Blackview ROCK 5 Hi-Fi Stereo Speaker Camping Light Rugged 4G Cellphone with 6.78-inch 2.4K 120Hz Display 108MP Camera & 20,000mAh Battery
Hurry up, only 6 items left in stock.
✔5W High-Quality Hi-Fi Stereo Sound Speaker
✔348LM Ultra-Bright Camping Lantern
✔108MP Samsung® ISOCELL HM6 & 20MP Night Vision Camera
✔Octa-core MediaTek Helio G100,20,000mAh & 33W Fast Charging
✔Top-Tier IP69K/IP68 & MIL-STD-810H Certified
The Blackview ROCK 5 is built for users who need power, sound, light, and durability in one rugged 4G phone. Its massive 20,000mAh battery keeps you connected through long outdoor trips, work shifts, and emergencies, while the 5W Hi-Fi stereo speaker and 348LM camping lantern add real utility beyond a regular smartphone. A 6.78-inch 120Hz display, MediaTek Helio G100 processor, 108MP main camera, and 20MP night vision camera make it ready for entertainment, navigation, photography, and field use. With IP68/IP69K protection, it is made for tough conditions.
| Design | |
| Product | Blackview ROCK 5 |
| Color | Black |
| Dimensions | 184 × 83 × 29.7 mm |
| Weight | 635 g |
| OS | DokeOS 5.0 based on Android 16 |
| Display | |
| Main Display | 6.78-inch IPS display |
| Resolution | 1080 × 2460 |
| Refresh Rate | 120Hz |
| Touch Sampling Rate | 180Hz |
| Brightness | 700 nits |
| PPI | 396 |
| Screen-to-Body Ratio | 86% |
| Glass | Panda Glass |
| Streaming | 1080P Widevine L1 Support |
| Performance | |
| CPU | MediaTek Helio G100 |
| CPU Clock | 2 × Cortex-A76 2.2GHz + 6 × Cortex-A55 2.0GHz |
| GPU | Mali-G57 |
| RAM & ROM | 6GB / 12GB RAM + 256GB ROM |
| Memory Type | LPDDR4X + UFS 2.2 |
| RAM Expansion | Up to 36GB expansion |
| TF Expansion | Up to 2TB |
| Camera | |
| Front Camera | 50MP Samsung® ISOCELL JN1 |
| Rear Camera | 108MP Samsung® ISOCELL HM6 main camera + 20MP night vision camera |
| Night Vision | 20MP night vision camera with IR fill light |
| Video Recording | 2K video recording at 30fps |
| Camera Features | Smart Google Lens, Motion Photo, AI Photos, 8x Zoom, Pro Mode |
| Battery & Charging | |
| Battery | 20,000mAh |
| Charging | 33W fast charging |
| Reverse Charging | 5W reverse charging |
| Battery Life | Up to 2280 hours standby, 88 hours calling, 37 hours web browsing, 36 hours camping lantern, 23 hours navigation |
| Audio | |
| Speaker | 5W Hi-Fi stereo sound speaker |
| Audio Features | Up to 138dB max speaker output, SOS alarm bell, high-quality Hi-Fi stereo sound |
| Outdoor Light | |
| Camping Lantern | 348LM ultra-bright camping lantern |
| Lighting Range | Up to 10 meters |
| Lighting Power | 3.2W max power |
| Lighting Modes | Low, High, Ultra-Bright, SOS Mode, Quick Flashing Mode |
| Lighting Duration | Up to 36 hours |
| Durability | |
| Rugged Rating | IP68 / IP69K / MIL-STD-810H |
| Water Resistance | 1.5m submersible for 30 minutes |
| Drop Resistance | Up to 6m drop proof |
| Crush Resistance | Up to 500kg crush resistant |
| Operating Temperature | -20°C to +60°C |
| Build Protection | Scratch-resistant Panda Glass, reinforced shockproof corners, aviation-grade aluminum alloy frame |
| Connectivity | |
| Network | 4G, 5G not supported |
| Wi-Fi | IEEE 802.11 a/b/g/n/ac, 2.4GHz / 5GHz |
| Bluetooth | 5.2 |
| NFC | Yes |
| Card Slot | 2 × SIM / 1 × SIM + 1 × TF |
| USB | Type-C |
| Network Bands | |
| 2G | B2 / B3 / B5 / B8 |
| 3G | WCDMA: B1 / B2 / B4 / B5 / B8; CDMA: BC0 / BC1 / BC10 |
| 4G | FDD: B1 / B2 / B3 / B4 / B5 / B7 / B8 / B12 / B13 / B17 / B18 / B19 / B20 / B26 / B28A / B28B / B66; TDD: B38 / B40 / B41 |
| 5G | No |
| Navigation | |
| Positioning | GPS / GLONASS / Galileo / BeiDou / QZSS |
| Sensors | |
| Sensors | G-sensor, P-sensor, L-sensor, gyroscope, compass, magnetic sensor, fingerprint sensor |
| Extra Features | |
| AI Features | Doke AI, Hi Doki voice assistant, Gemini AI, AI Chat, AI Photos, AI Video, AI Music |
| Outdoor Features | Glove Mode 2.0, underwater camera, one-tap dust and water expel, AI rainproof touch, customized shortcut button, ToolBag |
| Other Features | FM, OTG, fingerprint unlock, dark mode, reading mode, night light, smart ambient light, 3 years of Android OS updates |
Who is the Blackview ROCK 5 rugged phone designed for?
The Blackview ROCK 5 rugged phone is ideal for camping enthusiasts, hikers, construction workers, field technicians, and anyone who spends long periods working outdoors. It is also a great choice for users who are frequently away from power sources and prioritize battery capacity and practical outdoor features.
Its massive 20,000mAh battery delivers long-lasting power for outdoor trips and daily work, while its dustproof, waterproof design lets it withstand harsh outdoor conditions. For instance, campers can use the built-in light to illuminate their campsite, and field workers can use it to light up dim areas during inspections. Additionally, the night vision camera helps users observe their surroundings at night.
Is the Blackview ROCK 5 a suitable rugged phone for camping?
Yes. The Blackview ROCK 5 integrates several highly practical features for camping trips. For example, you can use the built-in light to set up camp after dark, use the night-vision camera to check your surroundings, or use the reverse charging function to power up other compatible devices.
Before heading out, it is recommended to download necessary maps, check network coverage along your route, and fully charge the phone. Since lighting, navigation, and reverse charging all consume power, it is important to plan your energy usage wisely based on the duration of your trip.
Is the Blackview ROCK 5 a suitable rugged phone for construction workers?
Yes, the ROCK 5 rugged phone offers many features ideal for construction sites. Its dustproof and waterproof capabilities handle the challenges of the daily environment, while "Glove Mode" allows for easy screen operation without the need to constantly remove and put on gloves. Additionally, the built-in light provides illumination in dim areas, and the camera can be used to document construction progress.
Its large-capacity battery ensures long-lasting power when there is no time to charge during work. Due to the phone's weight, carrying it in a waist pouch is recommended for greater comfort compared to keeping it in a pocket.
What charging speeds does the Blackview ROCK 5 rugged phone support?
The Blackview ROCK 5 rugged phone supports wired fast charging at up to 33W. Whether you are topping up before a camping trip or plugging in after work, you can quickly and conveniently fully charge its high-capacity battery. For optimal charging performance, simply use a compatible charger and cable.
Charging speed is affected by battery level, temperature, and the phone's usage status. It is normal for charging to slow down as the battery nears full capacity. To speed up charging, it is recommended to pause games or navigation apps and keep the screen off while charging.
Can the Blackview ROCK 5 charge other devices?
Yes. The ROCK 5 supports wired reverse charging at up to 5W, allowing it to transfer power to compatible smartphones, wireless earbuds, or other devices that support this feature.
Before use, please ensure your cable is compatible or check if an OTG adapter is required. Given the 5W output, it is better suited for emergency top-ups rather than rapid charging. Please note that this process consumes the ROCK 5's own battery power, so ensure you retain enough charge for your own daily needs.
Does the Blackview ROCK 5 rugged phone support 5G?
No, it does not. The Blackview ROCK 5 is a 4G rugged phone and cannot connect to 5G mobile networks. However, its supported 4G networks are capable of handling daily mobile tasks (such as web browsing, messaging, and streaming); actual performance depends on network coverage and conditions.
How can I check whether the Blackview ROCK 5 works with my mobile carrier?
First, check the network frequency bands supported by the ROCK 5 in the "Specifications" section and compare them with the bands used by your carrier. Next, consult your carrier to confirm whether the device supports calling, mobile data, and VoLTE functions.
If your carrier offers a device compatibility checker, it is recommended to use that tool and provide the required information. Additionally, if you plan to take the phone abroad, you should check for compatibility and roaming service options at your destination.
How water-resistant is the Blackview ROCK 5 rugged phone?
The ROCK 5 features IP68 and IP69K ratings. It has passed tests involving immersion in water up to 1.5 meters deep for 30 minutes. However, the phone should not be subjected to constant water exposure, and water resistance capabilities may degrade over long-term use (e.g., 2–3 years).
If the phone comes into contact with water, please follow the maintenance instructions and ensure the charging port is completely dry before plugging in a charging cable. Additionally, we recommend reviewing the warranty terms, as "water resistance performance" and "warranty coverage for water damage" are distinct concepts.
Does the Blackview ROCK 5 rugged phone have a night vision camera?
Yes. The ROCK 5 is equipped with a 20MP night-vision camera featuring an infrared (IR) illuminator, allowing you to view and photograph nearby objects in the dark. It is highly convenient for use in low-light areas or for outdoor photography at night. However, image quality may be affected by factors such as the distance to the subject, obstacles, and the infrared reflectivity of the object's surface.
Please note that this is a night-vision function, not thermal imaging technology; it cannot measure temperature or display heat distribution images. When walking or working in the dark, it is advisable to use additional lighting equipment to ensure you can clearly see the path ahead.
What lighting modes does the Blackview ROCK 5’s camping light offer?
The camping light on the ROCK 5 rugged phone features five modes—low, high, ultra-high, SOS, and rapid flashing—with a maximum brightness of 348 lumens. You can select a lower brightness setting for close-range tasks or switch to high brightness when more illumination is required. Additionally, the flashing modes can help attract attention and signal your location to others.
Please choose the appropriate brightness setting for the task at hand; there is no need to keep the light at maximum brightness constantly. High-brightness settings consume more power, so the duration of illumination will vary depending on the selected mode and other phone usage.
What are the benefits of the Blackview ROCK 5 rugged phone’s built-in loudspeaker?
The ROCK 5 features a built-in 5W speaker that allows you to play music, listen to navigation prompts, or enjoy other audio content at any time. It is convenient to use whether you are at a campsite, taking a break at work, or sharing audio with those around you.
Actual listening quality may be affected by ambient noise, your distance from the phone, and volume settings. We recommend adjusting the volume based on your environment and the people around you. If you are unable to charge the device for an extended period, it is advisable to pause audio playback.
Can I use the Blackview ROCK 5 rugged phone while wearing gloves?
Yes. The ROCK 5 supports "Glove Mode 2.0," which optimizes the touchscreen experience when wearing gloves. You can check messages, browse maps, or use various apps without frequently removing your gloves.
Touch sensitivity may vary depending on the material, thickness, and fit of the gloves; we recommend testing the device with the gloves you normally wear. Please follow the user manual to enable this feature and verify that tapping and swiping actions are smooth enough to meet your daily needs.
What is the difference between the Blackview ROCK 5’s 6GB and 12GB RAM versions?
Both versions come with 256GB of storage; the main difference lies in the physical RAM—you can choose between the 6GB or 12GB model. The 6GB version is perfectly adequate for daily tasks such as messaging, web browsing, and navigation. However, if you frequently switch between multiple apps or run performance-intensive applications, the 12GB version is a better choice as it offers more ample memory.
It is important to note that having more RAM does not mean processing speeds for all tasks will double. Additionally, one should distinguish between physical RAM and the "memory expansion" feature, which converts a portion of the storage space into virtual memory.
How much does the Blackview ROCK 5 rugged phone weigh, and how thick is it?
The ROCK 5 weighs approximately 635g and is 29.7mm thick, with overall dimensions of 184 × 83 × 29.7mm. If you are accustomed to the slim, lightweight phones used in daily life, you will notice its substantial weight; you will need to consider how to carry it when working or heading outdoors.
For extended periods of carrying, using a pouch or a carry bag may be more comfortable. If you plan to use a car mount or other mounting hardware, it is recommended to check the size range and weight limits beforehand to ensure the device can securely support the phone.
What are the benefits of a rugged phone with a 20,000mAh battery?
A high-capacity 20,000mAh battery provides ample power reserves for situations where charging is inconvenient—such as camping, working long shifts, or relying on the phone for navigation and communication. It can also power camping lights and supports reverse charging to replenish other compatible devices.
Actual battery life depends on factors such as screen brightness, signal strength, ambient temperature, and daily usage habits. The trade-off for this large battery is increased size and weight; however, if battery capacity is your top priority, it is an ideal choice.
