Blackview AirBuds 60 IPX4 Waterproof Bluetooth 5.3 Half In-ear TWS Earbuds with Earhooks
Sale price £23.00 Regular price £30.00
Blackview
AirBuds 60
Feel the Beat and
Hear the Difference
LED Power Display
IPX4 Waterproof
13mm Dynamic
Driver
500mAh Battery Charging Case
5.3
Flip Open
and Connect
Environment
Noise Cancellation
Ergonomic
Secure Fit
Indulge in Music without Battery Anxiety 500mAh Large Battery Earphone heavy users? AirBuds 60 can satisfy you all with a larger 500mAh battery that provides up to 6 hours of music playback on a single full charge. Beyond that, you get nearly a total of 30 hours of endurance with the charging case which offers 4-5 times of charge for the earbuds. Immerse yourself in music all the way.
6 Hours 6 Hours of Music Playback at Maximum Volume on a Single Charge. LED Indicator Description
For the earbuds
Low Battery Blue light flashes
Fully Charged Blue light off
Bluetooth Pairing Blue light flashes
Power Off Blue light on for 1s
30 Hours A Total of 30 Hours of Music Playback with the Charging Case. LED Indicator Description
For the charging case
Low Battery (<20%) The digital display flashes the battery level for 10 seconds upon opening the cover.
Charging The digital display stays on and indicates the last digit of the battery level with intermittent flashes.
Full charge The digital display shows 100% and remains lit for 10 seconds before turning off.
*The actual battery life varies depending on music type, volume.and usage patterns. Intended for Optimized Audio Pleasure Half In-ear Design After massive tests to improve the experience of wearing Airbuds 60 on thousands of users, the earbuds are engineered to fit snugly and seamlessly in the ears with minimal pressure and maximal comfort regardless of various ear contours.
4.6 g
Earbuds
40*29.8*24.7 mm
46 g
Charging case
73.9*51*31 mm
Automatically Block out the Unimportant Noise ENC Noise Reduction Incorporating the adaptive dual-mic Environmental Noise Cancellation Technology (ENC) , AirBuds 60 automatically switches on noise cancellation mode to cut out all the unwanted noise during calls whether you are in a crowded subway, a bustling supermarket, or near loud traffic. Low Latency, High Synchronization Effective Game Mode Press the right earbud for 2s to turn on the Game Mode designed to minimize audio latency during gaming. Keep visuals and audio in lockstep to ensure thrilling gaming experiences.
Rich in Details,
Pleasing in Every Note
13mm Dynamic Driver
The 13mm dynamic driver characterized by PU and TI titanium composite diaphragms reproduces authentic and vivid sound as on site. AirBuds 60 precisely captures audio across a wider field of frequencies to please your ears and mind with more powerful treble, deeper bass and clearer midrange.
Latest Bluetooth 5.3
Faster and More Stable
to Connect
Upgrading from Bluetooth 5.0 to Bluetooth 5.3, it delivers faster and more stable connectivity and transmission, stronger anti interference, lower latency and lower power consumption to elevate your listening.
Paired Once and for All Automatic Connection When you open the charging case and take out the earbuds, the duo will automatically activate themselves. After first-time pairing with your smartphone, the earbuds will resume automatic connection with your phones. Only pair once and you are free from the trifle of connection. First-time Pairing Guide
Step 1: Open the charging case and
take out the earbuds.
Step 2: Open the Bluetooth on your
smartphone and search for “AirBuds 60”.
Step 3: Click to connect.
Tap to Operate Control at Your Slight Touches Airbuds 60 features convenient tapping control and responses to your every move accurately.
For the Left Earbud For the Right Earbud For the Either Earbud
Volume - Previous song
Tap once Long tap
Volume + Next song
Tap once Long tap for 2s
Voice assistant
End a call
Answer a call
Tap thrice
Long tap for 2s
Long tap for 2s
IPX4 Waterproof
Safe from Spills,
Rains,and Sweats
The integral structure meets IPX4 water resistance standard. Whether you’re breaking strong sweat in workouts, running in the mild rain or accidentally splashing coffee/oil over the earphones, they remain safe and reliable.
Multiple Operating
Systems Support
Airbuds 60 is widely compatible with most Android/iOS/Harmony OS devices. Connect it to tablets and smartphones for various pleasures.
Model
Weight
Color
Driver
Frequency response range
Bluetooth version
Audio codec
Battery capacity
Music play time (single full charge)
Charging time
Charging port
Water resistance
AirBuds 60
46g(charging case) / 4.6g*2 (earbuds)
Black/White
13mm dynamic driver
20 ~20KHZ
BT 5.3
SBC/AAC
500mAh
6 hours(100% volume)
1.5h (earbuds) / 2h(charging case)
USB Type-C
IPX4 (earbuds)
Blackview
AirBuds 60
Feel the Beat and
Hear the Difference
LED Power Display
IPX4 Waterproof
13mm Dynamic
Driver
5.3
Flip Open
and Connect
Environment
Noise Cancellation
Ergonomic
Secure Fit
For the earbuds
30 Hours A Total of 30 Hours of Music Playback with the Charging Case. LED Indicator Description For the charging case
4.6 g
Earbuds
40*29.8*24.7 mm
46 g
Charging case
73.9*51*31 mm
Rich in Details,
13mm Dynamic Driver
Faster and More
Stable to Connect
Unimportant Noise
ENC Noise Reduction
Volume - Tap once
Previous song Long tap
Volume + Tap once
Next song Long tap for 2s
Voice assistant
End a call
Answer a call
Tap thrice
Long tap for 2s
Long tap for 2s
IPX4 Waterproof
Safe from Spills,
Rains,and Sweats
Multiple Operating
Systems Support
Model
Weight
Color
Driver
Bluetooth version
Audio codec
Battery capacity
Charging time
Charging port
Water resistance
AirBuds 60
Black/White
13mm dynamic driver
20 ~20KHZ
BT 5.3
SBC/AAC
500mAh
USB Type-C
IPX4 (earbuds)
