Color_Black
Blackview A50 6.088 inches Unisoc T310 Quad Core 3GB+64GB 4280mAh 13MP Camera 4G Smartphone
Sale price £90.00 Regular price £113.00
Note:
A50
More than You Expect
  • 6.088" HD+ Display
  • Unisoc T310 Processor
  • 5MP
    Front Camera
  • 3GB RAM + 64GB ROM
  • 4280mAh Battery
  • 13MP
    Rear Camera
  • Android 11
  • Doke OS 2.0
  • Fingerprint
    Unlock
6.088" HD + Display
Bigger & True-to-life Vision
Show more content in a frame on the large, expansive display for reading, catching up on some tasks, or web browsing without sliding back and forth. HD resolution gives an ideal clear vision.
  • 6.088''
    Screen Size
  • 720*1560
    HD+ Resolution
  • 86.3%
    Screen-to-body Ratio
  • 380nit
    Brightness
156g Light & 8.9mm Thin
Feature-packed Inside, Exquisite Outside
From super lightweight and ergonomic rounded curves to refined anti-fingerprint finish and stylish colors, it makes each grip a perfect fit in the palm and a relish for the touch and vision.
  • 156g
    Light
  • 8.9mm
    Thin
4280mAh Battery
Stay Energized for A Day
With full power before out and still powered on when back home, carry on your day ahead lively, whether for work or play, without any battery anxiety.
  • 7.5hrs
    Web
  • 6hrs
    Game
  • 25hrs
    Music
  • 22hrs
    Call
  • 6hrs
    Video
  • 288hrs
*The data is tested by Blackview Laboratory. Battery life depends on the actual usage situations.
Quad-core Unisoc T310
Powerful to Your Demands
Powered by the Unisoc T310 to process quickly, run more apps simultaneously, and switch them seamlessly. A large storage room saves more content, including videos, music, eBooks, and files.
  • 3GB
    LPDDR4X RAM
  • 64GB
    ROM
  • Up to 1TB
    Expandable
5MP Front + 13MP Rear
Awesome Photographs with the Taking
Every clip in life, from the hilarious travel time to bustle learning hour, is worth a video or photo shoot on the way. Derive immense satisfaction from your photographs in the album gallery.
13MP Sony® IMX258 Rear Camera
Doke OS 2.0
Based on Android 11, As Natural as Breathing
A50 adopts the Doke OS 2.0 based on Android 11 for better aesthetics, interaction, and efficiency.
Exquisite Wallpapers and App Icons
The all-new UI design combines style and viewing comfort.
System Manager
Support all-in-one controls such as trash cleaning and battery management.
  • Free up
    More Space
  • Smart
    Power Saving
  • Game
    Speedup
  • App
    Management
Game Mode
Clean up RAM to save memory and block popups for interference-free gaming.
  • Before
  • After
  • Game
    Other Apps
Cold Room
Freeze apps to avoid their stealthy background running and save memory.
  • Before
  • After
Screenshot/Long Screenshot
For important messages, make a screenshot or long screenshot and edit it easily.
Dual-window Entertainment
View different contents on the same screen to enable entertaining while working.
Rear-mounted
Fingerprint Sensor
Easy to reach and unlock within a snap.
Back Fingerprint Unlock
2+1 Card Slots
Have both — easy card switch & larger memory space.
Blackview A50
Colors
  • Summer Mojito
  • Twilight Blue
  • Ink Green
  • Phantom Black
  • Specifications
    • Model
      A50
    • Dimension
      156.4*72.9*8.9mm
    • Weight
      156g
    • OS
      Doke OS 2.0 (Based on Android 11)
    • Display
      6.088" 720*1560 HD+ IPS
    • CPU
      Quad-core Unisoc T310 2.0GHz
    • RAM & ROM
      3GB RAM + 64GB ROM
    • Max TF Card Storage
      1TB
    • Battery Capacity
      4280mAh
    • Camera
      5MP Front Camera
    • Navigation
      GPS+GLONASS
    • Wi-Fi
      802.11.b/ g/ n/ ac;
    • Network Connectivity
      GSM spec: 2/3/5/8
      WCDMA spec: B1/B8
      TDD spec: B40
      FDD spec: /B1/B3/B7/B8/B20
  • Dimensions
    Height: 156.4mm
    Width: 72.9mm
    Thickness: 8.9mm
    Weight: 156g
Button/interface
