Blackview Tab 7 Wifi 10.1" 3GB RAM 64GB ROM 6580mAh Wi-Fi Version Tablet PC
Tab 7 Go for Stunning Visuals and Productivity Wi-Fi Connection 2.4G 3GB RAM + up to 2GB Expansion 10.1-inch HD+ Display...
Tab 7
Wi-Fi Connection
2.4G
79% Screen-to-body Ratio
64GB ROM + Up to
1TB TF Expansion
Dual BOX Speakers
with Smart PA
2MP + 5MP
Cameras
6580mAh
Battery
Doke OS Go 3.0
Android 12GO
Quad-core
RK3326S
A Look to Impress
Feel the giddy delight when you take hold of the Tab 7 WiFi characterized by silky touch and paper-like slim body with refined matte finish and trendy mcro-curved edges. This is a truly premium design but cuts out all the frills, leaving only the essentials to amp up your life.
9.9mm
Slim
520.5g
Light
Refresh Your Visual World
Tab 7 WiFi transforms the way you view the world with a punchy and pixel-dense display that unfolds stunningly right in front of your eyes and generates a new realm of life-like graphics, bold colors, and smoother gradients to awaken your senses and invigorate your body and mind.
10.1-inch
Expansive Size
800*1280
Resolution
79%
Screen to Body Ratio
16:10
Aspect Ratio
Quad-core Rockchip RK3326S
Power for Better Efficiency and Smoothness
From responsive app-launching through smooth video streaming to seamless light-duty multitasking, the Rockchip RK3326S nails them all without a sweat. Get your basic daily entertainment needs perfectly satisfied.
CPU
4*Cortex-A35 up to 1.5GHz
GPU
Mali-G31MP2 GPU
69381
AnTuTu
3GB
LPDDR3 RAM
64GB
eMMC 5.1 ROM
1TB
TF Expansion
3GB RAM + Up to 2GB Expansion
Include More without Cost
To further expand running memory without extra cost, Tab 7 WiFi provides the new Memory Expansion Technology that extends the 3GB RAM to up to 5GB, giving you an edge to open more apps simultaneously and switch between different apps with ultra-smoothness.
6580mAh Mega Battery
Keep on All Day & All Night
Ultra-lasting 6580mAh battery is ready all the time for you to get through intense work days, juice-consuming online classes, or conferences on the go. Tab 7 WiFi promises longer and more reliable company day in or day out.
Video
5 hrs
Music
15 hrs
Game
4.5 hrs
Web
6 hrs
312 hrs
Dual Box Speakers with Smart PA
As If in a Live Concert
Tuned by skillful technicians, the dual box speakers with Smart PA enable you to indulge in a powerful sound wave that reproduces ultra-rich acoustic details and broad soundscape from transparent treble to deep bass.
2MP Front + 5MP Rear
Click All the Unforgettable Moments
From perfect selfies at home to interesting groupfies in a long-expecting reunion, Tab 7 WiFi always brings endless shutter joy and takes your photography up a notch.
5MP
2MP
Doke OS Go 3.0 Based on Android 12
Dare to Make A Difference
Swipe up, down, right or left or try more gestures to navigate Doke OS Go 3.0 that facilitates your control over Blackview Tab 7 Wifi. Designed for further convenient interaction without undergoing complex processes.
Swipe Down for Control Panel
- A Tap to Take Screenshot and Switch between Ring/Mute
- Drop-down Menu
Press Volume Button for Pop-up Window on the Right
- Shortcut for Sound Adjustment of Media, Alarms and Notifications
- Quick Access to Sound Setting
Auto Pop-up
- Low Battery, High Volume and USB Connection
Refined Animation
Doke OS GO 3.0 witnesses faster and smoother animation of screenshots and all types of floating windows. Always be in sync with you without latency.
Screen Mode
Tab 7 Wifi is designed to ease your learning or working process by providing Dark Theme for better protection of your eyesight and significant reduction of eyestrain at low-lit environments
Twilight Blue
Space Gray
Blackview Tab 7 WiFi
ModelTab 7 WiFi
ColorsTwilight Blue, Space Gray
Dimension246.5*163*9.9mm
Weight520.5g
Display10.1-inch 800*1280 HD+ IPS
79% Screen-to-body Ratio -
CPURockchip RK3326S
RAM & ROM3GB + 64GB, LPDDR3 + eMMC 5.1
RAM ExpansionUp to 2GB
Max TF Card Capacity1TB
Card SlotOne TF Card Slot
Cameras2MP Front + 5MP Rear
Battery6580mAh; 10W Charge
Speaker1217 2PCS BOX Speakers with Smart PA
Wi-Fi802.11a/b/g/n
OSDoke OS Go 3.0 Based on Android 12
Power button
3.5mm headphone jack
TF card slot
Type-C charging port
Volume +/-
2MP front camera
5MP rear camera
Speaker
