Note:
This tablet's 4G network connection can only work in Europe and Asia area, please pay attention before purchasing or consult us.
Blackview Tab 13
Instant Productivity,
Endless Entertainment
Blackview Tab 13 supports the RAM expansion of up to 4GB, TÜV Rheinland low blue light certification, PC mode, SIMO Internet, up to 1080 hours of battery standby, and up to 1TB TF storage for unmatched work and play.
  • 6GB RAM +up to 4GB Expansion =10GB
    RAM Fast 27% Faster Start-up
  • MediaTek Helio G85
    AnTuTu 256691
  • TÜV Rheinland Low Blue
    Light Certification
  • 128GB ROM + up to 1TB TF
    Dual Slots for SIM/TF Cards
  • Functional
    SIMO Internet
    Your solution anytime, anywhere
  • Up to 1080 hrs of Standby
  • 10.1-inch FHD+ Display
    Tempered Membrane
    + Protective Case
  • Doke OS_P 3.0, Android 12
    • Design
    • Convenience
    • Smoothness
  • PC Mode with
    Keyboard Supported
  • Dual Smart PA
    BOX Speakers
  • Sleek, Slim, Portable
  • Tab 13 ticks all the boxes for design aesthetics. Every detail, from the refined matte finish coated on a durable aluminum alloy back panel to the modish flattened frame, presents a never-out-dated minimalist, elegant style. Measured 7.7mm slim and 450g light, its portability reaches max.
Why to Choose
Blackview Tab 13?
  • Efficiency
    Upgrade
  • Safety
    Upgrade
  • Entertainment
    Upgrade
  • Convenience
    Upgrade
Higher Efficiency
for Everyday Tasks
    27% Faster Start-up
    AnTuTu 256691
  • Smart Pre-Loading
  • Refined Animation
  • Cold Room
6GB RAM + up to 4GB Expansion=10GB
Heavy-duty
Multitasking Made Easy
The new RAM expansion technology extending the 6GB of LPDDR4X RAM to up to 10GB endows Tab 13 with strong prowess in effortlessly launching RAM-intensive, large-scale hot games, running more apps simultaneously in the background, and switching different tasks.
MediaTek Helio G85
Drive Gaming to Fuller Potential
MediaTek Helio G85 pumps its Arm Mali-G52 GPU up to a 1GHz peak, blasting performance for avid gamers. Built-in MediaTek HyperEngine technology helps run heavy-loading games more fluidly and responsively with reliable connections and true-to-life visuals.
  • 12nm
    FinFET Process
  • 2*Arm Cortex-A75 @ 2GHz
    6*Arm Cortex-A55 @ 1.8GHz
  • Max 1GHz Frequency
    Arm Mali-G52 MC2
    Enough Space for
    All Memories
    Up to 128GB of eMMC 5.1 internal storage and 1TB of external storage give ample room for a bulk of valuable multimedia files to have everything right at your fingertips and blow through your pleasure anytime.
    • 25%
      Faster data
      transmission
    • 28%
      Less power
      consumption
    • 31%
      Larger storage
      space
OS Enhancements Featuring in Efficiency
  • Smart Pre-Loading
    By learning users’ app-opening patterns, Doke OS_P 3.0 foresees which apps you’ll launch and help preload your apps before you open them, improving the average app-launching speed by 7%.
  • Refined Animation
    Doke OS_P 3.0 witnesses faster and smoother animation of screenshots and all types of floating windows. Always be in sync with you without latency.
  • Cold Room
    Doke OS_P 3.0 introduces the all-new Cold Room freezing the third-party rogue apps with one click to prevent them from background self startup and save battery and running memory.
Enhanced Protection for
Eyes, Tablet, and Data
  • TÜV Rheinland Low
    Blue Light Certification
  • Android 12
    (Privacy Dashboard +
    Location Permissions)
  • Tempered Membrane
  • Face Unlock
  • Dark Mode
  • Reading Mode
  • Free Protective
    TPU Case
TÜV Rheinland Low Blue Light Certified
A screen that’s Easier
on the Eyes than ever
Tab 13 is the first-ever Blackview tablet that obtains the TÜV Rheinland Low Blue Light certification to help reduce blue light, cause less eye strain, and reduce irreversible harm to eyes in a dim-lit environment or in long-time viewing. Combined with Dark Mode and Reading Mode, it bring out the best reading comfort and readability in any lighting.
    • TÜV Rheinland Low
    • 3-darkness-level Dark Mode
    • Reading Mode
    *Note: Please activate the Eye-protection mode to make effect the blue light filtration.
Accessories that
Reinforce the Protection
Tempered Membrane + Protective Case
Protection from
Front to Back
Sometimes, it’s unavoidable that the tablet drops down and breaks. To protect Tab 13 from drops, falls, or screen cracks, it’s packed with a piece of reinforced tempered membrane and protective TPU case which will give double guarantee of your tablet safety.
  • Protective Case
  • Tempered Membrane
Privacy Protection
  • You’re Always
    in Control
    Android 12 is designed for your safety. With new easy-to-use, powerful privacy features, you’ll have peace of mind knowing that you have control over who can see your data and when.
  • Privacy
    Dashboard
    Your privacy permissions at a glance over the past 24 hours
  • Approximate Location Permissions
    Giving apps access to your precise location or an approximate location
  • Fast & Secure
    Face Unlock
    The selfie camera maps out your face in great detail and enables you to access the tablet within a second, faster than typing in password numbers.
Go for the Unmatched
Recreation Fun
  • Dual Smart PA
    BOX Speakers
  • Mobile Wi-Fi Supported
    (No SIM Cards or Wi-Fi;
    Affordable Data Plans)
  • Faster Speed
    27% Faster Start-up
10.1-inch
FHD+ Display
See Greatness on an Incredible Panel
From the moment you light the screen up, the 10.1-inch expansive FHD+ display delivering wide viewing angles, fine color reproduction, and vivid details will amaze you.
  • 10.1-inch
    Screen Size
  • 16:10
    Aspect Ratio
  • 1200*1920
    FHD+ Resolution
  • 300 nits
    Brightness
  • 81%
    Screen-to- body Ratio
  • LCD IPS
    Panel Type
  • In-cell
    Thinner & Lighter
  • 224
    PPI
Dual Smart PA
BOX Speakers
Revel in the
Stunning Sound
Enliven your ears with the impressive, well-tuned, and clear sound produced by the dual Smart PA-supported BOX speakers without distortion and whip you into extreme excitement and thrill when gaming, listening to grand symphonies, and watching movies.
Keep Powered up Longer
7280mAh Battery
The enormous-pack 7280mAh battery that pumps out juices way beyond a day provides a killer solution to low battery anxiety. Never will it slide into power-off earlier at a crunch moment and mess up your recreation merriness or devotion to work and study.
  • Game
    5.5 hrs
  • Video
    5.5 hrs
  • Web
    6.4 hrs
  • Music
    16 hrs
  • Calling
    30 hrs
  • Standby
    1080 hrs
Blackview Tab 13 x SIMO Internet
No Wi-Fi? Try SIMO!
Work, play and chat anywhere
Start your free trial by
turning on SIMO Internet!
With SIMO, you don’t need to purchase a SIM card to access the Internet. SIMO keeps you connected when Wi-Fi is not available or usable.
Blackview has partnered with SIMO, leading global mobile Wi-Fi provider who has provided mobile connectivity to more than a million customers around the world over the last 10 years.
Global Coverage
SIMO provides global mobile Internet access in more than 135 countries
Affordable
No hidden fees. SIMO Internet gets you connected for as low as €1! (see note 4)
On-demand
No contract, on-demand, flexible data plans for every need
Convenient
Subscribe directly from Tab 13. No physical SIM cards needed
Reliable
Our mission is to not only offer multiple carriers in your country, but also to help you find the best one
Connect Multiple Devices
Work as a hotspot to keep more than one devices online
24/7 Support
Regardless of the carrier connection, SIMO support team is always available to help via LiveChat.
Note:
1. When used for the first time, users should connect to Wi-Fi to complete the SIMO registration.
2. While SIMO coverage is available in 135+ countries, SIMO is only available for consumers registering from EU countries, U.K., U.S.A., Mexico, Canada, and Japan. SIMO is always working to expand the list of countries from which its service is available to register.
3. When SIMO connection is started, voice, SMS, and data from the SIM1 Card will be disabled until SIMO is stopped. When connecting to external Wi-Fi, the connection will automatically switch to Wi-Fi and SIMO will disconnect.
4. This may vary based on your country of registration. €1 price is defined as a 1 Hour Unlimited data plan when purchasing a pack of 10 from EU. SIMO prices are subject to change from time to time.
Max out the Convenience to Fuel
Your Productivity and Creativity
  • PC Mode
  • Game Mode
  • Versatile Desktop
  • Smart Floating
    Windows
  • 3-finger Screenshot
  • Split Screen View
  • The Upgraded
    Notebook
PC Mode
Work Wonders without a Laptop or Desktop
Put your tablet to its full potential by supporting the PC Mode which transforms the display into a familiar laptop-style interface in one tap while you can touch the screen to operate. Combined with the keyboard connection support, work smarter and easier as you were on a computer.
  • Take class notes
  • Edit business documents/sheets/PPT
  • Have an online conference
  • PC Mode
OS Enhancements
Featuring in Convenience
Game Mode
Game on,
Stay Immersive
You can not only set up to block notifications and calls for immersive gameplay by toggling on the Diving Mode but clean up RAM to spare more running space for smoothness. All help you stay ahead of the curve in gameplay.
Ready for Revolution?
Versatile Desktop
Doke OS_P 3.0 renders all the magic tricks that amuse you and save your time. You can install apps, dismiss folders, lock the layout, and customize your themes, wallpapers, or icons with a breeze.
More Convenient
Smart Floating Windows
Keep Your
Apps on Tap
Swipe up, down, right or left or try more gestures to navigate Doke OS_P 3.0 that facilitates your control with convenient floating windows.
  • Swipe Left or Right for Smart Sidebar Customized the Sidebar with often-used apps
  • Swipe Down for Control Panel Take screenshot, switch Wi-Fi, record screen, activate PC mode, etc
  • Swipe Right for Minus One Screen Organize Important Information all in one space
More OS Features for
Convenient Operation
    Choose Three Point Screenshot mode and slide down with three fingers to take a screenshot on which you can make a long screenshot, edit with scribbles and mosaic, and share.
  • The Upgraded Notebook
    Write down what you think, probably your whimsical thoughts, creative scribble, or to-do lists with texts, audio, and images on the Notebook.
  • Split Screen View
    With the Split Screen mode, you can read through documents or binge-watch videos while messaging your friends on just a single tablet.
Other Highlights that
Shine in Work & Play
8MP + 13MP
Gorgeous in Every Take
Tab 13 is given the photography smarts to capture fabulous portraits and scenes. The 8MP selfie sensor, backed by the Beauty algorithm, brings out the full splendor of your face, while the 13MP back camera nails zingy photos of every memorable moment at the click of the shutter.
  • Pro Mode
  • Mono Mode
  • Dual Slots for SIM/TF Cards
    Tab 13 features dual card slots. You can insert two SIM 4G SIM cards to get full internet access or insert one SIM and one TF card of up to 1TB to expand the storage space.
  • GPS & Beidou & Glonass & Galileo
    Whether you’re driving, hiking, or just traveling across the country, Tab 13’s high-precision quad navigation system offers a better route to your destination.
Power button
Volume +/-
External
keyboard interface
13MP + 0.3MP
Dual BOX Speakers
Charging port
Dual 4G LTE
8MP Samsung® S5K4H7
  • Model
    Tab 13
  • Colors
    Lunar Silver/Twilight Blue/Space Gray
  • Dimension
    238.8*157.6*7.7mm
  • Weight
    450g
  • Display
    10.1-inch 1200*1920 FHD+ IPS 81% Screen-to-body Ratio
  • CPU
    MediaTek Helio G85, Cortex-A75 @ 2GHz*2,Cortex-A55 @ 1.8GHz*6
  • RAM & ROM
    6GB + 128GB, LPDDR4X + eMMC 5.1
  • SIM Slot
    Dual SIM; Two Nano Card or Nano Card + TF Card
  • Max TF Card Capacity
    1TB
  • Front Camera
    8MP Samsung® S5K4H7
  • Rear Camera
    13MP + 0.3MP
  • Battery Capacity
    7280mAh
  • Speaker
    1217 2PCS BOX Speakers
  • Wi-Fi
    802.11a/b/g/n/ac
  • Connectivity
    3G Bands: WCDMA: B1//B8
    4G Bands: TDD: B40 FDD: B1/B3/B7/B8/B20
  • Navigation
    GPS/Beidou/Glonass/Galileo
  • OS
    Doke OS_P 3.0 based on Android 12
