Blackview W50 10-meter Waterproof Stylish Sports & Fitness Smart Watch
£54.00 £36.00
✔1.39 inch Display
✔100+ Workout Modes
✔24-hour SpO2 & Heart Rate Monitoring
✔Up To 5-7 Days of Battery Life
Color: Black
Gray
Green
HURRY! ONLY LEFT IN STOCK.
Frequently Bought Together
  • Blackview W50 10-meter Waterproof Stylish Sports & Fitness Smart Watch
Total price:£54.00 £36.00
  • This item: Blackview W50 10-meter Waterproof Stylish Sports & Fitness Smart Watch £54.00 £36.00
Description
W50
The World's First Rugged
& Higher-Quality Bluetooth
Calling Smartwatch
NO.1 THE WORLD'S FIRST RUGGED SMART WATCH
Salt Spray & Alcohol
& Cosmetics-
resistant
All-new Colorfast Oil-
filling Craftsmanship
The white fonts on W50 are manufactured by an all-new oil-filling process, providing outstanding salt spray resistance . Therefore, whether you are sweating profusely at the gym, or cooking in a smoky kitchen, you don't need to take off the W50. Even alcohol or cosmetics will not easily fade its bright fonts, ensuring its durability.
Water and Dust Won't Stop Us IP68 Waterproof & Dust-proof
You can be confident that water droplets from handwashing or light rain will not damage the W50 with its up to 10-meter waterproof . Besides, its IP68 rating ensures complete protection against dust ingress. Whether you are engaging in outdoor activities such as hiking and cycling, or cleaning your room, you can be assured that dust contamination will not be a concern.
Sweating in the gym
Meet light rain on the way home
Splash-proof when
washing hands
Always be Durable Up to 5m Death Broke
Drop-proofness
Whether you make a mistake in daily life or travel where accidents may occur, your watch may be damaged by falling from heights or suffering impacts. Equipped with rugged PANDA® Glass and wear-resistant zinc alloy body, Blackview W50 is designed to withstand drops from up to 5m.
* The above data comes from Blackview laboratory,
which may vary due to different conditions.
Knocked off the watch
on the table
Flung the watch off
while jogging
Dropped on the ground
while climbing
70
-30
Remain Operational From
-30℃ to 70℃
Working in Extreme Conditions
Blackview W50 can maintain normal operation even in extreme temperatures ranging from as high as 70 degrees or as low as -30 degrees. Whether you are in the desert or on a glacier, the W50 still stays by your side to provide time, weather and more, record your sports data, and track your health conditions.
Watch fell into a creek while hiking
30% ↑ More Robust
Structure
Withstand up to 7KG
of Pulling Force
The sturdy watch strap and case of the W50 allow it to withstand tensile forces of up to 7kg without damage. Therefore, when you are weight lifting at the gym, rock climbing, or participating in other strenuous activities, you don't need to worry about the watch getting snapped off. It will continuously and reliably record your heart rate and blood oxygen levels, becoming a powerful assistant on your adventures.
Anti-Fingerprint & Anti-Impact
Even for Sharp Objects
Thicker PANDA® Glass
Thicker PANDA ® Glass is more durable and can effectively resist scratches and accidental collisions. Occasional bumps and knocks will not have any impact on W50’s understated body. Meanwhile, the anti-fingerprint technology makes the screen less prone to fingerprints and 00smudges, keeping it clean and enhancing elegance and sophistication.
Why Choose Blackview W50?
NO.1 NO.2 NO.3 NO.4
The World's First Rugged Smart Watch High-Quality, Ultra-Stable Bluetooth Calling Tech The Largest Super-clear Display & Longest Battery Ever Smarter, More Functional, More Personalized
NO.2 HIGH-QUALITY, ULTRA-STABLE BLUETOOTH CALLING TECH Always Stay Connected
Silky-smooth Operation on your Wrist Actions ATS3085L
Blackview W50, powered by Actions Technology's ATS3085L, provides advanced features, extended battery life, and seamless connectivity while supporting dual-mode Bluetooth that separates calls from other data, resulting in smoother operation and lower power consumption.
Smoother Operation
Lower Power Consumption
Higher Frame Rate
More Stable & Clearer
Two-way Calling
All-new Upgraded
Chip-level Bluetooth
Calling Tech
W50 supports dual-mode Bluetooth technology. The classic Bluetooth is mainly used to transmit audio signals while Bluetooth low energy is more suitable for small data transmission. At the same time, by transmitting audio signals and other data separately, the W50 avoids interference between different signals, ensuring more stable and higher-quality calls throughout.
Easier to Answer & Make Calls on your Wrist Even for Emergency Assistance Higher-Quality Call Dialing & Answering
Do you find it difficult to receive phone calls when you are riding your motorcycle on a mountain road or driving on the highway? Connect W50 to your phone via Bluetooth, and with a simple tap, you can effortlessly answer or reject calls, ensuring contact in every urgent moment.
*The Bluetooth Connectivity with up to 10 Meters.
Make an emergency call when
a car accident occurs
Answer calls from lovers
when busy cooking at home
Answer calls from important clients
while taking outdoor exercise
Answer/Make calls while riding
bicycles/motorcycles/driving cars
Keep Talking without Phone Built-in Large Speaker/Microphone
Unlike ordinary watches, W50 is equipped with a large speaker and high-sensitive microphone, enabling you to make or receive calls even in noisy surroundings. Furthermore, it supports voice assistant that is capable of recognizing your voice commands, providing you with an unparalleled smart experience.
Move to the Rhythm of Music Music Control
Easily control music playback on your phone through Bluetooth connection with W50. Sweat profusely at the gym while syncing with the rhythm of your music!
NO.3 THE LARGEST SUPER-CLEAR DISPLAY
& LONGEST BATTERY EVER
See More, Do More 360x360
1.39" Super-clear
Color Display
Blackview W50 features a 1.39-inch color display with HD 360*360 resolution, providing clearer information and images for a more comfortable visual experience , while its PVD metal case delivers premium texture. No matter where you go, it stands out as the most eye-catching scenery on your wrist.
Wider 1.39" Viewing Area
1.39"
360x360 Crisp Visuals
Sharper Viewing
Even in Sunlight
Up to 550nits Brightness
Backed by W50’s display that boasts up to 550 nits brightness, whether in bright daylight or dark night environments, you can clearly and easily view the information displayed on its screen. Simply lift your wrist to check missed calls, message notifications, sports status and more, just like on a mini smartphone.
Better Endurance,
More Interaction
Ultra-long 370mAh Battery
>30 days
Typical
Use>5 days
W50 lasts longer than you can imagine. With a 370mAh mighty battery, W50 delivers enough power on a single charge to keep you entertained for days. It also comes with overcharge and overdischarge protection to prevent potential damage.
Keep up with the Fast-
paced Lifestyle
100% Charge in just 2.5hrs
It only takes 2.5 hours to fully charge the Blackview W50, which ensures that you will spend less time tethered to a charging cable and more time enjoying the full suite of functionalities that W50 offers. Keep up with your busy schedule, track your fitness goals, or stay connected with important calls and messages.
NO.4 SMARTER, MORE FUNCTIONAL,
MORE PERSONALIZED
More Convenient
& Easier Photo Taking
Shake to Control
Camera Remotely
With the Infowear APP, you can transform W50 into a remote shutter for your phone's camera, which provides unparalleled convenience for taking photos. Whether you are taking group photos or stunning selfies, there is no need to stretch your arm to touch the shutter on your phone. Just gently shake the W50 to easily capture the moment.
Timely Attention
to your Well-being
24-hour SpO2 Monitoring
Blackview W50 is capable of tracking and recording your blood oxygen levels throughout the day. For fitness enthusiasts, seniors, or those who snore at night, monitoring blood oxygen indicators can provide valuable insights into the health of your respiratory system, allowing for timely attention to your well-being.
Arrhythmia,
W50 Reports
24-hour Heart
Rate Monitoring
With the advanced HX3605 sensor, you can monitor your heart rate more accurately anytime, anywhere, and timely discover potential disease risks. At the same time, sports enthusiasts can also formulate the optimal training plan for themselves by observing their heart rate changes.
Long-distance Runners/Hikers/Heart Disease Patients/High Blood Pressure Patients/Asthma Patients/Pneumonia Patients/People Who Snore
Control Breathing Rhythm, Increase Lung Capacity Breathing Exercise
Simply activate the breathing exercise on W50, and the watch will guide you through scientific deep breathing, helping you better control the rhythm of breathing and relax your body. Especially for professional athletes, breathing exercise can also increase their lung capacity, preparing for the next high-intensity training.
Scientifically Improve
Your Sleep Quality
Deep Sleep Tracking
Blackview W50 professionally interprets the characteristics of your sleep stages by accurately monitoring deep sleep, light sleep, awake time, and other sleep phases, analyzing your sleep quality to help you develop a better sleep habit.
Burn Your Calories! Pedometer
Always reluctant to exercise and sit all afternoon? A pedometer can record your daily walks and runs and calculate how many calories you burn. It continuously motivates you to carry out daily activities, fosters a healthy lifestyle, and helps you achieve your daily fitness goals.
Satisfy the Need
for Any Sport
100+ Workout Modes
Life can definitely be healthier with sports, but Blackview W50 makes your life much healthier by keeping track of your exercise. With 100+ workout modes like badminton, fitness walking and more, W50 informs you of your running or jumping metrics or more detailed exercise data each time you train for a better body.
Today's Outfit?
At-a-glance
Intuitive Weather Widget
Get four-day forecasts right at your wrist with W50, allowing you to plan attire and activities with ease. Say goodbye to weather surprises and hello to better planning.
Women's
Health Matters
Women's Special Day Alert
Blackview W50 cares for women's health by offering special alerts in case you are too busy dealing with daily routines to remember it’s your special day and you need to take care of yourself with more attention.
Menstrual period
Safe Period
Ovulatory period
Check Crucial Messages Promptly Message Notification
W50 ingeniously incorporates message notification features, ensuring you seamlessly capture communication signals from vital contacts anytime, anywhere. Respond promptly to cherished familial messages or pivotal clients, leaving no room for regrets.
More Convenient Alerts
Event
Reminder
Drinking Water
Reminder
Hand Washing
Reminder
Sedentary
Reminder
Customized Watch Menus
Different Styles of UI
Blackview W50 is paired with a highly personalized UI. Go choose from the six-square division interface and the minimalist list-like UI. You can always find what suits your style.
Feel Free to Switch Your Personality 100+ Multifarious Watch Faces
Blackview W50 comes with 5 exquisite built-in watch faces, and after effortlessly connecting to the app, you can freely download up to 100+ watch faces in any style. Customize your watch to your heart's content and make it as cool as you desire.
Shine on Every
Occasion
5+ Fashion Styles
W50 offers black, green, and khaki three different stylish color options for you. Besides, according to the color you choose, it comes with extra black or green woven straps, meeting your needs for unique fashionable matches in daily life or sports scenes.
Know Your Language 16-language Support
Blackview W50 offers you more ways to localize itself with 16-language support. Whether you are an Italian or a Portuguese speaker, W50 will adjust itself to keep up with you more effortlessly.
Support Languages including: English, Chinese, Traditional Chinese, German, French, Italian, Spanish, Portuguese, Russian, Arabic, Turkish, Hebrew, Indonesian, Thai, Malay, Bulgarian
Other Helpful Tools Little Helpers All along the Journey
Stopwatch Time your training programs or outdoor exercise.
Timer Set a timer before you start baking, training etc.
Wake up the Screen by Raising Your Hand Raise your hand and you get a woken-up screen already.
243mm
47.5mm
14.5mm
243mm
Blackview W50
Dimension
Weight
Color
CPU
Screen Size
Resolution
Battery
Bluetooth
47.5*14.5 mm(Diameter*Thickness)
56g
Black watch + Black strap
Green watch+ Green strap
Khaki watch+ Khaki strap
Actions ATS3085L
1.39-inch
360*360
370mAh
Typical Use > 5 days Standby > 30 days
Ver 5.3
Language
W50
Calling Smartwatch
NO.1 NO.2 NO.3 NO.4
& Cosmetics-
resistant
30% More Robust
Structure
Withstand up to 7KG
of Pulling Force
Water and Dust
Won't Stop Us
Sweating in the gym
Splash-proof when
washing hands
Drop-proofness
on the table
Flung the watch off
while jogging
while climbing
-30℃ to 70℃
70
-30
Smoother Operation
Higher Frame Rate
Two-way Calling
All-new Upgraded
Calling Tech
1.39" Super-clear
Color Display
Wider 1.39" Viewing Area 360x360 Crisp Visuals
1.39"
Sharper Viewing
Even in Sunlight
>30 days
Typical
Use>5 days
Better Endurance,
More Interaction
paced Lifestyle
MORE PERSONALIZED
More Convenient
Shake to Control
Camera Remotely
Timely Attention
to your Well-being
Arrhythmia,
W50 Reports
24-hour Heart
Rate Monitoring
Your Sleep Quality
Deep Sleep Tracking
Satisfy the Need
for Any Sport
100+ Workout Modes
Today's Outfit?
At-a-glance
Women's
Health Matters
Menstrual period
Safe Period
Ovulatory period
Event
Reminder
Drinking Water
Reminder
Hand Washing
Reminder
Sedentary
Reminder
Shine on Every
Occasion
5+ Fashion Styles
243mm
47.5mm
14.5mm
243mm
Blackview W50
Dimension
Weight
Color
CPU
Screen Size
Resolution
Battery
Bluetooth
56g
Actions ATS3085L
1.39-inch
360*360
370mAh
Ver 5.3
Language
