Blackview Table 9 16" FHD Low Blue Light Certified Portable Monitor w/ Built-in Speaker & Full Functional USB Type C+Mini HDMI Input
Available in stock (21)
✔16 inch FHD IPS 16:10 1920*1200 Pixels
✔TÜV SÜD Low Blue Light Certified
✔360°Rotatable Mag-Spin Stand &Pocket-Ready Kickstand
✔Dual Full Functional USB Type C & One Mini HDMI Port
Light on the Go. Gentle on the Eyes
Find the Perfect Angle—In Life and On Your Screen
16-Inch FHD Eye-Comfort Display
Enjoy Clear, Vibrant Visuals with Reduced Eye Strain
16-inch FHD Immersive Display
Sharper. Clear. More Vivid
Portable, yet uncompromising. Enjoy display quality rivaling professional monitors, with vibrant colors and exceptional contrast. Your content looks flawless, wherever you take it.
1920 * 1200
Sharp Resolution
Sharp Resolution
178°Viewing Angle
300nits
Balanced Brightness
16:10 Golden Productive Aspect Ratio
Wider View, Better Efficiency
Enjoy the perfect balance of width and height with the 16:10 aspect ratio. More vertical space means better layouts, less scrolling, and a smoother, more immersive workflow for designers, editors, and multitaskers alike.
Protect Your Eyes, Enjoy the View
Game, stream, or work for hours without your eyes paying the price. Table 9’s eye-comfort screen keeps visuals crisp and your eyes relaxed, so you can focus on the action, not the strain.
Built-in Speaker
Crystal-Clear Calls and Music Anywhere
Take your screen anywhere without extra bulky speakers. Compact, lightweight, and hassle-free—whether gaming, streaming movies, or joining a call, your entertainment is always ready, no extra setup required.
Fully Adjustable to Fit Your Style
Effortlessly Tailor Your Brightness, Contrast ,Color And Layout
Free Screen Customization
Smart Display, Smarter Work
Effortlessly enhance your workflow with flexible displays and intuitive controls, enabling smoother multitasking, personalized viewing, and a more productive, comfortable, and efficient workspace for every task and scenario.
Volume
Brightness
Color Temperature
Contrast
PPT + Video Calls
Working Efficiency Doubled
Stocking + Analysis
Trading Efficiency Doubled
Coding + Debugging
Output Doubled
Movie on a Bigger Display
Viewing Immersion Doubled
Powerful Display, Feather-Light Body
650g Light, 13.2 mm-Slim, Engineered for Mobility
Redefine the Portability
Double Your Screen Anytime Anywhere
Redefine portability with a screen designed for life on the move. Slim, lightweight, and instantly ready, it lets you double your workspace anywhere—at the office, in a café, or on the road—without adding bulk or slowing you down.
13.2mm
650g
Refined Aesthetics. Solid Build.
Premium to Touch, Strong to Hold
With a refined, Kevlar-textured durable body, Table 9 feels premium and tech-forward. The foldable stand doubles as a protective armor for the screen, keeping it safe on the go. Slip it into your bag and enjoy gaming, work, or streaming anywhere.
Air/Train Travel
Office
Café
Library
Enjoy Posture Freedom in Any Space
Extendable Mag-Spin Stand
Any Height. Any Angle. Total Freedom.
Experience ultimate flexibility with Blackview’s exclusive Mag-Spin Stand. Easily attach it magnetically, adjust height up to 90mm, and rotate it 360° freely. Space-saving, flexible, and effortless—perfect for professionals, gamers, and creators alike.
90mm Extension Travel
Rotate at Full 360°
Double Your View without Doubling Your Desk
Work smarter, stay organized, and make every inch count.
Pocket-Ready Slim Kickstand
Tiny Stand, Big Freedom
Small, portable, and powerful. Snap the Slim Kickstand on, rotate between landscape or portrait, adjust the angle from 0 to 90°, and rely on strong magnetic stability—flexible viewing made effortless.
Switch Effortlessly Between
Landscape & Portrait Mode
Smooth Tilt from 0–90°for
the Perfect Viewing Angle
Snap on or remove easily with stable, secure Magnetic hold
Seamless Plug-And-Play Connection
One Plug, Instant Display. No Drivers, No Delays.
Easy Connection
Simple Plug for a Second Display
Forget tangled cables and complicated setups. With just a single plug, your second screen comes to life instantly. Expand your workspace, stream content, or game on a bigger display without any hassle.
Connect Without Limits. Work Without Boundaries.
* All the Cables Mentioned above are included in the package.
100W Reverse Charge
Where Work Goes, Power Follows
Running low power but every port is taken? Once the Table 9 is plugged into external power, its 100W reverse charging keeps your laptop alive through the same cable—no extra charger to juggle, no ports to rearrange.
* Reverse charging works only when the portable
screen is connected to an external power source.
Wide Device & OS Compatibility
Enjoy Smooth, Reliable Performance Across All Your Devices
Seamless Work with All Your Devices
One Screen for Work, Create and Play
Whether it’s a laptop in the office, a desktop at home, or a tablet on the move, enjoy smooth, reliable connectivity. No adapters, no interruptions—just seamless performance across your tech ecosystem.
Compatible with All Mainstream Systems
No Setup, Just Plug and Play
Mac, Windows, Android, Linux, ChromeOS—Table 9 speaks them all. Seamless recognition, instant display, zero configuration. Wherever you work, it works with you.
Blackview Table 9 Specification
| Model | Table 9 |
| Color | Black |
| Material | Aluminum+PC+ABS |
| Display | 16" IPS, 1920x1200 Resolution, 60Hz Refresh Rate, 300 nits Brightness, 62% sRGB, 16:10 Aspect Ratio |
| Ports | 2 × USB - C (Full - Featured, USB3.1, DP Alt Mode, PD3.0 20V/5A MAX ) 1 × Mini HDMI |
| Speaker | Single Box Speaker |
| Weight | 1.27kg(With Stand)、650g(Without Stand) |
| Size | 368 * 237 * 29.5mm(With Stand)、360.7 * 235.7 * 13.2mm (Without Stand) |
