Blackview XPLORE 1 Pro Thermal lmaging Rugged 5G Phone with 6.78" 120Hz Main & 2.01" Secondary Display 20000mAh & 170LM Flashlight
Sale price £344.00 Regular price £448.00
XPLORE 1
5G
Pro
See the Heat. Conquer the Extreme. Powered by the Clearest FLIR®
Lepton 3.5 — Wider. Smarter. Tougher.
Thermal Beyond Compare
XPLORE 1 Pro × FLIR ® Lepton 3.5 See Beyond Heat. Conquer Beyond Limits. Powered by FLIR®, the world leader in thermal imaging, XPLORE 1 Pro lets you see what others can’t — uncover hidden heat, detect problems before they strike, and capture every thermal detail with professional precision.
See Sharper. Feel Deeper. Reach Wider. Industry’s Only FLIR® VividIR™ | Exclusive MSX® Fusion | 57°FOV Wider View
Industry’s Only Clarity Algorithm
FLIR® VividIR™ Tech for AI-Enhanced Clarity Every Detail, Instantly Clear With FLIR® VividIR™, thermal images become sharper and clearer—less noise, more detail. Whether you’re spotting hidden heat sources, analyzing equipment, or ensuring safety, open VividIR™ for next-level clarity.
FLIR® VividIR™ Activation
Exclusive Image Fusion
FLIR MSX® Mode for Detailed Thermal Image Embossed Outlines, Sharper Vision FLIR MSX® fuses thermal and visual images, embossing sharp outlines and key details—making objects instantly recognizable for clearer inspections, faster analysis, and smarter decisions every time.
MSX® Strength Adjustment Picture-in-Picture Mode
Visible/Thermal Image Blending Adjustment
Industry’s Widest Thermal View
57°FOV Broader View
See More, Heat Beyond Frame With a 57° wide thermal view, capture broader scenes and more details in small frame—making inspections faster, area coverage greater, and thermal imaging more complete.
57°FOV Peers 42.2°FOV
35% Wider Vision & Faster Inspections
Every Degree, Under Your Control
<50 mK Sensitivity | –10 °C – 400 °C Range
<50mK Increased Thermal Sensitivity See the Subtle Heat
With thermal sensitivity below 50mK, XPLORE 1 Pro detects even the slightest temperature differences. Subtle heat variations become visible, ensuring you never miss hidden issues.
50mk ≈ 0.05℃
Sensitive to small thermal fluctuations in air
Even the tiniest chip heat cannot hide
-10℃ to 400℃ Wide Measurement Range From Frost to Fire, Measure it All XPLORE 1 Pro captures extreme cold and intense heat. Whether inspecting freezing conditions, industrial machinery, or high-temperature equipment — nothing is overlooked.
Boiler Temperature Monitoring
Extreme Cold Research and Exploration
Flexible, Faster, Smarter for Every Scene 9 Color Palettes | 4 Image Fusion Modes | 5 Target Measuring Tools | Video Recording Support
9 Color Palettes
Highlight Heat the Way You See Best Choose from 9 color palettes to adapt to different environment and highlight subtle temperature contrasts, pinpoint hotspots.
4 Image Fusion Modes Adapt to Any Scene. See Every Detail Whether you need clarity, contrast, or context, each mode gives you the flexibility to capture and analyze heat exactly as you need.
Full Thermal Mode MSX® Fusion Mode
(Multi-Spectral Dynamic Imaging)
Alpha Fusion Mode
(All-New Picture-in-Picture)
Full Visible Mode
5 Target Measuring Tools Smart Measure,
Focus on Whats Matters
Whether monitoring large areas or focusing on specific spots, each mode gives you control, clarity, and actionable insights. Spot Measure temperature at an individual Spot
Add up to five spots per image simultaneously
Full Frame Display temperature for the entire scene
Rectangle Display temperature for a specific rectangular area
Circle Display temperature for a specific circle area Line Track temperature along a line in the frame
3 Recording Modes Snap, Record, Track Your Heat Whether capturing a single moment, continuous footage, or tracking changes over time, these three modes give you full control, flexibility, and insight.
Photo Video
Time-lapse
[Industry’s Only]
(Automatically capture interval images and then create time-lapse videos for monitoring gradual thermal changes —— See the Changes, Not just the Moment)
4 Efficient Heat Monitoring & Analyzing Tools See, Track, and Understand Heat Instantly From instant alerts to professional reports, these smart tools help you detect, analyze, and share thermal insights with ease and precision.
Dynamic Isotherm Mark a specific temperature range with a highlight color
Smart Timer Set a 3s or 10s timer to capture thermal or visible images hands-free, avoid shaky shots, plan your framing
Smart Alerts & PDF Report Set your target temperature range, receive real-time alerts when temperatures reach the preset limits, and then you can instantly generate PDF reports from thermal images for easy sharing with colleagues or clients.
step 1 Set Warning Temperature
step 2 Automatically take Photos
step 3 Send Reminder
step 4 Generate Report
FLIR SDK Mobile Support Become a Developer and Create a Brand New App With FLIR Mobile SDK (Software Development Kit), Developers can utilize FLIR interface to integrate thermal imaging or thermal sensing capabilities to their own apps. Convenient for further development by Android/iOS users.
Ready for Every Challenge — Thermal Imaging
Tailored to Your Needs
Medical & Biological Monitoring
Infant & Child Care Temperature Screening Local Inflammation Detection
Industrial & Equipment Maintenance
Electrical Inspection Mechanical Monitoring Pipelines &
Boilers leaks Identifying
Building & Energy Management
Thermal Loss Detection HVAC & Pipes Monitoring Solar Panels Inspection
Field Exploration & Wildlife Observation
Wildlife Monitoring Energy & Geological Surveys
Security & Safety
Night Surveillance Fire Warning
Industry-leading 2m for 30mins Water
Resistance, 1.5m Death-broke Drop-proof,
Protection, 6m Free-fall Durability
Beyond the Limits, Conquer Every Extreme
The Waterproof & Dustproof Benchmark
Leading IP68 &IP69K & MIL-STD-810H Certified Weather Any Storm, Conquer Any Terrain With leading IP68 and IP69K water and dust resistance, XPLORE 1 Pro is built to offer 360° protection against water and even the finest dust particles. Moreover, certified by the strict MIL-STD-810H standard, it effortlessly withstands accidental drops, intense shocks, or extreme temperature swings from ice to fire.
2m for 30mins
[Industry’s Only]
1.5m Death-broke Drop-proofness
2m for 30mins
Peers 1.5m for 30mins Peers
33% Deeper Water Resistance
25% Higher Drop Resistance
*All data from Blackview Lab.
Please note that real-world performance may vary.
Glove Mode 2.0
8%
Increased
Touch
Sensitivity
Underwater Camera
All-round Defense, All-round Toughness
360° Water-, Dust-, and Drop-resistance,
Every Chosen Material, Rigorously Tested and Proven,
Fearless of Any Challenge
Finely woven, small-
aperture earpiece mesh
[Industry's Only] Dual-Layer Sealed USB Port
Waterproof Even Without the Plug
Raised Impact Corner
High-quality silicone waterproof rings for
camera and side buttons
Corning® Gorilla Glass®
5 Screen
Partial Aerospace-grade
Aluminum Alloy Shell
6m Free-fall Drop,
Unscratched
Withstand up to
500kg of Pressure
Tumble Test
5000+ Times
Mini Drop Test
10,000+ Times
Multi-angle Drop Test
1000+ Times
HB Flame Retardant
Certification
Super-bright
Dual LED Flashlights
Light up Your Way, Stay Safer All the Way
Provide an expansive beam, lighting up your way ahead when you need most to redefine clarity and safety in the toughest environments, from night field work or hikes to outdoor emergencies and
rescues in the deep dark.
170-lumen Max Brightness
Up to 18 Meters Max Beam Range
Up to 45hrs Prolonged Runtime
SOS Mode Increased Safety↑
Detect Dangerous Creatures in Advance
Avoid Stepping into Pits and Traps
Use SOS Mode in
Emergencies to Get Yourself Spotted
Help Night-shift
Workers Perform Tasks More Accurately
New Benchmark in All-in-One Control
Advanced Infrared Remote Control Your Phone, Your Universal Remote With an advanced Infrared Remote Control feature built-in, XPLORE 1 Pro transforms into your pocket universal remote, allowing you to command everything while bringing endless convenience to your adventures and daily life.
All-in-one remote for almost any
device that uses an IR remote, including
TV
Air conditioner
Set-top box
DVD player
Projector
Fan
IR-controlled lighting
Others
6.78-inch 2.4K 120Hz Eye-care Display,
Immersive Visual Experience from Every Detail
Dual Screens, Doubled Efficiency
King of Immersive Visuals
6.78-inch 2.4K 120Hz Immersive Display Crystal-clear Detail, Boundless Vision
The 6.78-inch 2.4K 120Hz screen on XPLORE 1 Pro offers you a large visual space where details pop and colors come alive. Movies or games, fully immerse yourself in the content with unparalleled clarity.
1080*2460 Resolution
86% Screen-to-body Ratio
120Hz Dynamic Refresh Rate
700 Nits Brightness
FHD+ IPS Panel Type
240Hz Touch Sampling Rate
Authoritatively Certified, Better Eye Comfort
Peers
1.5x Clearer
More Silk-smooth Scrolling
Industry's Premier Tool for Multi-Tasking
Seamless Split Screen Double the Apps, Double the Productivity Stop switching back and forth between apps. Watch videos while chatting, compare notes while browsing—Split Screen keeps you productive and entertained without missing a beat.
Industry’s Pioneer in Sub-Screen
Multi-functional 2.01-inch Sub-screen All You Need, At a Glance With a secondary screen on the rear of XPLORE 1 Pro, you can acquire key information and notifications without having to access the main screen. Besides, there are multiple watch faces for you to personalize your style.
2.01-inch Size
240*296 Resolution
Panda Glass Material
Stay Covered, Stay Connected
Everything You Need, Right on Your Sub-screen
Check the Time
Play/Pause/Skip Tracks
Accept/Decline Calls
Check Notifications
& Alerts
Quickly Check the
Weather
Monitor Your Steps
Find Way with the
Compass
Quicker
and Easier Selfies
Personalize
Your Watch Faces
Smart-K Box Speaker Immerse in Sound, Ignite Your Senses
The Smart-K Box speaker on XPLORE 1 Pro allows you to feel the rhythm, feel the power, and dive into a world where every beat and melody comes alive with unparalleled clarity and intensity.
20,000mAh Battery Beast, Robust
for Any Adventure Power Beyond Limits,
Charge Quicker than Ever
Industry’s Power Peak
20,000mAh Battery Beast Power Reigns, Go Further, Conquer All Keep you connected, powered up, and ready for anything, no matter where life takes you. Once fully charged, you can enjoy 1008 hours on standby. Power never runs out, and your adventurous expeditions will never cease.
1=4 20,000mAh mega battery
≈ 4x mobiles of regular battery capacity
Video 23hrs
Game 20hrs
Web 38hrs
Music 58hrs
Calling 84hrs
Standby 1008hrs
*Data tested by Blackview Lab. Actual use may vary depending on usage and environmental conditions.
Focus
Computing 2.0
Performance Mode
10%
Better CPU Performance
Power Saving Mode
4hrs
Longer Daily Use AI Super Power-Saving Algorithm
Intelligent Charging
Protection
Extended Battery Life
AI Smart Charging
Protection Algorithm
55W Fast Charging No More Waiting, Power up Faster
Go from empty to full in less time with XPLORE 1 Pro’s 55W fast charging. Whether it’s a quick lunch break, a brief rest, or a transition between tasks, just a few moments of charging inject massive power into your ultra-large battery. * The charging dock isn’t included. Opt for the charging dock for
a seamless power-up experience.
55W Wired Fast
Charging
Class-Leading Speed
Dock Charging
45W Wireless
Charging Dock
5W Reverse Charging Share Power, Always Ready
XPLORE 1 Pro is more than a rugged phone; it’s a portable power bank as well, ready to recharge your other devices, from earbuds to smartwatches, ensuring you stay connected and entertained on and on.
TWS Earphone IQOS Mobile Phone Digital Camera Smart Watch
Switch Tablet Mini Speaker USB Fan Camping Light
Peak Speed with 6nm 5G Dimensity 7050 AI Soc,
Ready for Everything You Do
Power Through Tasks, Speed Through Games
The Performance Iron Triangle
6nm 5G MediaTek Dimensity 7050 Smoother, Faster, Stronger
Featuring the octa-core 5G MediaTek Dimensity 7050, XPLORE 1 Pro unleashes lightning-fast speeds. From seamless multitasking, instant app launches, and breathtaking graphics, all in the palm of your hand.
6nm EUV Process 5G Dual Carrier Aggregation MediaTek NPU 550 AI
Accelerator
More Powerful Computing &
Higher Efficiency
Faster Network Speeds
& Wider Coverage
Faster and More
Energy-saving AI Features
2*A78@2.4GHz+
6*A55@2.0GHz
UP to 2.4GHz Clock Speed ARM Mali-G68 MC4
HyperEngine Tech 2.0
2.4+5GHz
Dual-band
WiFi 6
3x
Faster than
WiFi 5 Tech
AnTuTu Benchmark
601,430+ (V10.5.1)
Up to 48GB RAM+512GB ROM +
Up to 2TB TF Expansion
Power Through Anything, Store Everything
Experience unparalleled speed with up to 48GB RAM, enabling you to juggle countless apps, heavy games, and demanding tasks without a hitch. Coupled with a massive 512GB ROM and 2TB TF expansion, you’ll have ample room for all your photos, videos, files, and more.
Atomized Memory 2.0
9%
More RAM Available
LPDDR5 + UFS4.0
1TB More TF Expansion
≈221.6K+ More Photos
≈26.4K+ More Short Videos
≈400K+
More Songs
5,480mm² Integrated Cooling System Stay Cool, Stay Ahead Boasting a 5,480mm² heat dissipation area, XPLORE 1 Pro can stay cool and maintain optimal performance, even during marathon sessions. No more overheating, just pure performance.
Up to 48GB RAM=
16GB RAM + 32GB Expansion
35% Faster Response Speed
Copper Foil 900mm²
Graphite Sheet 4,400mm²
Thermal Silicone 180mm² Peak Temperature at 38℃ under CPU-intensive Games
64MP Main & 50MP Selfie & Clearest Thermal Camera
Every Moment, Vividly Captured
From True Color to True Heat
Flagship Imaging System
Triple-camera Setup
All Scenes, All Mastered
Main Camera
64MP
(f/1.79)1/2″
6P
Thermal Camera
Front Camera
50MP
Samsung® JN1
(f/1.8)1/2.76″
5P
64MP Main Camera Day or Night, Shine So Bright The 64MP main camera on XPLORE 1 Pro can capture every epic moment, day or night, transforming every shot into a masterpiece, regardless of the conditions. Each photo, seemingly still, is vividly alive.
4-in-1 to 1.4μm Super Pixels
1/2" Pixel Sensor Size
6P Ultra Clear Lens
f/1.79 Large Aperture
Class -Only
8x Optical Zoom
Capture Every Detail, Near or Far
Quad-Bayer Output
4-in-1 to 1.4μm
super pixel to enhance
light sensitivity
Color Filter Array
Better Capture
of Light and Color
Information
PDAF Tech
Faster and
More Accurate
Autofocus
Smooth Exposure
Control
Seamless Brightness
Transition
Optical Zoom
Sharp and Clear
Digital Zoom
Pixelated and Blurry
50MP Samsung® JN1 Selfie Shooter Every Detail, Frame Your Brilliance
Equipped with a stunning 50MP front camera, XPLORE 1 Pro delivers sharper, clearer selfies and crystal-clear video calls. From vlogging on the go to spontaneous video chats, always
present your best self with unparalleled clarity.
F/1.8 Large Aperture
5P High Light Transmission
1/2.76" Pixel Sensor Size
2x
Clearer Selfies
4K Crystal-clear Video Recording
Relive Every Moment, In Lifelike Detail Bring every laugh, every vibrant sunset, and every intricate detail of your story to life in vivid 4K at 30fps, ensuring you can relive them with unparalleled clarity and realism, just as they unfolded.
Peers
2K
4x Clearer
Smart Stabilization.
Effortless Clarity
True-Chroma Image 2.0 See True, Capture True
Bring your photos to life with incredible color accuracy and richer details, ensuring what you capture is as vivid and true-to-life as what you see, perfect for photography enthusiasts and everyday users alike. Smart Shooting Assistance
Perfect Shoots, Easy Control
Level Tool & Center Marker Steady Shots, Precise Focus
3x3 Grid Lines Grid your way to perfect photos
Vibration Feedback Responsive Touch, Perfect Control
Blackview x Doke AI 2.0, Speak to Control,
Smarter to Operate Powered by DeepSeek-R1,
ChatGPT, Gemini AI 2.0 Flash
Upgraded Doke AI Hand-free Anytime, Anywhere
Simply speak to wake XPLORE 1 Pro, keeping you effortlessly connected, in control, and one step ahead. It’s your hands-free helper, instantly understanding and seamlessly responding across all apps, screens, and situations.
AI Voice Wake-up
AI Full-screen Smart
Assistance
AI Smart Global Control
AI Smart Voice Interaction
AI Real-time Conversation
Hi Doki APP
Voice to Vision,
Ideas Unleashed
Experience lightning-fast,
deep-thinking AI search, effortless
document analysis, and smart writing assistance, unlocking smarter insights and boundless creation.
AI Text to Image
AI Image to Image
AI Music
Composition
AI Online Search
AI Document
Parsing
Smart Q&A with
DeepSeek-R1
AI Tutoring
Assistant
AI Role Chat
ImageX App
From Novice to Pro,
Make Every Post Go Viral
Boasting up to 18 powerful AI editing tools, it allows you to easily edit your photos and make every post of yours shine with new life and instantly go viral!
VidGen App
Bring Your Stories to Life,
Create Video in a Click
From daily v-logs, creative shorts, or exciting moments, it can revitalize your videos with intelligent AI tech! Simply input text or images, and watch as AI generates stunning videos, turning your words and pictures into an unforgettable visual feast.
AI Text-to-Video
AI Image-to-Video
Soundle App Your BGM, Your Way
Freely adjust the style, mood, instruments, and rhythm, and even write your own lyrics, making each BGM unique. From spark to symphony, your music, your way. *All Doke apps above offer a 30-day free trial to let users fully experience the convenience and excitement.
Industry’s Only Self-Developed DokeOS 5.0
Based on Android 15
Customization↑ Convenience↑ Fluency↑Privacy↑
Simply the Smartest
Blackview’s Next-Gen DokeOS 5.0 Fully Upgraded, Hardcore Ready Fully upgraded from DokeOS 4.2 (Android 15) to OS 5.0 (Android 15), XPLORE 1 Pro delivers ultra-smooth performance, smarter power optimization, and effortless convenience—bringing faster operations, longer battery life, and a truly intelligent everyday experience.
Convenience at Your Fingertips XPLORE 1 Pro delivers a more convenient experience with a series of upgrades like streamlined desktop, smarter system manager, and efficient camera—everything works faster and smoother.
Smarter Desktop, Faster Flow
Organized App Drawer Sort by Letter, Usage, or Category
Accessible Large Folders One-tap Access to Key Apps
Secure Desktop Edit New Uninstall Confirmation Popup
Streamlined Interface, Smoother Experience
Notification/
Control Center
Side by Side,
More Efficient
Lock Screen
Shortcuts
Add Third-Party
Apps Freely
One Tap to Clean. One Breath to Free Upgraded System Manager
From files to apps, fully optimize your storage for a lighter, smoother phone experience.
One-Tap Clean Instantly clear junk and
free space
Category Cleanup Clean videos, photos,
docs—your way
App Deep Clean Wipe app caches,
run like new
Idle App Detection Spot unused apps,
uninstall freely
System App Uninstall Remove preloads,
keep it pure
Easy Reinstall Restore deleted apps
with one tap
Camera: A Complete Upgrade from Daily to Pro From casual snaps to pro shots, the camera adds versatile features for faster, freer, and more precise photography.
Rich Filters One tap to
create cinematic vibes
Quick Access Tools Grid, watermark,
leveler,haptic feedback—all
within reach
Center Mark & Leveler Sharper composition,
steadier frames
Enhanced Pro Mode Adjust color temperature
& choose from
3 metering modes
Next-Level Notebook, Smarter Organization Now smarter than ever, the Notebook app is fully upgraded with faster search, intuitive organization, secure saving, diverse ways to capture ideas, and timely reminders.
Find Faster
Universal Search Notes, To-Dos, Voice Recordings—
All in One Search
Flexible Folders Create Folders in Notebook and
Move Notes freely to Folders
Smart Sorting Sort by Creation Date or
Update Date
Manage Better
Bulk Actions Pin, Encrypt, Delete, Move,
and Export.
Safe Deletion Delete Confirmation, Restore
from Recycle Bin
Flexible Export Formats Supports Word and TXT
Write More
Rich Text Effects Highlight, Strike-Through,
Listing Icons, and Custom
Text Colors.
Doodles Diverse Brushes, Erasers,
and Colors.
Never Forget
Reminders Alerts with Repeat &
Priority options
Upgraded Game Mode, Higher Performance From zero interruptions to sharper control and highlight recording, Game Mode optimizes every match for focus and flow.
No Interruptions Block Notifications and Calls
Anti-Mistouch Precise Control, Every Tap Counts
Smart Modes Three Performance Modes for Any Game Intensity
Capture Highlights One-Tap Recording and Screenshots
Upgraded Search Center,
Find Everything
News Hub Hot topics from all sources
One-Tap Access Instant Search,
Directly Reach the Answer
Smarter Weather Forecast,
Instant Insights
Live Scenes Sun, Rain, Snow in Motion
Practical Tips Outfit, Travel,
and Activity Suggestions
Smoother Interactions, Seamless Flow
Screen on/off Fluid and Instant
Screen Unlock Natural Transitions,
Multiple Effects
More Convenience For You to Explore
EasyShare App 77x Faster than
Wireless BT
Workspace App Balance Your Life
and Work
Focus Mode Your Space for Deep Work
Surfline APP Your Ultimate
Surf Companion
Data Migration
Assistant
Move Everything,
Hassle-Free
Infinite Personalization,
Make it Uniquely Yours
For a more vibrant and unified look,
XPLORE 1 Pro brings richer wallpapers, themes, and colors for refreshed interfaces.
Expanded Wallpaper Center A Rich Collection Including Rugged Style,
Live and Textured Wallpaper
More Diverse Themes Multiple Theme Styles to Match Your Taste
Refined Color Styles Versatile Color Schemes for
Easy Interface Customization
App Interface Refresh Core Apps Fully Updated With
a More Unified Look
Upgraded Magnifier See Clearly, Effortlessly
Display Size and
Text Customization
Tailored Readability, Just for You
Advanced Storage Optimization,
Faster Performance
Cold Room App
Atomized Memory 2.0
Safe, Private, Always Designed for peace of mind, XPLORE 1 Pro keeps you safe and in control, giving you the freedom to enjoy your digital life without compromise.
Enhanced
Media Permissions
Customize App Access to
Your Media Files
Private Space Establish a Secure Zone to
Store Sensitive Files
Child Mode A Safe and Simplified
Interface for Kids
App Lock Robust Protection for Your
Apps And Sensitive Data
Useful Features to Explore,
More Seamless and Effortless Every Day
Face & Fingerprint Unlock
L1+L5
Dual-band GPS+Beidou+
Glonass+Galileo+QZSS
≤5 Meters
More Accurate Pinpoint Precision
Multifunctional NFC
Precision Gyroscope
Dual-SIM Slot Dual 5G SIM Dual Standby
Global Connectivity
Customized Shortcut Button
Start Soundrecording
Open flashlight
Screenshots
Open UnderWater Camera
Open PTT
Open SOS
Comprehensive Offline & Online After-Sales Care Quick, Professional, and Always Here for you
24/7
Online Support
Get help anytime,
anywhere.
Offline
Repair Centers
Expert technicians,
genuine parts.
3 Years of
Android Updates
Always fresh, secure,
and up to date.
2-Year Extended
Warranty
Peace of mind for the
long haul.
Learn More
Blackview XPLORE 1 Pro Specifications
  • Model
    XPLORE 1 Pro
  • Color
    Black, Orange
  • Dimension
    184*83*29.5mm
  • Weight
    640g
  • OS
    DokeOS 5.0 Based on Android 15
  • Display
    6.78-inch 2.4K FHD+IPS, 1080*2460 Resolution,
    Corning® Gorilla® Glass 5,
    120Hz Refresh Rate,
    Secondary Screen: 2.01-inch, 240*296 Resolution
  • CPU
    Octa-core 5G MediaTek Dimensity 7050, 6nm, Up to 2.4GHz
  • RAM & ROM
    12GB RAM & 256GB ROM, LPDDR5+UFS3.1
    16GB RAM & 512GB ROM, LPDDR5+UFS4.0
  • TF Expansion
    Up to 2TB Expansion
  • Battery
    20,000mAh; 55W Fast Charging
  • Front Camera
    50MP (Samsung® ISOCELL JN1)
  • Rear Camera
    64MP
  • Speaker
    1PC 1134 Smart-K BOX Speaker
  • Rugged Rating
    IP68 &IP69K& MIL-STD-810H
  • Navigation
    GPS/GLONASS/BeiDou/Galileo/QZSS( L1、L5)
  • Glove Mode
    Support
  • NFC
    Support
  • Dual 5G VoLTE
    Support
  • Wi-Fi&Bluetooth
    IEEE802.11a/b/g/n/ac/ax (2.4GHz/5GHz); BT 5.2
  • Network Connectivity
    3G Band:
    WCDMA: B1/B2/B4/B5/B6/B8/B19,
    CDMA: BC0/BC1/BC10
    4G Band:
    TDD: B34/B38/B39/B40/B41
    5G Band: N1/3/5/7/8/20/28/38/40/41/77/78
