Is the Blackview XPLORE X1 a 5G Rugged Phone?
Yes. The Blackview XPLORE X1 is a 5G rugged smartphone powered by the MediaTek Dimensity 7050 processor. Not only does it support 5G mobile networks and Wi-Fi 6, but it can also be used for calls, mobile data, navigation, video, online applications, and everyday tasks, whilst offering the protection one would expect from a rugged smartphone. The XPLORE X1 also boasts IP68 and IP69K protection ratings, as well as compliance with the MIL-STD-810H ruggedness standard. It is suitable for those who frequently engage in outdoor activities, travel often, or use their phone in environments where it may be exposed to rain, dust, or accidental drops. In everyday life, it can be used just like a standard smartphone.
Does the Blackview XPLORE X1 Rugged Phone Have Night Vision?
Yes. The Blackview XPLORE X1 is equipped with a 20-megapixel night vision camera and a 108-megapixel main rear camera. The night vision camera can be used in conditions where there is very little visible light, or when a standard camera cannot capture further detail. It also offers an alternative shooting option when standard night-time photography does not meet your needs. It can be used to check the surroundings of a campsite, observe nearby objects after dark, carry out night-time patrols, or document conditions in poorly lit work areas. Furthermore, it can assist with inspecting equipment, footpaths, or the surrounding environment at night without the need for an external light source.
Can the Blackview XPLORE X1 Rugged Phone Take Photos Underwater?
Yes. The Blackview XPLORE X1 supports underwater photography; it has IP68 and IP69K protection ratings and can operate continuously at a depth of 2 metres for 30 minutes. It can therefore be used in suitable underwater scenarios. The underwater photography function can be used when the touchscreen does not operate normally whilst submerged. It can also be used in scenarios such as swimming pools, shallow water or outdoor water activities; however, you must adhere to the rated water resistance limits and ensure the phone is undamaged before submerging it. Furthermore, you should avoid contact with salt water or hot water, as well as prolonged immersion in water.
What Can the Blackview XPLORE X1 Secondary Screen Be Used For?
The Blackview XPLORE X1 is equipped with a 2.01-inch rear secondary screen that displays information such as the time, date, notifications, and compass data, so you don’t have to open the main screen every time. It offers a quicker way to view basic information without having to constantly turn the phone over or unlock it. When out hiking or working outdoors, you can quickly check the time, see if you have any new notifications, or consult the compass. It is equally useful when the phone is placed face-down on a table or nearby surface, and you need to glance at essential information.
Does the Blackview XPLORE X1 Rugged Phone Support GPS Navigation?
Yes. The Blackview XPLORE X1 supports GPS, GLONASS, BeiDou, Galileo and QZSS, as well as the L1 and L5 positioning systems. Consequently, when using compatible map and navigation apps, it can access multiple satellite navigation systems, rather than relying on a single one. It can also be used for driving, hiking, travelling, working in the field or visiting unfamiliar locations. For users who frequently work outdoors, the navigation function can help locate work sites, navigate between different locations along a route, or confirm one’s position whilst moving through unfamiliar areas. Of course, offline maps can also be helpful when travelling in areas with weak mobile signal.
Can the Blackview XPLORE X1 Rugged Phone Be Used with Gloves?
Yes. The Blackview XPLORE X1 supports ‘Glove Mode 2.0’, which makes touchscreen operation more convenient when wearing compatible gloves. This feature comes in handy when you need to keep your gloves on whilst working, in cold weather or during outdoor activities. People such as construction workers, outdoor workers, hikers or those using their phones in winter can check maps, open apps, take photos or adjust settings without having to take their gloves off frequently. It makes everyday phone use much more convenient when you need to wear gloves for extended periods.
Does the Blackview XPLORE X1 Rugged Phone Support an Infrared Remote Control?
Yes. The Blackview XPLORE X1 features infrared remote control functionality and can control compatible infrared devices. It can be used as an additional remote control without the need to purchase any extra accessories. It works with compatible televisions, air conditioning units and other domestic or office equipment. This feature is particularly useful when the original remote control is not to hand, has been lost, or when you wish to control multiple infrared devices using a single mobile phone. It is also extremely convenient when travelling or in situations where multiple remote controls are required.
How Much Storage Does the Blackview XPLORE X1 Rugged Phone Have?
The Blackview XPLORE X1 is available in two configurations: 12GB RAM + 256GB storage and 16GB RAM + 512GB storage. It also supports TF cards of up to 2TB, allowing users to expand their storage capacity as required. This provides ample space for storing large files without the need for frequent storage management. If you like to store large numbers of photos, videos, offline maps, work files or apps on your mobile, it provides ample storage space. Furthermore, when working or travelling in the wild where network connectivity is limited, important documents, maps, photos and videos remain readily accessible at all times.
Can the Blackview XPLORE X1 Rugged Phone Be Used for Outdoor Photography?
Yes. The Blackview XPLORE X1 is equipped with a 108-megapixel main camera, a 20-megapixel night vision camera and a 50-megapixel front-facing camera, offering a wide range of options for outdoor photography and videography. Use the 108-megapixel main camera when you need greater image detail; for night-time shots, opt for the night vision camera. It is also suitable for use whilst hiking, camping, travelling, landscape photography, documenting outdoor activities, or capturing scenes along the way. Furthermore, its rugged and durable body provides rain and dust protection and can withstand rough trails and rugged terrain, so there is no need to handle it with excessive care.
Can the Blackview XPLORE X1 Rugged Phone Be Used for Fieldwork?
Yes. The Blackview XPLORE X1 is suitable for fieldwork where users require communication, navigation, photography, maps, documents, and everyday apps. Its 5G connectivity, rugged protection, 10,000mAh battery, GPS support, and glove mode are all highly practical features. Field staff can also use this phone to navigate to specific locations, take photographs of equipment or site conditions, consult documents, take notes, and stay in touch with colleagues. It can also store offline files and maps for use in areas with limited network coverage, as well as handle the day-to-day tasks required during fieldwork.
Can the Blackview XPLORE X1 Rugged Phone Be Used for Worksite Inspections?
Yes. The Blackview XPLORE X1 can be used for basic site inspection tasks, such as taking photographs, recording videos, confirming locations, viewing documents and documenting on-site conditions. The 108-megapixel main camera also helps capture details that may need to be verified at a later date, such as equipment labels, damaged areas or construction progress. The 20-megapixel night vision camera is designed for use in low-light conditions, whilst the IP68, IP69K and MIL-STD-810H protection ratings safeguard the device against dust, rain and harsh working environments. Users can save photos and videos as records to compare site conditions at different points in time, or share information with colleagues once the inspection is complete.
Is the Blackview XPLORE X1 Rugged Phone Easy to Carry Outdoors?
The Blackview XPLORE X1 is 18 millimetres thick and weighs 420 grams, making it slimmer and lighter than other rugged mobile phones with larger batteries and thicker bodies. It is equipped with a 10,000mAh battery, which not only maintains a high capacity but also makes it easier to carry. Its dimensions make it easier to carry whilst hiking, travelling, working in the field, or during any activity where you need to carry your mobile for several hours. Compared to large rugged mobiles with 20,000mAh batteries, it takes up less space in a bag or pocket and is more comfortable to hold for extended periods.
Can the Blackview XPLORE X1 Rugged Phone Handle Rain and Dust?
Yes. The Blackview XPLORE X1 has IP68 and IP69K protection ratings and complies with the MIL-STD-810H ruggedness standard, making it resistant to water, dust, drops and harsh environments. This makes it suitable for use in more demanding conditions. Whether you’re hiking in the rain, on a dusty building site, along muddy trails or carrying out outdoor maintenance work, you can use it with confidence. However, you should ensure the phone is used within its rated operating limits, as prolonged use, damaged seals or physical damage may reduce its protection over time.
Why Choose the Blackview XPLORE X1 Rugged Phone for Outdoor Use?
The Blackview XPLORE X1 combines 5G capability, a 10,000mAh battery, GPS navigation, night vision, IP68/IP69K protection ratings and a glove mode, whilst weighing just 420g. These features fully meet users’ needs for extended outdoor activities, whilst avoiding the bulkiness often associated with high-capacity rugged models. For instance, GPS assists with route navigation, the night vision function is useful after dark, the rugged body effectively resists water and dust ingress, and the 10,000mAh battery supports longer periods of offline use. The slimmer design also makes it easier to carry whilst hiking, camping, travelling or working outdoors, making it an ideal choice particularly for those who want robust protection but prefer not to opt for a heavy model.
What Is the Difference Between the Blackview XPLORE X1 and XPLORE 1 Rugged Phones?
The Blackview XPLORE X1 and XPLORE 1 share several key features, including a 6.78-inch 120Hz display, a 2.01-inch secondary screen, a Dimensity 7050 processor, 5G support, a 20-megapixel night vision camera, and rugged protection. The main differences lie in battery capacity, the main camera, the thickness of the body, and the weight. The XPLORE X1 is equipped with a 10,000mAh battery and a 108MP main camera; It is 18mm thick and weighs 420g. The XPLORE 1, on the other hand, features a 20,000mAh battery and a 64MP main camera; It is 29.5mm thick and weighs 638g. The XPLORE X1 is better suited to users who want a rugged mobile phone that is slimmer, lighter, and has a higher-resolution main camera. The XPLORE 1 is better suited to users who prioritise battery capacity and are willing to carry a larger, heavier device. If you frequently go hiking, travel, or carry your phone with you on a daily basis, the XPLORE X1 is the most suitable choice, whereas the XPLORE 1 is better suited to those who need to go without a power source for extended periods.
Who Is the Blackview XPLORE X1 Rugged Phone Best For?
The Blackview XPLORE X1 is ideal for hikers, campers, travellers, field workers, construction workers, outdoor photographers, and users who want rugged protection without having to carry a bulky rugged mobile phone. Its 5G connectivity, night vision, GPS navigation, dual-screen design, high-capacity battery, and rugged protection meet both everyday needs and outdoor requirements. It is also particularly well-suited to users who value durability and portability. With a body thickness of 18 millimetres and a weight of 420 grams, it is easier to carry than larger rugged smartphones, whilst its 10,000mAh battery capacity is sufficient for extended outdoor trips, working days and everyday use.
