Blackview A52 Pro 6.5-Inch T606 Octa Core 4GB/6GB+128GB 5180mAh 13MP Rear Camera 4G Smartphone
A52 Pro Powerful, Fast, Elegant 5MP Front Camera 13MP Rear Camera T606 Octa core 6.5-inch HD+ Display 6GB RAM + 128GB...
Frequently Bought Together
A52 Pro
5MP Front Camera
13MP Rear CameraT606 Octa core
6GB RAM + 128GB ROM
5180mAh Battery
Android 13
Doke OS 4.0
Stunning Views on A Bigger Screen
Embark your next incredible and immersive visual journey on the expansive 6.5-inch waterdrop display with silky smoothness and quick responsiveness. The high-definition resolution brings you real-world vividness that fascinates you much.
6.5-inch
Screen Size
720*1600
HD+ Resolution
87.6%
Screen-to-body Ratio
380cd/cm2
Brightness
5180mAh Battery
Last Longer, Charge Less
Under the hood, the A52 Pro embeds an above-average battery and turns out to be a strong powerhouse that continuously powers you up, living up to more than a day of regular use. Even that you’re a heavy smartphone user, it still lasts longer than you can expect.
5.5hrs
Game
7 hrs
Movie
10 hrs
Web
24 hrs
Call
30 hrs
Music
240 hrs
*The data is tested by Blackview Laboratory. Battery life depends on the actual usage situations.
Sophisticated, Simplistic Design
Appealing to Eyes,
Comfortable to Hands
Made of durable material and treated with refined craftsmanship, A52 Pro presents a minimalist back cover in youthful and living colors. With the texture of matte finish and ergonomic flat-edged design, it’s comfortable to fit in hand.
Your Dream Colors
A Delight to Your Style
Design is an endless journey of pursuing beauty, and everything can be the spark of new inspirations. A52 Pro interprets the color aesthetics in life from the splendid nature scenes to the whimsical imaginations with four invigorating hues.
Octa-core Processor
Smooth and Responsive to Process
Clocked at up to 1.6GHz, the Octa-core T606 runs multiple apps and multitasks at sufficient fluidity, responsiveness, and efficiency to satisfy your productivity and entertainment needs.
6GB RAM
128GB ROM
512GB Expandable Storage
5MP + 13MP Cameras
Never Miss A SceneMake selfies, shoot creative videos, and take photos for wonderful moments on both front and rear cameras. Edit your photographs further with filters, emojis, or other techniques and share them on social media to get more likes and fans.
Beauty Mode
Beautify your face naturally to maximize your charm.
Doke OS 4.0 Based on Android 13 Empower Every Aspect
Blackview has always focused on user experience improvement and therefore developed the Doke OS. Leaping from OS 2.1 to OS 4.0 version, the latest upgraded OS brings more friendly features for the intuitive visuals and smooth controls. With Android 13 OS, you can also relish new Android highlights.
System Manager
Support all-in-one controls such as trash cleaning and battery management.
Clone Phone
Transfer the privacy data safely from the old to the new device.
Artistic Themes
Three sets of themes are with enriching icons and invigorating wallpapers.
Cold Room
Freeze apps to avoid their stealthy background running and save memory.
Screenshot/Long Screenshot
For important messages, make a screenshot or long screenshot and edit it easily.
Dual-window Entertainment
View different contents on the same screen to enable entertaining while working.
Dark Mode
More Details
More to Impress
Face Unlock in A Blink
Enable the face recognition function to unlock the smartphone quickly at a glance.
3-in-1 Navigation System
supports GPS, GLONASS, and Galileo navigation for faster positioning.
4G LTE Connectivity
Deliver fast and stable mobile network experience for better work and play capabilities.
Multiple Card Slots Design
More room, more fun. Support the insertion of 2*SIMs /1*SIM+1*TF Card
Button
Camera
Blackview A52 Pro
Model | A52 Pro |
Colors | Vitality Green∣Ice Blue∣Polar Night |
Dimension | 164.2*62*9.05mm |
Weight | 183.6g |
OS | Doke OS 4.0 (Based on Android 13) |
Display | 720*1600 20:9 HD+ IPS |
CPU | T606 |
RAM & ROM | 4GB/6GB RAM + 128GB ROM |
Max TF Card Storage | 512GB |
Battery Capacity | 5180mAh |
Camera | 5MP Front Camera 13MP Rear Camera |
Navigation | GPS, GLONASS and Galileo |
Wi-Fi & Bluetooth | 802.11b/g/n 2.4G ; BT V4.2 |
Network Connectivity | GSM spec: 850/900/1800/1900 3G spec: WCDMA:B1/B8 LTE spec:FDD:B1/B3/B7/B8/B20 |
