Blackview AirBuds 16 IPX4 Waterproof In-ear TWS Earbuds
Sale price £38.00 Regular price £53.00
Airbuds 16
Lighter to Wear.
Made for Every Move.
Airbuds 16
Airbuds 16
Ergonomic Fit Design
Airbuds 16
2.8g Ultra-light
Airbuds 16
Dual Wear Modes
In-Ear
Mode
Semi In-Ear
Mode
Airbuds 16
IPX4 Water Resistance
Airbuds 16
Intuitive Touch
Control
Control Without Breaking
Your Flow.
Airbuds 16
Antibacterial Ear Tips
Airbuds 16
Clear Voice Pickup
Airbuds 16
13mm Dynamic Driver
Airbuds 16
USB-C Fast Charging
10-Min Charge = Up to 40-Min
Playback / Calls
Airbuds 16
470mAh Charging Case + 35mAh
Earbuds (Each)
Up to 30h Total Playback
Airbuds 16
Ear Tip Storage Design
Airbuds 16
Wireless BT 6.0
Up to 10 m Wireless Range
Airbuds 16
Lock In. Move Freely.
Designed for everyday movement, AirBuds 16 features an ergonomic shape that feels natural, comfortable, and secure—keeping up with you from daily commutes to casual walks.
Airbuds 16
Daily Commutes
Airbuds 16
Everyday Movement
Airbuds 16
Casual Walks
Airbuds 16
Light Jogs
Two Ways to Wear. One Way to Move.
Dual Wear Modes
With dual wear modes, AirBuds 16 lets you choose between deeper, more immersive sound when you want to focus, or lighter, pressure-free comfort when you’re on the move—adapting effortlessly to how you listen throughout the day.
Airbuds 16
In-Ear Mode
Deeper Sound,
Stronger Focus
  • A more sealed fit delivers richer sound and punchier bass
  • Minimizes sound leakage for immersive listening
  • Ideal for music, movies, and focused listening
Airbuds 16
Semi In-Ear
Mode
Lighter Feel, All-Day
Comfort
  • Open, pressure-free fit for long wear
  • More breathable and comfortable during movement
  • Ideal for calls, walks, and light workouts
Airbuds 16
Control Without
Slowing Down
Intuitive Touch Control
Stay in your rhythm with responsive touch controls. Manage music and calls instantly—without reaching for your phone or slowing down. Less thinking. Less tapping. More focus on the move.
Airbuds 16
Double-tap to play or pause
Airbuds 16
Triple-tap to skip tracks
Hands-Free Call Management
Airbuds 16
Single tap to answer calls
Airbuds 16
Double-tap to end or reject calls
Voice Assistant Access
Airbuds 16
Press and hold (2 seconds) to activate the voice assistant
Low Latency Mode
Airbuds 16
Tap four times to enable or disable low latency mode
Airbuds 16
Long-Wear Comfort.
You’ll Forget They’re There.
2.8g Ultra-light
At just 2.8g per earbud, AirBuds 16 sits lightly in your ears—comfortable for long commutes, casual walks, and all-day listening.
Airbuds 16
Cleaner Fit. Safer Wear.
Designed with antibacterial ear tips, AirBuds 16 helps reduce everyday bacterial buildup, supporting safer and more hygienic long-term wear. Gentle on your ears, even during extended listening sessions.
Airbuds 16
Sound That
Moves With You
13mm Dynamic Driver
Powered by a 13mm dynamic driver, AirBuds 16 delivers clear vocals and crisp, detailed sound for everyday listening. From podcasts to calls and music, audio stays lively and clean—easy on your ears all day.
Airbuds 16
Stay Connected.
Keep Moving.
Clear Voice Pickup
With a built-in microphone, AirBuds 16 delivers clear voice pickup for everyday calls—so you stay connected on the street, between meetings, or on the move. Clear, natural conversations without slowing you down.
Airbuds 16
Sweat Ready.
Day Ready.
Built with IPX4 water resistance, AirBuds 16 is designed to handle sweat and light rain during everyday activities. Whether you’re on your commute, taking a casual walk, or caught in a light drizzle, your music keeps playing without interruption. No worries—just keep moving.
Airbuds 16
Power for Your Day.
Commute. Listen.
Repeat.
+ 35mAh Earbuds (Each)
From morning commutes to evening wind-downs, AirBuds 16 keeps your music and calls going all day—powered by a 470mAh charging case and 35mAh earbuds.
Up to 6 hours
on a single charge
Up to 30 hours total
with the charging case
*Playback time is tested at 70% volume. Actual battery life may vary depending on usage and environment.
Airbuds 16
Power in Minutes.
Keep Moving.
USB-C Fast Charging
Short on time? AirBuds 16 is ready when you are. Just 10 minutes of charging delivers up to 40 minutes of music playback or calls—perfect for a quick boost before heading out or between commutes. Plug in briefly, then get back to your day.
10-Min Charge
Up to 40-Min Playback / Calls
*Estimated based on typical usage. Actual playtime may vary depending on usage conditions.
Airbuds 16
Everything in One
Place.
The charging case is designed to store your ear tips securely, keeping everything together and preventing loss when you switch modes or head out.
Ear Tip Storage to
Prevent Loss
Airbuds 16
Airbuds 16
Stable Connectivity.
No Breaks in
Your Flow.
Light on Your Ears.
Strong in Sound.
From daily commutes to casual walks, from starting your day to winding down—AirBuds 16 fits naturally into every moment on the move.
Blackview Airbuds 16 Specifications
Model AirBuds 16
Dimensions Earbuds(Each): 21.25 * 16.8 * 18.26 mm
Charging Case: 65.97 * 37.79 * 26.38 mm
Weight Earbud(Each): 2.8g±0.2g
Charging Case: 30.97g±1g
Color Black
Dynamic Driver 13mm
Frequency Response Range 100Hz~10KHz
Audio Codec AAC / SBC
Battery Capacity Earbuds: 35mAh (per earbud)
Charging Case: 470mAh
Charging Port Type-C
Wireless BT Version Wireless BT 6.0
Connection Range Up to 10 m (open space)
Water Resistance Rating IPX4 (sweat & splash resistant)
