Tab 7
Go for Stunning Visuals and Productivity
  • Wi-Fi Connection
    2.4G
    3GB RAM + up to 2GB Expansion
  • 10.1-inch HD+ Display
    79% Screen-to-body Ratio
    64GB ROM + Up to
    1TB TF Expansion
  • Dual BOX Speakers
    with Smart PA
    2MP + 5MP
    Cameras
    6580mAh
    Battery
    Doke OS Go 3.0
    Android 12GO
    Quad-core
    RK3326S
A Look to Impress
Feel the giddy delight when you take hold of the Tab 7 WiFi characterized by silky touch and paper-like slim body with refined matte finish and trendy mcro-curved edges. This is a truly premium design but cuts out all the frills, leaving only the essentials to amp up your life.
  • 9.9mm
    Slim
  • 520.5g
    Light
Refresh Your Visual World
Tab 7 WiFi transforms the way you view the world with a punchy and pixel-dense display that unfolds stunningly right in front of your eyes and generates a new realm of life-like graphics, bold colors, and smoother gradients to awaken your senses and invigorate your body and mind.
  • 10.1-inch
    Expansive Size
  • 800*1280
    Resolution
  • 79%
    Screen to Body Ratio
  • 16:10
    Aspect Ratio
Quad-core Rockchip RK3326S
Power for Better Efficiency and Smoothness
From responsive app-launching through smooth video streaming to seamless light-duty multitasking, the Rockchip RK3326S nails them all without a sweat. Get your basic daily entertainment needs perfectly satisfied.
  • CPU
    4*Cortex-A35 up to 1.5GHz
  • GPU
    Mali-G31MP2 GPU
  • 69381
    AnTuTu
  • 3GB
    LPDDR3 RAM
  • 64GB
    eMMC 5.1 ROM
  • 1TB
    TF Expansion
3GB RAM + Up to 2GB Expansion
Include More without Cost
To further expand running memory without extra cost, Tab 7 WiFi provides the new Memory Expansion Technology that extends the 3GB RAM to up to 5GB, giving you an edge to open more apps simultaneously and switch between different apps with ultra-smoothness.
6580mAh Mega Battery
Keep on All Day & All Night
Ultra-lasting 6580mAh battery is ready all the time for you to get through intense work days, juice-consuming online classes, or conferences on the go. Tab 7 WiFi promises longer and more reliable company day in or day out.
  • Video
    5 hrs
  • Music
    15 hrs
  • Game
    4.5 hrs
  • Web
    6 hrs
  • Standby
    312 hrs
Dual Box Speakers with Smart PA
As If in a Live Concert
Tuned by skillful technicians, the dual box speakers with Smart PA enable you to indulge in a powerful sound wave that reproduces ultra-rich acoustic details and broad soundscape from transparent treble to deep bass.
2MP Front + 5MP Rear
Click All the Unforgettable Moments
From perfect selfies at home to interesting groupfies in a long-expecting reunion, Tab 7 WiFi always brings endless shutter joy and takes your photography up a notch.
5MP
2MP
Doke OS Go 3.0 Based on Android 12
Dare to Make A Difference
Swipe up, down, right or left or try more gestures to navigate Doke OS Go 3.0 that facilitates your control over Blackview Tab 7 Wifi. Designed for further convenient interaction without undergoing complex processes.
  • Swipe Down for Control Panel
    • A Tap to Take Screenshot and Switch between Ring/Mute
    • Drop-down Menu
  • Press Volume Button for Pop-up Window on the Right
    • Shortcut for Sound Adjustment of Media, Alarms and Notifications
    • Quick Access to Sound Setting
  • Auto Pop-up
    • Low Battery, High Volume and USB Connection
Refined Animation
Doke OS GO 3.0 witnesses faster and smoother animation of screenshots and all types of floating windows. Always be in sync with you without latency.
Screen Mode
Tab 7 Wifi is designed to ease your learning or working process by providing Dark Theme for better protection of your eyesight and significant reduction of eyestrain at low-lit environments
  • Twilight Blue
  • Space Gray
Blackview Tab 7 WiFi
  • Model
    Tab 7 WiFi
  • Colors
    Twilight Blue, Space Gray
  • Dimension
    246.5*163*9.9mm
  • Weight
    520.5g
  • Display
    10.1-inch 800*1280 HD+ IPS
  • CPU
    Rockchip RK3326S
  • RAM & ROM
    3GB + 64GB, LPDDR3 + eMMC 5.1
  • RAM Expansion
    Up to 2GB
  • Max TF Card Capacity
    1TB
  • Card Slot
    One TF Card Slot
  • Cameras
  • Battery
    6580mAh; 10W Charge
  • Speaker
    1217 2PCS BOX Speakers with Smart PA
  • Wi-Fi
    802.11a/b/g/n
  • OS
Power button
3.5mm headphone jack
TF card slot
Type-C charging port
Volume +/-
2MP front camera
5MP rear camera
Speaker
