Blackview A80s 4GB+64GB Octa-core 6.217 inches 4G Dual SIM Smartphone
✔6.217 inch Waterdrop Screen
✔Octa Core 4GB+64GB
✔13MP+5MP Camera
✔Android 10.0 4G Smartphone
A80s
Beyond Your Expectations
Sony® 13MP
Quad Camera -
Octa-core
4GB + 64GB -
4200mAh Big
Battery
Quad Camera
Every Shot Is Amazing
Even a mundane moment is worth recording. Capture it and turn each shot into a masterpiece with the Sony® 13MP quad-camera setup. A killer feature which is rarely seen on a budget smartphone, but A80s makes it.
Enjoy It and Unlock
Your Creativity
5MP Front Camera
Snap Better Selfies
The 5MP front camera with a BSI sensor ensures clear image and improves the low-light performance,
whether you're taking a selfie or on a video call.
Incredibly Long-lasting Fun
While extremely thin and lightweight, A80s doesn't cut down on functional experiences. With a 4200mAh large-capacity battery, it allows you to watch 7.6-hour video and listen 25-hour music, without stopping for recharging every few hours. Just go on with your everyday tasks with more confidence.
8h
Video
25h
Music
14h
Calling
152h
Viewing Experience
Surprisingly Good
6.21
inches
19.9
aspect ratio
In-cell
display
Ultra-thin and Lightweight
Even with A 4200mAh Battery
A cumbersome smartphone? No, no one would like to hold a cumbersome device for the whole day. A80s comes with a slim, lightweight and brilliant contoured design that feels great in your hand.
8.8mm
Slim body
180g
Weight
Android 10
It's Just the Way You Want It.
Smarter, safer, smoother and more user-friendly. Based on Android 10, it's smoother to enjoy your smart life on A80s with features like smart assistance, sound amplifier, gesture navigation, dark theme, location controls and security updates. Technology do change our life.
Octa-core Processor
Smoother & Power-efficient
Featuring a Mediatek Helio A25 octa-core processor and the 4GB RAM, A80s ensures smoother performance even running multiple tasks and enhance power efficiency in the meanwhile. Pairded with 64GB storage, it allows you to work more, play more, share more and at the same time plug in less.
4GB
RAM
64GB
ROM
Face and Fingerprint Unlock
The Easier and Faster the Better
Place your finger on the fingerprint sensor, or let your device scan your face. No need to enter a password for each time and do what you want right now.
Face recognition, safe and lightning fast
Rear-mounted fingerprint sensor, easy to reach
Sound Quality Also Matters
Thanks to the Box audio cavity and a sophisticated speaker unit, A80s delivers sound quality with noise greatly eliminated, allowing you to immerse in music or video even at full volume.
Fast & Precise Navigation
Always Find Your Way through Exploration
Supported with GPS, GLONASS & BeiDou triple navigation systems, A80s will be your reliable partner, minimizing the dead zone and providing you with precise positioning when driving bettween urban canyons or playing outside.
Classic Colors
Never Go out of Fashion
Tasteful Black
Modern Red
Dreamy Blue
Beyond
Your Expectations
Sony® 13MP Quad
Camera Setup
4200mAh Battery
Android 10
8.8mm Slim Body
6.21-inch HD+ Waterdrop Display
Octa-core Processor
4GB RAM + 64GB ROM
4G Connectivity
