Blackview ROCK 1 Pro Professional 2D Barcode Scanner 4G Rugged Phone with 6.56-inch 90Hz Display 15000mAh & Night Vision Camera
Out of stock
✔Built-in Professional 2D Barcode Scanner, EAN-13, PDF417 & QR Code Compatible
✔Equipped with 3000K White LED Light & Laser-Precise Aiming
✔6.56-inch 90Hz AI Smart Refresh Rate Display
✔Octa-core MediaTek Helio G81 Processor
✔15000mAh & 33W Fast Charging
✔20MP Sony® Night Vision Camera
✔IP68 & IP69K & MIL-STD-810H Certified
The Blackview ROCK 1 Pro is built for users who need dependable mobile performance in demanding environments. It combines a 6.56-inch 90Hz display with MediaTek Helio G81 performance and a 15000mAh battery with 33W fast charging for work, travel, navigation, and outdoor use. Key field-ready features include a 20MP Sony night vision camera and built-in 2D barcode scanner, laser-precise aiming and a white LED light, and IP68 & IP69K & MIL-STD-810H protection. Designed for job sites, remote trips, and everyday toughness, it gives users the confidence to stay connected, capture details, and keep going when regular phones are not enough.
| Model | ROCK 1 Pro |
| Color | Black |
| Dimension | 177.9*83.5*24.7mm |
| Weight | 493g |
| OS | DokeOS 5.0 Based on Android 16 |
| Display | 6.56-inch HD+ IPS, 720*1612 Resolution 90Hz Refresh Rate, 83% Screen-to-body Ratio |
| CPU | Octa-core MediaTek Helio G81 |
| RAM & ROM | 8GB RAM + 256GB ROM, LPDDR4X + eMMC 5.1 |
| TF Expansion | Up to 256GB Expandable Storage |
| Battery | 15000mAh; 33W Fast Charging |
| Front Camera | 13MP |
| Rear Camera | 16MP Main + 20MP Night Vision |
| Speaker | Smart-PA Box Speaker |
| Card Slot | Two; 2*SIM/1*SIM +1*TF Card |
| NFC | Support |
| Wi-Fi &Bluetooth | Wi-Fi 5; BT 5.0 |
| Network Connectivity | 2G Band: B2/B3/B5/B8 3G Band: WCDMA: B1/B8 CDMA: BC0/BC1/BC10 4G Band: TDD: B40/B41 FDD:B1/B3/B7/B8/B19/B20/B28A/B28B |
