Blackview OSCAL S60 Pro 5.7-inch 4GB+32GB 13MP+8MP 4G NFC Ruggedized Cellphone
Note:
S60 Pro
IP68&IP69K&MIL-STD-810H
5.7-inch HD+
4GB+32GB MediaTek A25
Underwater Mode
8MP+13MP Camera
5580mAh
Android 11 Doke OS 2.1
Multifunctional NFC
Rugged & Tough
Invincible from inside out
Constructed from durable TPU and reinforced polycarbonate with 10% Glass Fibers material and treated with various durability tests, S60 Pro, with a robust structure, can well protect itself from daily rough uses. Have peace of mind whether on construction sites or outdoors.
*Solid unibody to reduce risks of falling apart
*High-strength Panda glass for scratch and crack resistance
*Thickened jagged corners to buffer shocks and crashes
*Double-shot molding process for slip and drop resistance
IP68 & IP69K & MIL-STD-810H
Survive from Any Challenges
The solid build that cannot be compared by most delicate and fragile mainstream smartphones makes it exceptionally resistant to damage caused by falls, water immersion, shock and impact.
Water, Oil, Coffee Resistant
Waterproof up to 1.5m deep for 30mins,
Oil & coffee splash resistant
Dustproof
Rock, dust, mud proof
Drop-proof
*Drop-proof up to 1.5m height
5580mAh Battery
Power Lasts Longer
Charge less and extend longer. The large 5580mAh battery with built-in smart battery management effectively avoids running out of juice in the middle of enjoyment even for heavy uses.
7hrs
Game
8hrs
HD video
11.5hrs
Web
24hrs
Calling
28hrs
Music
288hrs
*The battery data is tested by OSCAL Laboratory.
5.7" HD+ Display
Rugged to Resist, Clear to View
Make every frame clear and vivid on the large 5.7" HD+ display. On the exterior, it's covered with high-strength Panda glass to avoid daily screen scratches or breaks. Always get the pleasing and spellbinding visuals.
5.7" HD+ Display
Octa-core MediaTek Helio A25
Smooth & Responsive to Multitask
Powered by a fast octa-core CPU coupled with 4GB RAM and 32GB internal storage it's easy to execute your demands with enough efficiency and fluidity.
RAM
ROM
Expandable Storage
Underwater Mode
Capture the Beauty on Land or in Water
With the Underwater mode available, make awesome snaps for the splendid scenes or other wonderful life moments anywhere.
8MP Front Camera
13MP Rear Camera
Always Find Your Way
Coordinating 4 navigation satellite systems together, S60 Pro is capable of providing more reliable and accurate positioning to help never lose the way especially in outdoor explorations.
GPS -
Galileo -
Glonass -
Beidou
GPS -
Galileo -
Glonass -
Beidou
Multifunctional NFC
As Easy As Breathing
Easier and faster. The user-friendly NFC function supports Google pay, public transport ticket purchase, and files sharing with other devices.
Doke OS 2.1
Based on Android 11, Intuitive & Smooth
S60 Pro combines the developed Doke OS 2.1 and Android 11 OS to boost interaction smoothness and efficiency.
Dual Artistic Themes
Both are designed with exquisite wallpapers and app icons for aesthetics and intuitiveness.
System Manager
Get better and smarter all-in-one control such as over the battery and app management.
Cold Room
One click to put rogue apps in the Freezer and stop their stealthy background running.
Clone Phone
Safely transfer all the data from old to new device even without Wi-Fi or mobile data.
Screenshot/Long Screenshot
For important messages, make a screenshot or long screenshot and edit it easily.
Split View
Support a multi-window view and help multitask effectively and productively.
Oasis Green
Flame Orange
Eclipse Black
