Blackview SCM6 14-inch Portable Monitor Laptop Screen Extender with Speaker
Hurry up, only 6 items left in stock.
✔14" IPS 1080P FHD, Double Your Laptop Screen
✔TÜV SÜD Low Blue Light Certified
✔4.5mm thickness & 600g Weight Portable Design
✔Universal USB-C Ports, Fits 13”to 17.3" Laptops
World’s Lightest & Thinnest Eye-Comfort Add-on Laptop Screen One Extra Screen. Double the Vision.
WHY CHOOSE SCM6 Screens
Thinness and Lightness
1080p IPS Eye-Comfort Screen
Universal Plug-and-Play Type-C Ports
Wide Device and OS Support
Ultra-Thin. Ultra-Light. Ultra-Tough.
Only 4.5mm & 600g
As Thin as a Magazine, As Light as a Feather
Experience the future of portability with the SCM6. At just 4.5mm thickness and weighing only 600g, it redefines lightness and convenience. Slip it effortlessly into your bag, carry it anywhere, and enjoy a seamless big-screen experience without compromise.
4.5mm
29% Thinner
than Peers
600g
50% Lighter
than Peers
≈ a Rugged Phone
7.5mm
Incredibly Compact
Even with the Mount
332 × 207 × 15.6 mm
Perfect Portable Size
Fits Easily in Your Suitcase
Dual-Screen Efficiency Anywhere
Effortlessly Slip into Your Bag
Sleek Elegance & Unmatched Durability
Premium Feel, Military Tough
The aerospace-grade aluminum alloy back screen panel delivers unmatched durability and elegance. The matte, scratch-resistant finish resists fingerprints while offering a refined, premium touch—built to impress and built to last.
Aerospace-Grade
Aluminum-Alloy Back Screen Panel
High-Strength Engineering ABS
+ PC Screen Mount
Ultimate Portable Display Experience
14-inch Portable Display
Crystal-Clear Visuals, Immersive Everywhere
Experience stunning visuals on the go with this 14-inch portable screen. Featuring 1920 × 1080 resolution and 300 nits brightness, every frame is sharp, smooth, and vividly colorful for both work and play.
14-inch
Screen
1080p
Display
300nits
Brightness
16:9
Aspect Ratio
Gentle Viewing, Always Portable
Say goodbye to eye fatigue from long hours in front of screens. With TÜV SÜD Low Blue Light Certification, SCM6 reduces harmful emissions for eye-friendly viewing. Work, study, or stream longer on the go with less strain.
Integrated Box Speaker
Clear Sound, Built Right In
Enjoy true portability with the integrated box speaker—no need for external audio. Delivering clear voices and balanced tones, it ensures great sound quality wherever you work, study, or relax.
1W Audio Output
Smooth Plug-and-Play Connectivity
Seamless Setup for Every Laptop
Featuring two full-featured USB-C ports and a PD Charging USB-C port, SCM6 adapts seamlessly to every laptop—whether it’s a new laptop connecting with just one USB-C to USB-C cable, or an older laptop using USB-A to USB-C cable plus HDMI to USB-C cable for instant compatibility.
Faster
Data Transfer
Wider
Compatibility
Stable
Connectivity
One Cable Connection:
USB-C to USB-C
Make Sure the USB-C Port in Your Laptop is Full-Featured. (Support Data Transfer, Video Signal and Power Delivery )
Two Cable Connection:
USB-A to USB-C & HDMI to USB-C
All the Cables Mentioned above are included in the package
USB-C to USB-C (Full-Featured) USB-A to USB-C HDMI to USB-C
100W
Reverse Charging
Fast Power Up Your
Laptop While Work
Stay powered and productive at all times. With 100W reverse charging, SCM6 delivers high-speed power directly to your laptop. Work, stream, or game without worrying about running out of battery.
Seamless Compatibility, Endless Possibilities
Wide Device Compatibility
Work, Create, Game on Multi-Screens
From your laptop to PC, tablet to phone, SCM6 connects instantly. Whether you’re working in the office, trading stocks at home, or gaming on the go, enjoy smooth, versatile compatibility across all your devices.
Compatible Device
Laptop
Desktop
Tablet
Smartphone
Universal OS Compatibility
Plug & Play Across Mainstream Systems
Seamlessly connect across Mac, Windows, Android, Linux, and Chrome. No extra setup, just plug in and start using. With true cross-platform flexibility, your screen is always ready when you are.
Smart Structure for Smooth Workflow
Quick-Fit Laptop Mount
Lock in Your Screen, Work Freely
Easily attach this expandable clip to your laptop. Secure, lightweight, and simple to remove, it ensures your monitor stays steady without compromising portability.
Fits 13" to 17.3" Laptops
Laptop Screen Kickstand
Stable Screen, Steady Workflow
Say goodbye to Laptop screen droop! The Kickstand props up your laptop screen to counterbalance the SCM6 screens, keeping your setup stable and comfortable for work or play.
Adjustable Length – Stretch to Your Comfort
180°Adjustable Angle
Work Freely, View Comfortably
Open, tilt, and customize your viewing angle with ease. The full 180°adjustment ensures ergonomic comfort while maximizing productivity and enjoyment.
Your Portable Productivity Hub
Eye-Friendly Multitasking On The Go
Turn any place into your mobile workstation with dual-screen efficiency. Ultra-light and eye-friendly, it boosts focus, reduces eye strain, and lets you multitask seamlessly—whether working, studying, or creating on the go.
Attend Online Class & Take Notes Together
Report Writing & Reference Side by Side
Editing Timeline & Media Library Together
Compare Multiple Contract Versions Side by Side
| Model | SCM6 |
| Color | Grey |
| Material | Aluminum Alloy + PC + ABS |
| Display | 14" IPS, 1080p FHD, 60Hz Refresh Rate, 300 nits Brightness, 157.35 PPI |
| Ports | 2 × USB-C (Full-Featured, USB3.1, DP Alt Mod, PD3.0 20V/5A MAX) 1 × USB-C (PD 3.0, 20V/5A Max) |
| Speaker | Single BOX Speaker |
| Compatibility - Resolution | 640 × 480 – 1920 × 1080 |
| Compatibility - Color | RGB |
| Compatibility - Refresh Rate | 60Hz |
| Compatibility - OS | Mac / Windows / Android / Linux / Chrome |
| Dimension | 332 × 207 × 15.6mm |
| Weight | 600g |
