Blackview A70 Pro 6.517 Inches Quad Core 4GB+32GB 5380mAh 13MP + 5MP Camera 4G Android 11 Smartphone
A70 Pro
Budget Big Battery King
5380mAh Battery | 6.517" HD+ Display
5380mAh Battery
6.517" HD+ Display
5MP + 13MP Camera
Quad-core Unisoc T310
4GB + 32GB
Doke OS 2.0
Android 11
Fingerprint
Unlock
5380mAh Massive Battery
Long-lasting Power for Never-ending Days
Live your day freely without worrying about where you can plug in your phone for an extra juice refuel. The far-above-the-average 5380mAh battery has the power that outlasts a day.
7 hrs
Game
8 hrs
Video
9.5 hrs
Web
29 hrs
Call
45 hrs
Music
696 hrs
Light and Exquisite Design
Slim and Portable
While retaining a big 5380mAh battery, the A70 Pro is 9.6mm thin and 205g light only, without extra thickness and weight added, making no compromise on the portability.
Sleek and Stylish
With the pursuit of beauty and aesthetics, the fusion of streamlined curves and smooth finish of lively colors presents the modern stylish look for the A70 Pro.
6.517" HD+ Display
Stunning Visuals with Vivid Details
Get immersive visuals with perfect smoothness and responsiveness on the large 6.517-inch waterdrop display. The high-definition resolution brings you true-to-life clarity and vivid colors.
720*1600
HD Resolution
87.6%
Screen-to-body Ratio
20:9
Aspect Ratio
5MP + 13MP Camera
Capture Every Special Moment
Capture every sparkling moment in life with the A70 Pro. Combining high-class cameras with advanced algorithms, it turns what you see into stunning shots. With the BSI sensor that helps capture more light for both front and rear cameras, low-light performance is also enhanced.
13MP
Sony® IMX258
Rear Camera
5MP
Front Camera
Ready for Most Demands
As the world’s first 4-core LTE chip with the introduced large core, the Unisoc T310 achieves high computing performance and lower power consumption, excelling in the current mainstream 4-core products. Paired with 4GB RAM, it smoothly runs and switches between more apps.
More Powerful than the Predecessor, A70
| A70 | A70 Pro | |
| Processor | Unisoc SC9863A | Unisoc T310 |
| Process | 28nm | 12nm |
| CPU | 4*A55 1.6GHz + 4*A55 1.2GHz | 1*A75 2.0GHz + 3*A55 1.8GHz |
| GPU | PowerVR GE8322@550MHz | PowerVR GE8300@800MHz |
| RAM | 3GB | 4GB |
3 Card Slot Design
More Room, More Possibilities
While inserting two SIM cards, A70 Pro can support an external TF card of up to 128GB to store more. With 32GB of internal storage, keep all the favorites right on your phone.
Rear-mounted Fingerprint Sensor
Unlock in A Twinkling
Reach the rear-mounted fingerprint sensor area with your finger naturally to make phone unlock simple. Also support face and password unlock.
Rear Fingerprint Sensor
Doke OS 2.0
Based on Android 11, As Natural as Breathing
A70 Pro carries the Doke OS 2.0 based on Android 11 to improve aesthetics, interaction, and efficiency.
Clone Phone
Transfer the privacy data safely from the old to the new device.
System Manager
Support all-in-one controls such as trash cleaning and battery management.
Dual-window
EntertainmentView different contents on the same screen to enable entertaining while working.
Game Mode
Clean up RAM to save memory and block popups for interference-free gaming.
Cold Room
Freeze apps to avoid their stealthy background running and save memory.
Screenshot/
Long ScreenshotFor important messages, make a screenshot or long screenshot and edit it easily.
4G LTE
4G LTE Connectivity
Ensure more reliable connection and faster data transmission with the 4G LTE connection. Also offer 2.4G &5G dual-band Wi-Fi.
4G LTE
2.4G&5G Wi-Fi
3-in-1
Navigation System
Combine the world’s most utilized satellite navigation systems, including GPS, GLONASS, and Beidou, to locate your destination with accuracy.
GPS
GLONASS
Beidou
165.2*77*9.6mm
Dimension
165.2*77*9.6mm
205g
Weight 205g - 6.517-inch 720*1600 HD+, 87.6% Screen 6.517-inch 720*1600 HD+, 87.6%
Octa-core SC9863A
Processor Quad-core T310 -
3GB + 32GB
Storage 4GB + 32GB -
32GB
Expandable Storage 128GB -
5380mAh; 5V/2A
Battery 5380mAh; 5V/1A -
5MP Front + 13MP Sony® IMX258
Camera 5MP Front + 13MP Sony® IMX258 -
Android 11
Operating System Doke OS 2.0 (Android 11) -
Yes
Fingerprint Sensor Yes -
GPS+GLONASS
Navigation GPS+GLONASS+Beidou -
802.11 b/g/n; BT 4.2
Connectivity 802.11 b/g/n/ac; BT 5.0 -
Earphone Jack 3.5mm
Colors to Choose from
Express Your Style
With the impressively beautiful shades to choose from, A70 Pro suits your unique style — from cool and bold to simple and sleek.
Fantasy Black
Mint Green
Guava Red
Gradient Blue
Blackview A70 Pro
Model
A70 Pro
Colors
Black/Green/Red/Blue
Dimension
165.2*77*9.6mm
Weight
205g
OS
Doke OS 2.0 (Based on Android 11)
Display
6.517" 720*1600 HD+ IPS
CPU
Quad-core Unisoc T310, 2.0GHz
RAM & ROM
4GB RAM + 32GB ROM
Max TF Card Storage
128GB
Battery Capacity
5380mAh
Camera
5MP Front Camera + 13MP Sony
Navigation
GPS+GLONASS+BEIDOU
Wi-Fi
802.11 b/g/n/ac;
Network Connectivity
GSM spec: 2/3/5/8
3G spec: WCDMA: B1/B8
LTE spec: TDD: B40 FDD: B1/B3/B7/B8/B20
