Blackview MP100 Pro Intel/AMD CPU 16GB DDR4 M.2 PCIe 4.0 SSD WiFi 6 Windows 11 Pro Mini PC
Sale price £524.00 Regular price £598.00
MP100 Pro
Boost Your Day, Refine Your Play
Empower Work and Play with Unmatched
Performance and Smoother 4k 144Hz Display
Why Choose Blackview MP100 Pro?
NO.1
Next-level Flagship Power with Intel® SamsungSharpSans-Medium 12th Gen i9 CPU and 4K 144Hz Brilliance for Work, Leisure, and Gaming
NO.2
Ultra-quiet 5-in-1 Constant Temperature Cooling System
NO.3
Seamless Operation & Triple Display with 12 Well-organized Interfaces
NO.4
Power Up with Mini & Cool Magic
NO.1
Next-level Flagship Power with Intel® 12th Gen CPU and 4K
Ace Your Daily Grind in Work, Rest, and Play
Max Out Performance. Zero Compromise
Flagship Intel® 12th Gen Core i9-12900HK
With the flagship Intel® 12th Gen Core i9-12900HK inside, Blackview MP100 Pro clocks up to 5.0GHz, making light work of daily tasks, binge-watching, gaming sessions, and even heavy-duty office work.
Rev Your Tasks to the Next Level
16GB DDR4 | Upgradable to 64GB DDR4
Featuring dual DDR4 channels and 16GB of 2666MHz high-performance RAM , MP100 Pro ensures smooth parallel workflows and fast responsiveness. Need more? Expand it to 64GB and push your limits in multitasking, content creation, and gaming.
Ready When You Are. Faster Than You Think
1TB M.2 SSD + Up to 4TB M.2 2280 NVMe Supported
MP100 Pro comes equipped with a 1TB M.2 SSD that loads everything in a flash — apps, files, your entire creative universe. And when you're ready to level up, upgrade to 4TB and never look back.
Product Internal Design
Up Your Game at Work and in Play
with Sharper, Smoother Visuals
Smoother, Clearer, Faster, Than Ever
Top-tier Intel® Iris® Xe Graphics eligible
Powered by top-tier Intel® Iris® Xe Graphics, MP100 Pro improves gaming speed while delivering exceptional image clarity and resolution, creating a visually captivating experience.
Max Dynamic Frequency
MP100 Pro
1450MHz
20.8% ↑
Faster Response Time
Predecessor
1200MHz
Epic Visual Feast Unleashed
4K 144Hz UHD Display
Buckle up for a visual spectacle with MP100 Pro's 4K UHD and epic 144Hz refresh rate! Expect nothing less than vivid details and seamless graphics that will rev up your gaming and leisure time.
NO.2
Maximizing Performance with a Top-Notch Cooling System and Whisper-quiet Design
Mini Monster, Mega Chill
Superb Heat Dissipation System
The MP100 Pro comes equipped with a cooling fan that provides a maximum airflow of up to 7.74 CFM, supplemented by copper heat pipes, heat sink fins, aluminum plates, and thermal pads to ensure maximum heat dissipation efficiency and unparalleled performance.
7.74 CFM
Maximum airflow
≤38℃
Constant Cooling Temperature
Stay Silent, Stay Fast-paced Driven
Easily distracted by sound? Blackview MP100 Pro features a super-quiet fan operating at 2800 RPM, keeping noise levels below 30 dB during everyday office use. Stay laser-focused on your priorities without any noise interruptions.
2800 RPM
Super-silent fan speed
≤30dB
Regular usage
34-39dB
Peak performance
NO.3
Tap into Top-notch Smoothness and Convenience
Connect More, Do Anything, Effortlessly
12 Clever Well-organized Interfaces
Decked out with 12 clever well-organized interfaces, MP100 Pro turns your desk into command central—connect everything from headphones to keyboards in a snap. It's a perfect match for up to 99% of the peripherals out there, giving you a powerhouse of functionality and ease.
Tripled Vision, Tripled Productivity
Triple 4K Display Support
Max out your multitasking with Blackview MP100 Pro. Its HDMI,DP, and USB-C ports enable a seamless 4K triple-monitor support for peak productivity and top-notch entertainment.
Games
Design
Content Creation and
Multimedia Edits
Streamed Media and Films
Online courses
Office Tasks
Speed Up, Lag Down
Rocket-fast Wi-Fi 6 & Wireless BT5.2
Blaze through games without a hitch with MP100 Pro's rocket-fast Wi-Fi 6, ensuring no lag as you and your team rack up wins. Plus, Wireless BT5.2 cranks up the stability and speed of your wireless connections.
Power Through Work and Play
Windows 11 Pro Pre-installed
Enjoy professional-grade apps, privacy, stylish design , and realistic visuals with Windows 11 Pro pre-installed on MP100 Pro, which is tailored for office tasks, gaming, and home entertainment.
NO.4
Pocket-sized to Streamline Daily Routine and Boost Productivity
Mini Size, Mega Power
Space-saving Design
Small but mighty, Blackview MP100 Pro is a true powerhouse packed into a tiny package. Its space-saving design allows it to effortlessly fit into any space , providing the performance of a full-size PC in a compact form factor perfect for use on the move.
Illuminate Your Victory Horn!
Cool RGB ambient light kick up the intensity of fierce gaming battles, bringing the thrill right to your fingertips for a super immersive feel.
Office Use
Home Entertainment
On-the-Go Business Trips
Freedom to Mount, Space to Spare
VESA Back Mounting Support
Mount MP100 Pro behind your monitor using a VESA bracket to minimize space usage while maximizing aesthetics—a clean, clutter-free zone.
Brand Blackview
Model MP100 Pro
Color Grey, Blue
Dimension 147.5*147.5*41.8mm
Weight 492g
CPU Intel® 12th Gen Core i9-12900HK
14 Cores (6 Performance + 8 Effciency)
GPU Intel® lris® Xe Graphics eligible
Display 4K UHD, Max 144Hz Refresh Rate
Cache 24 MB
Burst Frequency 5.00 GHz
Base Frequency 3.80 GHz
RAM 16GB DDR4,2666MHZ
Dual Channel, Max 64GB Expansion Support
SSD 1TB M.2 2280 PCle 4.0
Dual Channel, 2* M.2 2280 NVMe slots (up to 2TB each)
OS Windows 11 Pro
Wi-Fi Wi-Fi 6
Wireless BT 5.2
LAN Support 10/100/1000Mbps
I/O USB 3.2 Gen 1 Type-A ×4 (5Gbps)
USB 3.2 Gen 2 Type-A ×2 (10Gbps)
HDMI 2.0 ×1 (Max 4K@60Hz)
DP 1.4 ×1 (Max 4K@144Hz)
RJ45 Gigabit Ethernet ×1 (Self-adaptive, 1000Mbps)
Type-C ×1 (Full-featured, 10Gbps, Max 4K@60Hz)
DC Jack (5.5mm/2.1mm) ×1
3.5mm Audio Jack ×1 (Two-in-one Headphone/Mic)
