Blackview A52 Pro 6.5-Inch T606 Octa Core 4GB/6GB+128GB 5180mAh 13MP Rear Camera 4G Smartphone
$159.99 $119.99
A52 Pro Powerful, Fast, Elegant 5MP Front Camera 13MP Rear Camera T606 Octa core 6.5-inch HD+ Display 6GB RAM + 128GB...
Capacity: 4GB+128GB
4GB+128GB
6GB+128GB
Color: Green
Blue
Green
HURRY! ONLY LEFT IN STOCK.
paypalvisamastermaestrojcbamerican expressdiners clubdiscovercartes bancairesklarnaafterpaygoogle payapple pay
Frequently Bought Together
Total price:$269.97 $189.97
Description
A52 Pro
  • 5MP Front Camera
    13MP Rear Camera
    T606 Octa core
    6GB RAM + 128GB ROM
    5180mAh Battery
  • Android 13
    Doke OS 4.0
Stunning Views on A Bigger Screen
Embark your next incredible and immersive visual journey on the expansive 6.5-inch waterdrop display with silky smoothness and quick responsiveness. The high-definition resolution brings you real-world vividness that fascinates you much.
  • 6.5-inch
    Screen Size
  • 720*1600
    HD+ Resolution
  • 87.6%
    Screen-to-body Ratio
  • 380cd/cm2
    Brightness
5180mAh Battery
Last Longer, Charge Less
Under the hood, the A52 Pro embeds an above-average battery and turns out to be a strong powerhouse that continuously powers you up, living up to more than a day of regular use. Even that you’re a heavy smartphone user, it still lasts longer than you can expect.
  • 5.5hrs
    Game
  • 7 hrs
    Movie
  • 10 hrs
    Web
  • 24 hrs
    Call
  • 30 hrs
    Music
  • 240 hrs
*The data is tested by Blackview Laboratory. Battery life depends on the actual usage situations.
Sophisticated, Simplistic Design
Appealing to Eyes,
Comfortable to Hands
Made of durable material and treated with refined craftsmanship, A52 Pro presents a minimalist back cover in youthful and living colors. With the texture of matte finish and ergonomic flat-edged design, it’s comfortable to fit in hand.
Your Dream Colors
A Delight to Your Style
Design is an endless journey of pursuing beauty, and everything can be the spark of new inspirations. A52 Pro interprets the color aesthetics in life from the splendid nature scenes to the whimsical imaginations with four invigorating hues.
Octa-core Processor
Smooth and Responsive to Process
Clocked at up to 1.6GHz, the Octa-core T606 runs multiple apps and multitasks at sufficient fluidity, responsiveness, and efficiency to satisfy your productivity and entertainment needs.
  • 6GB RAM
  • 128GB ROM
  • 512GB Expandable Storage
  • 5MP + 13MP Cameras
    Never Miss A Scene
    Make selfies, shoot creative videos, and take photos for wonderful moments on both front and rear cameras. Edit your photographs further with filters, emojis, or other techniques and share them on social media to get more likes and fans.
    Beauty Mode
    Beautify your face naturally to maximize your charm.
Doke OS 4.0 Based on Android 13 Empower Every Aspect
Blackview has always focused on user experience improvement and therefore developed the Doke OS. Leaping from OS 2.1 to OS 4.0 version, the latest upgraded OS brings more friendly features for the intuitive visuals and smooth controls. With Android 13 OS, you can also relish new Android highlights.
  • System Manager
    Support all-in-one controls such as trash cleaning and battery management.
  • Clone Phone
    Transfer the privacy data safely from the old to the new device.
  • Artistic Themes
    Three sets of themes are with enriching icons and invigorating wallpapers.
  • Cold Room
    Freeze apps to avoid their stealthy background running and save memory.
  • Screenshot/Long Screenshot
    For important messages, make a screenshot or long screenshot and edit it easily.
  • Dual-window Entertainment
    View different contents on the same screen to enable entertaining while working.
  • Dark Mode
More Details
More to Impress
  • Face Unlock in A Blink
    Enable the face recognition function to unlock the smartphone quickly at a glance.
  • 3-in-1 Navigation System
    supports GPS, GLONASS, and Galileo navigation for faster positioning.
  • 4G LTE Connectivity
    Deliver fast and stable mobile network experience for better work and play capabilities.
  • Multiple Card Slots Design
    More room, more fun. Support the insertion of 2*SIMs /1*SIM+1*TF Card
164.2mm
13MP Rear Camera
Flash
9.05mm
Power
Button
5MP Front
Camera
Earpiece
Volume +/- Button
62mm
Charging Port
Mic
Blackview A52 Pro
Model A52 Pro
Colors Vitality Green∣Ice Blue∣Polar Night
Dimension 164.2*62*9.05mm
Weight 183.6g
OS Doke OS 4.0 (Based on Android 13)
Display 720*1600 20:9 HD+ IPS
CPU T606
RAM & ROM 4GB/6GB RAM + 128GB ROM
Max TF Card Storage 512GB
Battery Capacity 5180mAh
Camera 5MP Front Camera
13MP Rear Camera
Navigation GPS, GLONASS and Galileo
Wi-Fi & Bluetooth 802.11b/g/n 2.4G ; BT V4.2
Network Connectivity GSM spec: 850/900/1800/1900
3G spec: WCDMA:B1/B8
LTE spec:FDD:B1/B3/B7/B8/B20
