Note:
This tablet's 4G network connection can only work in Europe and Asia area, please pay attention before purchasing or consult us.
Blackview Tab 6
Small in Size
Versatile in Use
Small in Size,Versatile in Use
Three in one: 8" phone & 8" tablet & 8" kindle
Think a phone is too small, a laptop too heavy?
Introduce Blackview Tab 6, a mighty hybrid, designed for those with requirements in between and for whoever thinks out of the box.
Best for
  • Students
  • Workplace newbie
  • The elderly
Cost one,get two
Tab 6 has a dual SIMs slot, supporting calls, communications, internet-surfing pleasure anytime, anywhere. Simply insert a SIM card, it becomes your big-sized phone right off the bat.
Light up the screen, the 8-inch display of HD resolution gives you an ideal vision for productivity tasks, reading, and entertainment.
A big-sized Kindle
but more than that
Tab 6 has a reader-friendly Grayscale mode that is easy on eyes. You don't feel like you're reading a screen, but a paper.
Better than a kindle, you can use Tab 6 for immediate creation upon a spur-of-the-moment inspiration as well, besides comfortable reading.
5MP rear camera
The versatile back camera enables you to record the classes, scan documents, capture memorable moments at school.
Handy Note
Note is at hand when inspiration strikes or simply for taking class notes. Write, draw, insert voice or picture with ease. This is where big ideas come to life.
Stuck on a question?
Look it up right away
Whenever you're stuck while doing homework or writing papers, take your Tab 6 right from your bag or your big-sized pocket, an encyclopedia unfolds for you on a big screen!
Make your
clients happier
The super portable, big-screen Tab 6 is always ready and available to impress your clients in a pinch whether for retrieving documents and critical information or bringing up a sample room display and virtual panoramic tour. Sealing the deal is just easy.
When your computer breaks down, it's great to have a backup device that can just be pulled out of your bag and ready to use. Business doesn't stop when your device is always up and running.
Your pocket theater
What's better than watching a movie or Tiktok to unwind after work? Tab 6 comes into play for immediate off-work chill.
32GB storage & up to 1TB expansion
Tab 6 provides enormous room for a huge library of movies. And you can also watch them online via Tab 6 once you insert a SIM card.
5580mAh big battery
Extend your joy with extended battery life. Tab 6 never runs out of battery as you watch movies, surf the internet, and play games on your way home.
Safer riding with
Tab 6 navigator
Tab 6 is equipped with a high-precision quad navigation system that always customizes better routes for you. The big screen that can adjust brightness automatically enables you to read information with ease in any conditions.
Easy to read,
even for the presbyopia
Compared to a phone, Tab 6's 8-inch big screen makes it better to read messages and news. For the elderly with the presbyopia problem, the word size can be enlarged even wider from the Setting.
Easy to pick up and hold
Slim and weighing just 365g, Tab 6 can be effortlessly held in one hand while sitting on the chair, couch, or laying in bed.
Blackview Tab 6
  • Macaron Blue
  • Peach Gold
  • Truffle Gray
Model
Tab 6
OS
Doke OS_P 2.0 (Based on Android 11)
Display
8-inch 1280*800 HD IPS, 16:10 Screen-to-body Ratio
CPU
Unisoc T310, 2.0GHz
RAM & ROM
3GB RAM + 32GB ROM
Max TF Card Storage
1TB
Battery Capacity
5580mAh
Cameras
2MP Front Camera + 5MP Rear Camera
Navigation
GPS+GLONASS+Beidou+Galileo
Wi-Fi
802.11a/b/g/n/ac;
Network Connectivity
GSM Bands: 2/3/5/8
WCDMA Bands:1/8
FDD-LTE Bands:1/3/7/8/20
Card Slots
Dual Nano SIM or a Nano SIM & a TF card
Earphone Port
3.5mm Earphone Jack
Height:207.6mm
Width:124mm
Thickness: 9.45mm
Weight: 365g
