Blackview A60 Quad-Core 13MP+5MP Camera 3G Smartphone
✔6.1 Inch 19.2:9 HD- IPS
✔Quad Core 2GB+16GB
✔13.0MP+5.0MP Dual Camera
✔Android 10 4080mAh
6.1"
Waterdrop Screen
5MP
Front Camera
13MP
Dual Rear Camera
4080mAh
Big Battery
Quad Core
Processor
2GB RAM + 16GB ROM
Waterdrop Full Screen, Expand Your Vision
Water is life. The unique shape of the A60’s notch is inspired by a droplet of water captured at the moment before it falls; a brief, transitional state between movement and stillness, where anything is possible. When you turn on the screen, it bursts into life as if infused with the life-giving power of water.
13MP Dual Rear Camera
Amazing photos are just a click away with the A60. It has a super-clear 13MP main rear camera, and a secondary rear camera which captures depth-of-field information, achieving DSLR-rivalling bokeh shots. It also provides super-fast focusing speed with PDAF technology, which captures even fleeting moments with perfect clarity.
4080mAh big battery using the world's leading ATL Li-ion battery
A huge 4080mAh battery capacity frees you from the concern of battery draining during your day. Moreover, smart and thoughtful AI battery management freezes inactive apps and reduces excess caching to save more power. This allows you to play at will, and there's no need to worry about running out of battery because of using the world's leading ATL Li-ion battries.
2GB RAM + 16GB ROM Meet Quad-Core Performance
Empowered by a new quad-core processor and 2GB RAM + 16GB ROM, the A60 runs smoothly even when performing complex tasks. Easily run multiple apps simultaneously, and switch between games and social media apps with ease. Don’t worry - your A60 is designed to keep up with you!
Dual SIM + Dedicated micro SD Card Slot
Up to 128GB expandable storage. Supports simultaneous use of two SIM cards for data and phone calls or a micro SD card for data storage.
Android 10 (Go edition), AI Powered
Android 10 harnesses the power of artificial intelligence to give you more from your phone. The Go Edition contains the best of Android in a much smaller size, built with new and reimagined apps, provides a smarter, more efficient and convenient user experience.
Green
Blue
