Blackview ROCK 2 Pro 6.67-inch 120Hz Display 8+256GB 400LM Camping Light 15000mAh 5G Rugged Phone
Hurry up, only 1 item left in stock.
✔6.67-inch 120Hz Smart Refresh Rate Display
✔Built-in Dual 400LM Camping Light
✔5G 6nm UNISOC T8100 Octa-core Processor
✔15000mAh & 33W Fast Charging
✔16MP AI Main + 13MP AI Front Camera
✔IP68 & IP69K & MIL-STD-810H Certified
The Blackview ROCK 2 Pro is built for users who need dependable mobile performance in demanding environments. It combines a 6.67-inch 120Hz display with UNISOC T8100 5G performance and a 15000mAh battery with 33W fast charging for work, travel, navigation, and outdoor use. Key field-ready features include 16MP rear and 13MP front AI cameras, dual 400LM camping lights, and IP68 & IP69K & MIL-STD-810H protection. Designed for job sites, remote trips, and everyday toughness, it gives users the confidence to stay connected, capture details, and keep going when regular phones are not enough.
Faster 5G, Brighter Light, Unstoppable Power
Go Beyond Limits, Conquer Every Challenge
Why Choose Blackview ROCK 2 Pro?
No.1
IP69K, IP68 & MIL-STD-810H Certified,
Built to Conquer Any Extreme.
No.2
Blazing 5G with 6nm UNISOC T8100,
Experience Unmatched Speed
Smooth and Stunning
Days Standby.
Anywhere
2.0, Intelligence Beyond Limits
Based on Android 16
No.1
400lm Camping Light
Bright, adjustable, and reliable — designed to illuminate your camp and ensure safety in every outdoor adventure.
Lighting ModeThree Brightness Levels:Low/Highlight/Extremely bright
Low for power-saving, High and Ultra-Bright for versatile outdoor lighting needs.
Outdoor Camping
Outdoor Repairs
Night Hiking
SOS Mode
Sends a clear, visible distress signal to ensure your safety in critical outdoor situations.
Lost in the Wild
Vehicle Breakdown
Severe Weather Distress
Quick Flashing Mode
Ideal for emergency warnings, deterring potential threats, or quickly attracting attention.
Outdoor Defense
Roadside Warning
Emergency Evacuation
Dive. Spray. Soak. It just works.
IP69K & IP68 Certified
ROCK 2 Pro is engineered for the toughest conditions, delivering unmatched protection against water, dust, and high-pressure jets.
Seamless Screen Sealing: Flawless
waterproof performance.
Corrosion-Resistant Aluminum Buttons:
Reinforced with premium silicone seals.
TPU Sealed USB Port: Maximum dust
and water resistance.
Underwater Camera: Capture unforgettable
moments below the surface.
Speaker Cleaning: Auto-expels water and
debris for crystal-clear audio.
Drop-Proof. Dust-Proof. Battle-Ready.
From -20°C Arctic sites to 60°C desert heat, from 1.2m concrete drops to sandstorms — ROCK 2 Pro survives where others fail.
Proven through these extreme tests
Rain
Sand and Dust
Vibration
Shock
Humidity
Altitude
Acceleration
High Temperature
Low Temperature
Immersion
Reinforced Rubber Corners:
Shock absorption at its best.
Ultra-Durable Composite Back:
Built to endure.
Aviation-Grade Aluminum Frame:
Strong, lightweight, and impact-resistant.
Panda Glass Display: Scratch-resistant and
shatterproof for ultimate durability.
Glove Mode 2.0
Operate flawlessly —
even with thick gloves on.
Useful ToolBag
Compass, Torch, Magnifier, and more —
your all-in-one practical toolkit.
No.2
5G 6nm UNISOC T8100
Speed You Need. Power You Trust.
Experience blazing-fast 5G with the 6nm UNISOC T8100 chipset, featuring a powerful 2.2GHz CPU for seamless multitasking and smooth performance in demanding apps!
4*A76@2.2GHz
+ 4*A55@2.0GHz
Arm Mali G57
748,099
AnTuTu Benchmark
Up to 32GB LPDDR4X RAM
Multitask Like It's Nothing.
Multitask effortlessly—launch apps instantly, switch seamlessly, and power through work and entertainment with unwavering speed.
Up to 32GB RAM=8GB RAM + 24GB Expansion
Atomized Memory 2.0
9% More RAM Available
256GB UFS 3.1 Storage
Upgraded to UFS 3.1 for 2.4x faster speeds, lower power consumption, reduced latency, and accelerated write performance—store more, load faster, and work smarter.
ROCK 2 Pro
UFS 3.1
ROCK 2
UFS 2.2
2.4x Faster Data Transfer Speed
Efficient Heat Dissipation
Cool Under Pressure
With a 1700mm² cooling area, enjoy rapid heat dispersion for stable, smooth performance no matter how intense the task.
No.3
6.67" 120Hz Smart Eye-Care Display,
Smooth and Stunning
6.67" HD+ IPS Display
Broader View, Sharper Details
Equipped with a 6.67" HD+ IPS screen, ROCK 2 Pro delivers immersive visuals with 120Hz smart refresh and 650nits brightness — perfect for gaming, streaming, and everyday tasks.
120Hz
AI Smart Refresh Rate
650nits
Brightness
85%
Screen-to-body Ratio
720*1604
Resolution
120Hz AI Smart Refresh Rate
Smoother, Faster, Smarter
Say goodbye to lag—smart refresh adapts to your needs, ensuring silky scrolling while optimizing battery life.
120Hz
60Hz
Twice the Refresh Rate,
Twice the Smoothness
Eye-Care Modes
Comfort That Lasts All Day
Protect your eyes with four tailored modes designed for reading, working, and relaxing.
Reading Mode
Paper-like comfort for long hours of reading
Night Light
Gentle lighting to reduce blue light strain
Dark Mode
Perfect for low-light environments
Light Mode
Bright and clear for daytime use
2W High-Power Box Speaker
Powerful Sound, Exceptional Clarity
ROCK 2 Pro delivers bold, crystal-clear audio with its 2W high-power speaker, cutting through noisy environments to ensure top-tier sound for both communication and entertainment.
No.4
Massive 15,000mAh Battery,
Up to 50 Days Standby.
15,000mAh Massive Battery
Power That Keeps Up. With a gigantic 15,000mAh battery, ROCK 2 Pro effortlessly handles work trips, outdoor adventures, and daily use—no outlet hunting required.
Intelligent Charging
Protection
AI Power Saving
Algorithm
28hrs
Game
43hrs
Call
97hrs
Music
34hrs
Web Browsing
26hrs
Video Playback
50 days
*Data is tested by Blackview Lab based on continuous use. The actual use may vary depending on real-world usage conditions.
Class-Exclusive Intelligent Deep
Power-Saving Mode
ROCK 2 Pro intelligently adjusts power consumption with advanced optimization during idle periods — delivering longer battery life without sacrificing performance.
Longer Light-Use Time
Less Overnight Drain
5W OTG Reverse Charging
Share Power On the Go
ROCK 2 Pro doubles as a portable power bank, letting you charge earbuds, smartwatches, or even your friend's phone on the go.
No.5
Capture Every Moment,
Anytime, Anywhere
16MP AI Main Camera
Capture Perfectly. Share Instantly.
The 16MP AI main camera of ROCK 2 Pro delivers crystal-clear, vibrant images—whether you’re capturing professional shots or chasing the perfect sunset.
16MP
Be You—Just Brighter.
ROCK 2 Pro's 13MP AI front camera adjusts to any lighting condition, ensuring your selfies remain sharp, natural, and effortlessly stunning.
Beauty Mode
Glow Effortlessly, Naturally.
AI beauty mode enhances your skin and tone with subtle, natural adjustments—highlighting your best features with finesse.
Portrait Mode
Focus on You, Blur the Rest.
AI depth sensing highlights your subject while creating a smooth, studio-quality bokeh effect—no extra equipment needed.
Night Mode
Master the Night, Every Detail Counts.
AI night mode reveals hidden details in the dark—bright skies, sharp edges, and perfectly stable shots, no matter how dim the scene.
No.6
Exclusively Self-Developed Doke
AI 2.0, Intelligence Beyond Limits
By integrating three cutting-edge AI models, Doke AI leverages cutting-edge technology to deeply understand user needs, delivering faster, smarter, and more tailored solutions.
DeepSeek-R1
ChatGPT-4o mini
Gemini AI 2.0 Flash
Your Exclusive Smart Life Manager
Voice Activation &
Voiceprint Recognition
Unlock effortlessly with your voice —
touch-free and highly secure!
AI Global Smart Control
Manage apps and settings with ease using simple voice commands, streamlining your daily tasks.
Compatible Apps:
AI Full-Screen Assistance
Instantly provide answers and insights related
to your current screen content.
AI Real-Time Interaction
Enjoy seamless, real-time communication,
enhancing productivity in every moment.
Four Innovative Doke AI Apps to
Elevate Your Experience
AI Chat App
Your Always-Available AI Chat Companion From task planning to creative brainstorming, AI Chat is your trusted intelligent assistant, always ready to help.
Next-Gen
DeepSeek-R1
AI Online Search
Document Parsing
Tutoring Assistant
Chat with AI
AI Photos App
Your Portable AI Photo Editing Tool With 18 advanced AI features, AI Photos transforms ordinary photos into stunning visual creations, ready to impress and share.
AI Remove Objects
AI OutPainting
AI Blur Photo
AI Replace Background
AI Animate
AI Video App
Your AI Video Creation Tool
Transform text, images, and everyday moments into cinematic videos effortlessly — no expertise required!
AI Music App
Your AI Music Creation
Platform
No instruments or studio needed—AI Music empowers you to create unique music effortlessly, tailored to every occasion.
No.7
Latest DokeOS 5.0 Based on Android 16
From DokeOS 4.2 to 5.0, we've rebuilt the experience: faster, cleaner, smarter, and deeply personal. This isn't just an update—it's a leap forward in how you interact with your ROCK 2.
Do What Matters. Without the Noise.
Side Key Function
One Press. Instant Access.
Quickly activate flashlight, SOS, underwater camera, PTT, or your favorite app. Always ready, no waiting.
Start Soundrecording
Open flashlight
Screenshots
Open Underwater Camera
Open PTT
Open SOS
Quad-Core Navigation
Global Precision. Always On Track.
Powered by GPS, Beidou, Galileo, and Glonass for accurate positioning — anywhere, anytime.
Beyond the Purchase, We’ve Got You Covered.
Android Version Update
Hotline Assistance
24/7 Online Service
Trusted Offline Repair Center
Blackview ROCK 1 Specifications
| Model | ROCK 2 Pro |
| Color | Black/Yellow |
| Dimension | 187.6 * 85.8 * 26mm |
| Weight | 558g |
| OS | DokeOS 5.0 Based on Android 16 |
| Display | 6.67-inch HD+ IPS, 720 * 1604 Resolution 120Hz Smart Refresh Rate, 85% Screen-to-body Ratio |
| CPU | Octa-core 5G 6nm UNISOC T8100 |
| RAM & ROM | 8GB RAM + 256GB ROM, LPDDR4X + UFS3.1 |
| TF Expansion | Up to 512GB Expandable Storage |
| Battery | 15000mAh; 33W Fast Charging |
| Front Camera | 13MP |
| Rear Camera | 16MP |
| Speaker | 2W Box Speaker |
| Card Slot | Two; 2SIM/1SIM +1*TF Card |
| NFC | Support |
| Wi-Fi & Bluetooth | (IEEE802.11a/b/g/n/ac) (2.4GHz/5GHz) ; BT 5.0 |
| Network Connectivity | 2G Band: B2/B3/B5/B8 3G Band: WCDMA: B1/B2/B5/B8 4G Band: TDD:B38/B40/B41 FDD:B1/B2/B3/B4/B5/B7/B8/B12/B17 B19/B20/B26/28A/28B/B66 5G Band: N1/2/3/5/7/8/20/26 28/38/40/41/66/77/78 |
| Weight | 558g |
| NFC | Support |
| Wi-Fi & Bluetooth | (IEEE802.11a/b/g/n/ac) (2.4GHz/5GHz); BT 5.0 |
