Blackview WAVE 2C 5-inch Unisoc SC9863A1 Octa-core 3000mAh Small 4G Smartphone
Hurry up, only 1 item left in stock.
✔5-inch display with a slim 11.1mm body
✔Unisoc SC9863A1 chipset with 3GB RAM and 32GB storage
✔2MP front camera and 5MP rear camera
✔Face unlock, 3.5mm headphone jack, and three satellite navigation systems
Blackview WAVE 2C is made for simple living, offering a compact palm-sized phone that feels light, comfortable, and easy to use. Its 5-inch display, 11.1mm slim body, 158.5g weight, Panda Glass screen, and Android 16 Go system support clear everyday operation. With Unisoc SC9863A1, 3GB RAM, 32GB ROM, up to 9GB RAM expansion, 1TB TF storage, 3000mAh battery, Google Lens, 2MP front camera, 5MP rear camera, face unlock, 3.5mm audio jack, and triple-satellite navigation, it keeps daily essentials simple.
Made for Simple Living
11.1 mm
Ultra-Slim
Cortex-A55@1.6GHz
PowerVR GE8322
Copper Foil Cooling Efficient Cooling, Reliable Operation
and stable runtime for daily use. 1754 mm² Total Copper Cooling
Longer Usage Intelligently optimizes power consumption to extend battery life effectively, keeping your phone ready for use whenever you need it.
Translation Image
Recognition Homework
Help
Reminder Gentle Reminders,
Healthy Habits Receive gentle alerts when using apps for too long, helping you take breaks and build healthy usage habits.
Even in Your Pocket When a call comes in, your WAVE 2C automatically boosts the ringtone to maximum volume and activates
vibration, ensuring you’ll always
hear and feel it clearly.
location accurate and navigation steady, whether you’re traveling or finding your way around town.
Face Unlock
Free TPU Protective Case
400 nits Brightness, 60Hz Refresh Rate
Up to 9GB RAM Expansion
3G Band: B1/B2/B4/B5/B8(With Diversity)
4G Band: TDD:B38/B40/B41(With Diversity)
FDD:B1/B2/B3/B4/B5/B7/B8/
B12/B17/B18/B19/B20/B26/
B28A/B28B/B66(With Diversity)
| Model | WAVE 2C |
| Colors | Shadow Black / Blaze Orange |
| Dimension | 135.6*70.2*11.1 mm |
| Weight | 158.5 g |
| OS | Android 16 GO |
| Display | 5", 854*480 Resolution, 198 PPI, 400 nits Brightness, 60Hz Refresh Rate |
| CPU | Octa Core Unisoc SC9863A1 |
| RAM & ROM | 3GB RAM + 32GB ROM, Up to 9GB RAM Expansion |
| Expandable Storage | Up to 1TB TF Expansion |
| Battery | 3000mAh (5W Charger Power) |
| Front Camera | 2MP |
| Rear Camera | 5MP |
| Speaker | Single |
| Navigation | GPS+GLONASS+Galileo |
| Card Slot | 2 × SIMs + 1 × TF Card |
| BT Version | 4.2 |
| WiFi Version | 2.4G(802.11 b/g/n) |
| Connectivity | 2G Band: B2/B3/B5/B8 3G Band: B1/B2/B4/B5/B8(With Diversity) 4G Band: TDD: B38/B40/B41(With Diversity) FDD:B1/B2/B3/B4/B5/B7/B8/ B12/B17/B18/B19/B20/B26/ B28A/B28B/B66(With Diversity) |
