Blackview N2000 Flip 2.8"+1.77" Display Unisoc T107 1500mAh Dual SIM 4G Cell Phone
$99.99 $74.99
N2000 Go Flip. Go Smaller. Go Easier. Teal Blue Ruby Red Midnight Black Compact, Ultra-light Measuring only 112g of light, the...
Color: Red
Red
Blue
HURRY! ONLY LEFT IN STOCK.
paypalvisamastermaestrojcbamerican expressdiners clubdiscovercartes bancairesklarnaafterpaygoogle payapple pay
Frequently Bought Together
Total price:$199.97 $144.97
Description
Teal Blue
Ruby Red
Midnight Black
Compact, Ultra-light Measuring only 112g of light, the Blackview N2000 can slip into even the smallest pockets or bags without issue when folded.
2.8" main display adjustable for larger-sized text and brightness
2.8"
1.77"
1.77" display rendering a preview of incoming calls and notification alerts
No.2 Easy to Use with
Ease of Use
Large Backlit Keypad
Intuitive.
User-friendly.
Navigate effortlessly in any lighting with the large backlit keypad and set shortcut keys for one-tap access to FM audios, camera, torch and even more.
Clear Calls and Audio with HAC
Clear Calls. Stay Connected Closely. Equipped with a loud speaker with Hearing Aid Compatibility rated M4/T4, the Blackview N2000 enabling clarity into your calls and FM audios.
Capture Life's
Important Moments
Retain every important moment using Blackview N2000. With a flip design, experience retro DV shooting.
On-the-Go Convenience.
On-the-Way Enjoyment.
FM Radio Support
Turn on the built-in FM radio and set it to your favorite channels. -Enjoy the joy of music on the go with the Blackview N2000.
No.3 Practical Functions for Emergency Use
Stay Connected
with Peace of Mind
SOS Side Key Long press to make an SOS call in case of emergency.
Always stay in touch with your best friends and beloved family with dual SIM support.
Free Desk Charging Dock Put the Blackview N2000 on the charging dock, and charging begins. Keep your workspace organized and prevent cables from becoming tangled.
Midnight Black
Ruby Red
Teal Blue
108.4*57*19mm
  • Model
    Blackview N2000
  • Color
    Midnight Black/Ruby Red/Teal Blue
  • Dimension
    108.4*57*19mm
  • Weight
    112g
  • OS
    RTOS
  • Main Display
    2.8-inch internal display, 240*320 resolution;
    1.77-inch external display, 128*160 resolution
  • CPU
    Unisoc T107
  • RAM & ROM
    48MB+128MB
  • ROM Expansion
    Up to 64GB
  • Battery
    1500mAh; 5W charging
  • Rear Camera
    2MP Rear
  • Support
    FM radio
  • HAC Rating
    M4/T4
  • Card Slot
    Three; 1*TF + 2*SIM
  • Network Connectivity
    2G spec: B2/B3/B5/B8
    3G spec: B1/B8
    4G spec:
    FDD:B1/B3/B7/B8/B20/B28A/B28B
    TDD:B40/B41
Blackview N2000
Pocketable, and comfortable to hold and use
112g Ultra-light
1.77-inch
secondary
display
2.8-inch
main
display
1500mAh
Battery
48MB RAM
+128MB ROM
Up to 64GB
Expandable Storage
2 MP Rear Camera
FM
Radios
Unisoc
T107
Why Choose Blackview N2000?
No.1 Functional Dual-screen Flip Design
No.2 Easy to Use with Ease of Use
No.4 Fluid Daily Use with Peace of Mind
The Blackview N2000 features a functional flip design with dual displays: the rear one renders a preview of incoming calls and notification alerts without unfolding it while the internal one offers adjustable text and brightness for a more comfortable viewing.
Easy-to-use and Intuitive Keypad
Audio and Calls with
Dual SIM Support
1500mAh Battery
Power that's Ready for
On the Go
Enjoy uninterrupted usage without interruptions, ensuring you always stay connected with your loved ones throughout the day. Its removable design allows for effortless swapping for continuous usage whenever and wherever you need it.
288 hrs
8 hrs
Call
9 hrs
Video
27 hrs
Music
*The data is tested by Blackview lab based on continuous use. The actual usage may vary.
Always Standby. Dual SIM Support
Bright Torch Be Fearless to the Darkness
Set a shortcut for easy access to the bright torch, and whenever you need it, long press the button, and it will brighten for you.
Peace of Mind
Ample Space for Fun 48MB RAM + 128MB ROM
Equipped with 48MB of RAM, you can navigate fluidly for daily use. With 128MB of ROM plus up to 64GB of expandable internal storage via a microSD card, it offers ample space for pictures and videos.
48MB RAM
+128MB ROM
Up to 64GB
Expandable Storage
112g Ultra-light
1.77-inch
secondary
display
2.8-inch
main
display
1500mAh
Battery
2 MP Rear Camera
FM
Radios
Unisoc
T107
Dual SIM Support
Teal Blue
Ruby Red
Midnight Black
2.8" main
display
2.8 "
1.77 "
Ease of Use
Large Backlit Keypad Intuitive.
User-friendly.
Capture Life's
Important Moments
FM Radio Support
Stay Connected
with Peace of Mind
Peace of Mind
1500mAh Battery Power that's Ready for
On the Go
288 hrs
8 hrs
Call
9 hrs
Video
27 hrs
Music
Midnight Black
Ruby Red
Teal Blue
108.4*57*19mm
  • Model
    Blackview N2000
  • Color
  • Dimension
    108.4*57*19mm
  • Weight
    112g
  • OS
    RTOS
  • Main Display
  • CPU
    Unisoc T107
  • RAM & ROM
    48MB+128MB
  • ROM Expansion
    Up to 64GB
  • Battery
  • Rear Camera
    2MP Rear
  • Support
    FM radio
  • HAC Rating
    M4/T4
  • Card Slot
    Three; 1*TF + 2*SIM
    3G spec: B1/B8
    4G spec:
    TDD:B40/B41
Blackview N2000
Always Standby. Dual SIM Support Always stay in touch with your best friends and beloved family with dual SIM support.
