super pixel to enhance
light sensitivity
of Light and Color
Information
More Accurate
Autofocus
Control
Seamless Brightness
Transition
present your best self with unparalleled clarity.
Effortless Clarity
Smart Shooting Assistance Perfect Shoots, Easy Control
Smarter to Operate Powered by DeepSeek-R1,
ChatGPT, Gemini AI 2.0 Flash
Assistance
Ideas Unleashed Experience lightning-fast,
deep-thinking AI search, effortless
document analysis, and smart writing assistance, unlocking smarter insights and boundless creation.
Composition
Parsing
DeepSeek-R1
Assistant
Make Every Post Go Viral Boasting up to 18 powerful AI editing tools, it allows you to easily edit your photos and make every post of yours shine with new life and instantly go viral!
Create Video in a Click From daily v-logs, creative shorts, or exciting moments, it can revitalize your videos with intelligent AI tech! Simply input text or images, and watch as AI generates stunning videos, turning your words and pictures into an unforgettable visual feast.
Based on Android 15 Customization↑ Convenience↑ Fluency↑Privacy↑
Control Center Side by Side,
More Efficient
Shortcuts Add Third-Party
Apps Freely
free space
docs—your way
run like new
uninstall freely
keep it pure
with one tap
create cinematic vibes
leveler,haptic feedback—all
within reach
steadier frames
& choose from
3 metering modes
All in One Search
Move Notes freely to Folders
Update Date
and Export.
from Recycle Bin
Listing Icons, and Custom
Text Colors.
and Colors.
Priority options
Find Everything
Directly Reach the Answer
Instant Insights
and Activity Suggestions
Multiple Effects
Wireless BT
and Work
Surf Companion
Assistant Move Everything,
Hassle-Free
Make it Uniquely Yours For a more vibrant and unified look,
XPLORE 1 Pro brings richer wallpapers, themes, and colors for refreshed interfaces.
Live and Textured Wallpaper
Easy Interface Customization
a More Unified Look
Text Customization Tailored Readability, Just for You
Faster Performance
Media Permissions Customize App Access to
Your Media Files
Store Sensitive Files
Interface for Kids
Apps And Sensitive Data
More Seamless and Effortless Every Day
Dual-band GPS+Beidou+
Glonass+Galileo+QZSS
Online Support Get help anytime,
anywhere.
Repair Centers Expert technicians,
genuine parts.
Android Updates Always fresh, secure,
and up to date.
Warranty Peace of mind for the
long haul.
ModelXPLORE 1 Pro
ColorBlack, Orange
Dimension184*83*29.5mm
Weight640g
OSDokeOS 5.0 Based on Android 15
Display6.78-inch 2.4K FHD+IPS, 1080*2460 Resolution,
Corning® Gorilla® Glass 5,
120Hz Refresh Rate,
Secondary Screen: 2.01-inch, 240*296 Resolution -
CPUOcta-core 5G MediaTek Dimensity 7050, 6nm, Up to 2.4GHz
RAM & ROM12GB RAM & 256GB ROM, LPDDR5+UFS3.1
16GB RAM & 512GB ROM, LPDDR5+UFS4.0 -
TF ExpansionUp to 2TB Expansion
Battery20,000mAh; 55W Fast Charging
Front Camera50MP (Samsung® ISOCELL JN1)
Rear Camera64MP
Speaker1PC 1134 Smart-K BOX Speaker
Rugged RatingIP68 &IP69K& MIL-STD-810H
NavigationGPS/GLONASS/BeiDou/Galileo/QZSS( L1、L5)
Glove ModeSupport
NFCSupport
Dual 5G VoLTESupport
Network Connectivity3G Band:
WCDMA: B1/B2/B4/B5/B6/B8/B19,
CDMA: BC0/BC1/BC10
4G Band:
TDD: B34/B38/B39/B40/B41
5G Band: N1/3/5/7/8/20/28/38/40/41/77/78
| Design | |
| Product | Blackview XPLORE 1 Pro |
| OS | DokeOS 5.0 Based on Android 15 |
| Color | Black, Orange |
| Weight | 640g |
| Dimensions | 184×83×29.5mm |
| Screen | |
| Main Display | |
| LCD panel | BOE I680EBQ-12Q01X |
| IC | ILI7807S-10000IA |
| Panel Type | IPS |
| Display Resolution | FHD+ |
| Screen Size | 6.78 Inch |
| Screen Resolution | 1080*2460 20:9 |
| Screen to Body Ratio (%) | 86% |
| PPI/DPI | PPI: 396 |
| Refresh frequency | 120HZ |
| Glass | Corning® Gorilla® Glass 5 |
| Secondary Display | |
| Screen Size | 2.01 Inch |
| Screen Resolution | 240*296 |
| Glass | Panda Glass |
| Connectivity | |
| Bluetooth | V5.2 |
| 2G | B2/B3/B5/B8 |
| Hardware | |
| CPU | MediaTek Dimensity 7050 (6nm), Octa-core, Up to 2.4GHz |
| CPU Clock | ARM Cortex-A78 cores @ 2.4GHz*2, ARM Cortex-A55 cores @ 2.0GHz*6 |
| GPU | ARM Mali-G68 MC4 |
| RAM | 12GB/16GB |
| RAM Type | LPDDR5 |
| ROM | 256GB/512GB |
| ROM Type | UFS3.1 |
| TF Card Slot | YES |
| USB | TYPE-C |
| Camera | |
| Front Camera | 50MP |
| Front Camera Aperture | f2.45 |
| Rear Camera | 64MP main camera FLIR® Lepton® 3.5 Thermal Camera |
| Rear Camera Sensor | OV64B40-GA5A-002A + Thermal imaging mode |
| Rear Camera Aperture | f1.79 |
| Rear Flash | Yes |
| Video | 4K Video Recording |
| Thermal Imaging Camera Datasheet | |
| Model | Lepton 3.5, 160×120, 57° with shutter |
| Thermal Imaging Detector | Uncooled microbolometer |
| Pixel Size | 12 μm |
| Frame Rate Options | 8.7 Hz (commercial application exportable) |
| Thermal Spectral Range | Longwave infrared, 8 μm to 14 μm |
| Scene Temperature Range | High Gain Mode: -10 °C to 140 °C (14 °F to 284 °F) Low Gain Mode: -10 °C to +400 °C (14 °F to 752 °F) at room temperature |
| Power | |
| Battery Capacity | 20,000mAh, 55W Fast Charge |
| Max Charging Current | 20V/2.75A |
| Multi-media | |
| Image | jpeg\png\gif\bmp |
| Features | |
| Motor | Flat motor |
| Sensors | G/P/L-sensor |
| Gyroscope | YES |
| Magnetic | YES |
| Air pressure sensor | NO |
| Hall | NO |
| Compass | YES |
| Fingerprint | YES |
| RGB | NO |
| NFC | YES |
| Hotkont | NO |
| Coulomb Counter | YES |
| Wireless Charging | NO |
| FM | YES |
| OTG | YES |
| Infrared Remote Control | YES |
| Accessories | |
| User Manual | x1 |
| USB cable | x1 |
