Blackview N2000 Flip 2.8"+1.77" Display Unisoc T107 1500mAh Dual SIM 4G Cell Phone
Out of stock
Ease of Use
User-friendly. Navigate effortlessly in any lighting with the large backlit keypad and set shortcut keys for one-tap access to FM audios, camera, torch and even more.
Important Moments Retain every important moment using Blackview N2000. With a flip design, experience retro DV shooting.
On-the-Way Enjoyment. FM Radio Support
with Peace of Mind
ModelBlackview N2000
ColorMidnight Black/Ruby Red/Teal Blue
Dimension108.4*57*19mm
Weight112g
OSRTOS
Main Display2.8-inch internal display, 240*320 resolution;
1.77-inch external display, 128*160 resolution -
CPUUnisoc T107
RAM & ROM48MB+128MB
ROM ExpansionUp to 64GB
Battery1500mAh; 5W charging
Rear Camera2MP Rear
SupportFM radio
HAC RatingM4/T4
Card SlotThree; 1*TF + 2*SIM
Network Connectivity2G spec: B2/B3/B5/B8
3G spec: B1/B8
4G spec:
FDD:B1/B3/B7/B8/B20/B28A/B28B
TDD:B40/B41
secondary
display 2.8-inch
main
display
Battery
48MB RAM
+128MB ROM
Up to 64GB
Expandable Storage
2 MP Rear Camera
FM
Radios
Unisoc
T107
Audio and Calls with Hearing Aid Compatibility
On the Go
Peace of Mind
+128MB ROM
Expandable Storage
secondary
display 2.8-inch
main
display
Battery
Radios
T107
display adjustable for larger-sized text and brightness
Ease of Use
with Peace of Mind
Peace of Mind
On the Go Enjoy uninterrupted usage without interruptions, ensuring you always stay connected with your loved ones throughout the day. Its removable design allows for effortless swapping for continuous usage whenever and wherever you need it.
Weight112g
OSRTOS
CPUUnisoc T107
RAM & ROM48MB+128MB
Rear Camera2MP Rear
SupportFM radio
HAC RatingM4/T4
3G spec: B1/B8
4G spec:
TDD:B40/B41
Blackview N2000
