Oscal Pilot 6 Thermal Imaging 4G Rugged Phone with 6.78-inch 120Hz Display 108MP Camera 98dB Loud Speaker & 93 Lumens LED Torch
Sale price £322.00 Regular price £359.00
PILOT 6
See Thermal, See Beyond The Sharpest 108MP & Thermal Rugged Phone
Thermal Imaging
108MP Samsung® HM6 Main Camera
98dB Smart-PA Speaker
93 Lumens LED Torch
Industry's Clearest Thermal Vision 160*120 Pixels Thermal Imaging
-15°C to 550°C Measurement Range
61° × 47° Thermal Field of View
Smart Alerts & Supplementary Light
10000mAh Mega Battery
27W Fast Charging
Pro Imaging Engine Motion Photo
Pro Video Mode
ImageX AI Editing
93 Lumens LED Torch Up to 5 Meters Range
SOS Alarm
98 dB Loud speaker
IP68/IP69K
MIL-STD-810H
Flagship Camera System 108MP Samsung® HM6 Main Camera
50MP Samsung® JN1 Selfie Camera
Underwater Camera
12GB RAM+36GB Expansion
Up to 2TB TF Expansion
6.78-inch 2.4K 120Hz Display 750-Nit Brightness
Glove Mode 2.0
MediaTek Helio G100 Octa-Core Processor
Doke OS 5.0 / Doke AI 2.0 / Android 16
Unmatched Strength, Ultimate Durability Featuring an Al-Ti Alloy Middle Frame Bracket and Aluminum Side Strips, the Pilot 6 maintains a lightweight feel while delivering exceptional strength and protection. Combined with a shockproof Plastic Base, it ensures long-lasting durability from structure to details.
Ultimate Strength
Light & Tough
Thermal Imaging, Professional Shooting
Camera See Beyond the Visible,
Capture Every Detail at Its Peak
-15°C to 550°C Broader Measurement Range
61°×47° Wider Thermal View
160*120 High Resolution
108MP Samsung® ISOCELL HM6 Main Camera
1/1.67" Large Sensor
1.92μm Nonapixel Plus
Smart-ISO Pro
f/1.9 Aperture
6P Lens
50MP Samsung® ISOCELL JN1 Front Camera
1.28μm 4-in-1 Pixels
1/2.76" Sensor
5P Lens
Thermal The Industry's Clearest Thermal Imaging
See Beyond Sight
PILOT 6 boasts a 160*120 ultra-clear thermal sensor for accurately capturing 0.7℃ tiny temperature changes, with an extra-wide -15℃~550℃ temperature range fitting cold chain to industrial high-temperature scenarios and a 61°×47° wide field of view that greatly boosts industrial inspection and field rescue efficiency. * The illustration is a schematic of the lens structure for functional demonstration only. The actual appearance and structure of the product shall prevail.
Industry-leading Thermal lmaging Sensor Key Features
60 x 90
160 x 120
550°C -15°C
9Hz
25Hz
160*120 Higher Resolution
Makes thermal images clearer and more detailed
-15°C to +550°C Temperature Measurement
Covers temperature detection needs in multiple scenarios
25Hz Frame Rate
Makes thermal images smoother; captures dynamics more timely
P1 P2 P3
Ironbow Aurora Rainbow
White HOT Red Hot Cold Blue
<50mK Thermal Sensitivity
Works for various scenarios to deliver precise temperature data
· P1: 0.7°C
· P2: 1.7°C
· P3: 37.2°C
6 Color Palettes
Enhances thermal image recognition efficiency and operational flexibility
5 Image Fusion Modes
Captures and analyzes thermal data precisely
· IR (Infrared)
· RGB (Visible Light)
· MIX (Mixed Mode)
· SPO (Spot)
· PIP (Picture-in-Picture)
61°x47°
61°x40°
Video
Time-lapse
4 Target Measuring Tools
Meets temperature measurement needs of targets in different shapes
· Spot
· Rectangle
· Circle
· Horizontal/Vertical Line
61° × 47° Wider Horizontal FOV
With a wider horizontal FOV of 61° × 47°, this device covers a significantly larger detection area in a single imaging pass, reducing the need for multiple scans and ensuring comprehensive coverage of your target scene.
3 Recording Modes
Adapts to thermal data recording needs in different scenarios
· Photo
· Video
· Time-lapse
* Automatically capture interval images and then create time-lapse videos for monitoring gradual thermal changes.
Thermal Imager
Personalized Thermal Imaging The thermal imaging camera app on PILOT 6 features flexible temperature measurement parameter adjustments: You can tweak emissivity based on the measured object’s material (smooth/matte surfaces), customize ambient temperature and target distance, and switch between global/regional temperature detection modes. It not only adapts precisely to different detection scenarios but also enables professional-grade temperature monitoring and thermal imaging recording with ease.
Temp Params
Customizable
Detail Boost
Sharpens contrast & edges
Smart Thermal Record & Report Smarter Alerts, Safer Visibility PILOT 6’s thermal imaging app lets you easily snap, record and track thermal activity. It supports high/low-temperature alerts and instantly notifies you when preset thresholds are exceeded, making it ideal for industrial sites, outdoor environments, equipment inspections and other demanding scenarios. Plus, generate PDF reports for accurate, reliable documentation.
*Temperature alerts include three features (Threshold Alert, Temperature Range Alerts, Auto Snapshot); among these, Threshold Alert lets you customize and adjust temperature thresholds to fit your specific needs.
Practical Thermal Scenarios Guide
Facility operation scenarios for industrial production
Industrial Electrical Predictive Maintenance
Spot equipment anomalies via thermal imaging to prevent shutdowns.
Building Energy Efficiency Diagnosis
Locate insulation leaks/air gaps to improve energy efficiency.
Power & New Energy Operation
Inspect lines/PV panel hotspots to ensure stable power supply.
Home practical scenarios for personal daily life
Home Renovation Inspection
Detect hidden heat loss/leaks in walls/floors during renovation.
Cookware Overheat Alert
Monitor stove/pan temps to avoid overheating risks.
Indoor Pipe Leak Detection
Locate hidden pipe leaks via thermal imaging to reduce repair costs.
Safety exploration scenarios for outdoor activities
Night Security & Border Monitoring
Identify targets clearly in no-light/bad weather for safety.
Outdoor Camping “Night Recon”
Detect nearby animals/obstacles with thermal imaging to boost camping safety.
Emergency Rescue & Wilderness Search
Locate trapped individuals quickly in dark/complex terrains.
108MP Samsung® ISOCELL HM6 Main Camera Capture Every Detail Zoom in effortlessly on the PILOT 6 to capture every detail, while the large pixel sensor minimizes noise for crystal-clear photos. Experience stunning clarity with every shot you take.
Nonapixel Plus Tech
Clear Details Even in Low-Light Outdoors.
True Colors in Complex Outdoor Lighting.
6P Crystal Clear Lens
Max Sharpness for Outdoor Shots.
Smart-ISO Pro
Perfect Exposure for Changing Outdoor Light. It adjusts exposure parameters smartly to avoid overexposure/underexposure, delivering richer contrast.
All-new Motion Photo
Capture the fleeting moment with PILOT 6’s Motion Photo—preserving movement, sound, and the split-second energy that traditional photos often miss.
Smart Google Lens
One Snap for All Scenarios. The PILOT 6 is more than a phone—snap a photo to scan, recognize, translate, and search via Google Lens. From outdoor object checks to instant translations, it simplifies life effortlessly.
50MP Samsung® ISOCELL JN1 Selfie Camera Day or Night, Your Selfies Lead the Way
Face Unlock.
Instant Unlock for Outdoor Scenarios. When wearing gloves, or with wet/dusty hands outdoors, unlock instantly via face recognition—no screen contact needed, for smoother, faster operation.
Tetrapixel Technology.
Clearer Quality, Lower Noise. 4-in-1 pixel fusion boosts brightness and clarity. Capture sharper details with less noise in outdoor low-light or backlit shooting.
Advanced ISOCELL 2.0.
Enhanced each pixel's light sensitivity by almost 16%. Upgraded sensor tech reduces pixel crosstalk, delivering accurate colors and cleaner quality in outdoor bright or low-light conditions.
Snap effortlessly perfect selfies with the PILOT 6’s 50MP front camera, from the first light of dawn to the quiet glow of dusk. Video calls? They’ll be so crisp, you’ll forget you’re not face-to-face.
ImageX App
Your Vision. Reinvented ImageX redefines visual creation — from words to images, from photos to masterpieces. Enhance, transform, and bring every moment to life with AI precision and artistic flair.
Blemish Remover
Outpainting
Clarity Enhancement
Scratch Removal
Sky Replacement
Background Replacement
Up to 18 Advanced Image Editing Algorithms
Military Ruggedness, Emergency Backup
Cut Through Noise Anywhere 4.5W Booming Smart-PA Speaker 98dB maximum loudness, powerful sound that penetrates wind, traffic, and outdoor noise. Perfect for outdoor camping, hiking, cycling, and construction site communication. Nonstop playback for hours, keeping you entertained and connected.
4.5W
Booming Speaker
98 dB
Max Loudness
Up to 24 Hrs
Nonstop Power
SOS Alarm Bell
Greater Security
Outdoor Camping and Adventure
Emergency Rescue & Field Operations
Construction Sites or Industrial Environments
Full-View Safer Clarity Super-Bright 93 Lumens LED Torch Illuminate your way with the PILOT 6’s powerful 93 lumens LED torch. Whether you're exploring caves or embarking on nighttime adventures, it lights up your path and equips you to face the unknown, making it the ultimate companion for all your journeys.
One-Key Switch
Flashlight
Strobe Mode for SOS
Increased Safety
93 Lumens
Max Brightness
Up to 42 hrs
Prolonged Runtime
Your Reliable Outdoor Go-To
All-Scenario Lighting Solution
More than just a camping light for outdoor activities like camping, night fishing, hiking, and cycling, this light fits seamlessly into countless scenarios. Whether for site work, urgent repairs, vehicle maintenance lighting, or household emergencies like natural disasters, it’s your go-to, easy-to-reach lighting whenever you need it.
Design IP68/IP69K, MIL-STD-810H Certified
Toughness, Proven.
Thinner and slimmer than traditional rugged devices while never compromising on durability. With IP68/P69K rating protection and MIL-STD-810H certification, PILOT 6 is engineered with its exclusive protective structure to resist dust, extreme weather, and accidental drops. Crafted with aluminum alloy, this device stands up to any harsh challenge.
1.5 Meters
True Dropproof
Dust Proof
IPX9K
True Waterproof
MIL-STD-810H
True Crushproof
Design CORNING® GORILLA GLASS 5 CORNING® GORILLA GLASS 5 screen comes with 5 times scratch & drop-resistance, capable of withstanding drop impacts. It delivers better durability against damages or breakage caused by scratches, drops and impacts.
5x Higher
scratch threshold
Drop
Resistance
Underwater Camera Mode See Beauty Beneath Dive into creativity with PILOT 6’s underwater camera mode. Thanks to IP68 & IP69K protection, it captures stunning shots even 1.5 m below the surface — perfect for pools, rivers, or rain-soaked adventures.
More Features for Outdoor
Glove Mode 2.0
Enhanced touch stays responsive with gloves. From winter commutes to quick stops on rides, OSCAL PILOT 6 answers effortlessly.
Side Key Function
Customize the side key to access your favorite functions with a single, double, or long press — from launching the underwater camera and turning on the flashlight to sending an SOS alert, all at your fingertips.
App
Video Record
Flash light
Screen shot
Undarwater Camera
Open File
SOS
4-in-1 Navigation System
Pinpoint accuracy wherever you explore, powered by four global satellite networks. GPS, GLONASS, BeiDou, and Galileo work in tandem to deliver reliable positioning—even in remote or obstructed areas.
Useful ToolBag
Packed with practical tools for every situation — from compass and sound meter to plumb bob and magnifier — PILOT 6 turns your phone into a handy all-in-one toolkit for work and adventure.
Flagship Display, Powerful Performance
6.78-inch 2.4K 120Hz Immersive Display Vibrant Colors, Crisp Details The 6.78-inch 2.4K 120Hz screen on PILOT 6 provides an expansive viewing area where every detail shines and colors are vivid. Whether you're watching movies or gaming, enjoy an immersive experience with stunning clarity.
1080*2460
Resolution
6.7”
120Hz
120Hz
Refresh Rate
750 Nits
Brightness
1080P Widevine L1 Support With 1080P Widevine L1 support, PILOT 6 delivers cinema-
quality streaming right in your pocket, bringing you
immersive, high-definition entertainment anywhere.
3 Eye Protection Modes Reading Mode
Night Light Mode
Dark Mode (Enhance&Moderate&Gentle)
Ambient Lighting, Understands Every Moment From message alerts to call responses, from charging prompts to music interactions, light and shadow seamlessly connect with your scenarios, turning every interaction into a visual delight.
Massive Storage, Limitless Memories See Beauty Beneath 48GB RAM (12GB + 36GB expandable) keeps multi-tasking smooth—switch between apps, games, and streams with zero lag, plus 18% faster loading. Pair with 256GB ROM (up to 2TB expandable) for all your content, no more space worries.
Up to 17 Apps
Active in the Background Simultaneously
1:3 RAM
Next-Gen Expandable Tech
18%↑
Faster App Loading
2TB
TF Card Expansion
256GB ROM + 2TB TF Card Expansion
≈796K+Songs ≈303K+ Photos ≈5.1K+ Short Videos
Battery 10000mAh Big Battery, All-Day Power Equipped with 10000mAh high-density lithium battery, the ultra-long standby time meets the needs of outdoor adventures, full-day industrial shifts and remote areas without charging conditions. The industry's unique deep power-saving mode intelligently tracks the idle time of the device, increasing daytime battery life by 23.08% and nighttime standby efficiency by 71.62%, eliminating power anxiety.
11 hrs
Game
10.5 hrs
Video
18 hrs
Web
43 hrs
Calling
24 hrs
Music
1080 hrs
Dual Standby Battery Idle Save, Active Boost Dual upgrade for standby battery life, more relaxed power usage. DOZE mode boosts standby life by 38.9% during breaks; night power-saving cuts 8-hour sleep consumption by an extra 52%~60%. Runs smartly in the background, no disruption to rest or calls, saving battery for daytime use and ending "battery anxiety". *Data from OSCAL Labs. Actual battery performance may vary slightly based on usage environment and device status.
27W wired fast charging
It can fully charge the battery in about 60 minutes, and can quickly replenish energy during lunch breaks
15W wireless fast charging
No cable constraints, can be charged by placing it at will during construction site breaks and camping.
*Wireless charging base is not included and needs to be purchased separately.
10W reverse charging function
Earphones
Phone
Camera
Watch
Others
Octa-core MediaTek Helio G100 Smoother Action, Anywhere You Go Conquer the wild with the PILOT 6’s Helio G100 chip—engineered for flawless gaming and effortless app-switching. Whether you’re capturing action-packed moments or streaming your favorite films, expect smooth performance and ultimate convenience.
6nm
Process
2.2GHz
Turbo Frequency
ARM Mali-G57
GPU
Connected Everywhere. Seamless Always.
Dual 4G SIM & TF Card Support
Use two SIM cards or one SIM + TF card — perfect for balancing work, travel, or adventure.
NFC Support
Tap to connect for access control, payments, and file transfer—simplify your work and life.
Dual Band Wi-Fi 5 & Wireless BT 5.0
Built for speed and reliability — smooth sharing, clear calls, and instant pairing, every time.
Infrared Remote Blaster
Control your TV, AC and more from anywhere—adjust the couch, turn off forgotten appliances, or set the mood for movie night.
All-new DokeOS 5.0 (Android 16)
DokeOS 5.0 New Look. More Magic.
Now powered by DokeOS 5.0 (Android 16), PILOT 6 delivers a smoother, smarter, and more personalized experience. It features refreshed visuals, optimized layouts and boosted performance. It’s not just faster; it’s more intuitive, adapting to you the more you use it.
Customize
Your Style, Your Way
PILOT 6 gives you full control over how your phone looks and feels — from wallpapers to themes, every detail reflects you.
Wallpaper Hub: Wide-ranging themes and live wallpapers across 8 categories-diverse styles to match your home and lock screens
Color Schemes: Easily switch interface colors, with light and dark modes for a consistent look across apps and system.
Theme Styles: Supports minimal, parallel, and other themes, with quick switching to match your personal workflow.
Efficiency
A Smarter Desktop,
Easier to Use.
App Drawer: Sort apps alphabetically, by usage, or into custom categories — transforming cluttered icons into a streamlined, lightning-fast hub.
Larger Folders: Bigger icons, easier taps. Your most-used apps are visible and one tap away.
Desktop Grid: Freely define layout, rows and spacing—tailored to your habits, boosting daily efficiency.
System Manager 2.0: With upgraded deep cleaning and smart file sorting, stays organized and runs faster than ever.
NoteBook 3.0:
Write Freely, Find Instantly
Upgraded Search: Instantly find your notes, to-dos, and images with smart recognition — all unified in one place for effortless access.
Folders & Editing: Effortlessly maintain a tidy notes system. Create nested folders, drag-and-drop to rearrange, and batch organize your thoughts for a workflow that's both efficient and personally tailored.
Flexible Export: Export freely in Word or TXT — ready for every scenario. Choose the perfect format for editing, sharing, or archiving, with seamless compatibility across all your devices and workflows.
Doodle & Reminders: Sketch your thoughts and tie them to timely alerts—transforming spontaneous ideas into actionable tasks that never get lost.
Performance All-Day Power, Always Smooth. DOKEOS 5.0’s Auto-Start & Associated Launch Control technology intelligently manages background idle apps and prioritizes system resources for current use, boasting 18.54% faster response and 9.58% better startup performance. It ensures smoother, more power-efficient operation with less overheating, blocks auto-start of malicious processes, enhances device security and privacy. Proven effective in tests, it fully upgrades daily user experience.
+18.54%
Faster System Response
+9.58%
Faster Startup Performance
+9.15%
Higher Memory Availability
*Data from OSCAL Labs. Actual performance varies by usage environment and app types.
Privacy
Privacy First, Always Secure
PILOT 6 puts your privacy at the center — with upgraded safeguards from data storage to app permissions, giving you full control over what you share and who sees it.
Private Space
All-Round Protection for Your Privacy. Create a secure space to hide sensitive photos, files, and apps.
Per-App Screen Recording
Per-App Screen Recording: Grant or revoke access for each app individually, stay informed with real-time alerts, and ensure you control your digital footprint.
App Lock
Privacy Anytime, Anywhere. Secure apps and sensitive data with passwords, PINs, or biometrics.
All-in-One Ease, All in Your Hand.
Stay productive and entertained anywhere with built-in essentials:
Doke AI 2.0: Personal, Fast, Powerful
Backed by the world’s top three AI models DeepSeek-R1, ChatGPT-4o mini, Gemini 2.0, Doke AI 2.0 makes PILOT 6 more intuitive, responsive and creative in everything you do.
Gemini Al Smarter Assistant, Tailored to You.
AI Voice Activation
Hands-Free. Hassle-Free
Built on deep-learning private voice recognition, it enables hands-free operation with high accuracy and low latency, making interactions faster, smarter, and more natural.
AI Global Smart Control
One Command. Full Control
From messages to maps, from tools to tasks — PILOT 6 understands what you say and what you need, turning voice or text commands into instant, intelligent actions across your entire phone.
Real-Time Voice Conversation
Real Talk. Real Time. Real Connection
Talk to OSCAL PILOT 6 like you talk to a friend. With real-time AI voice interaction, it listens, understands, and responds instantly — giving you natural, two-way conversations without typing or waiting.
Smart AI Voice Q&A
With voice-enabled AI, just speak to get answers—no typing, no searching. Enjoy instant, hands-free responses that make your tasks easier.
AI Full-Screen Smart Assistance
Real-Time Answers, Just a Tap Away
Say goodbye to vague answers — it reads your screen and delivers responses based on real-time content. Just tap to ask and enjoy AI that truly gets you.
Industry’s Only Self-developed AI Seamlessly switch between apps: chat with Hi Doki, refine photos in ImageX, produce videos in VidGen, and score tracks in Soundle—all working in harmony on a single device.
AI Chat App VidGen APP ImageX App Soundle APP
AI Chat App
From Thought to Art — Instantly Powered by Doke AI 2.0, Hi Doki unites document parsing, tutoring, online search, and creative generation — from image to music — all through one intelligent hub designed to think, learn, and create with you.
Next-Gen DeepSeek-R1
The AI companion that delivers fast searches and precise answers, adapts to your unique needs seamlessly, and turns complexity into clarity effortlessly.
AI Text-to-Image Creation
Just describe your ideas, and the AI swiftly creates it into images, captures every detail with stunning precision, and turns even the wildest imaginations into vivid realities.
AI Tutoring Assistant
20 Diverse Personalities — ready to chat, teach, or entertain anytime, tailors guidance to your learning pace, and turns tough topics into engaging journeys.
AI Image to Image
With 33 dazzling effects, turn any image into a masterpiece in seconds, crafts stunning visuals with cinematic quality, and lets you refine every detail to match your vision.
AI Music Composition
With 16 dynamic styles, craft exclusive melodies from imagination in an instant, adapt to diverse scenarios with flexible tones, and generate professional music works easily without professional skills.
VidGen APP
Where Ideas Come Alive Transform text prompts or static images into dynamic, emotion-filled clips — seamlessly bridging the gap between static ideas and vivid motion, boasting rich details, vibrant colors, and smooth transitions, all beautifully rendered with cinematic flair and effortlessly created without complex editing skills.
Text-to-Video
Simply describe it, and Al turns your words into avideo in seconds-scenes, camera motion, andpacing included. Refine with plain language: change style, aspect ratio, duration, or addsubtitles and transitions.
Photo-to-Video
Transform still photos into dynamic visual storieswith smooth pans, zooms, and parallax inseconds. Add captions, music, and transitions; choose styles from cinematic to vintage to match your mood.
Soundle APP
Your Emotions. In Every Note Turn your ideas into rhythm, your memories into melody. With Soundle, AI composes full songs that capture your mood — fast, emotional, and truly yours.
What's In The Box
OSCAL PILOT 6 Manual Data cable SIM Card Ejector Pin Lanyard
OSCAL PILOT 6 Specifications
Product Disclaimer
1. The product’s infrared detector is sensitive—do not point it at strong radiation sources (e.g., sun, laser beams), as permanent damage may occur. We are not liable for improper use.
2. This is not a medical device; temperature data is for reference only and not intended for disease diagnosis, treatment or prevention.
3. Avoid prolonged use in environments above +40℃; the app requires 1-3 minutes of preheating after launch for accurate data.
4. This product detects 8-14μm infrared wavelengths only—it cannot see through water or ordinary glass, and only measures surface temperatures of clothing or skin.
5. Temperatures of exposed human skin vary with the environment: they usually stay below 36℃ at room temperature, and may drop below 10℃ in cold outdoors or exceed 40℃ after sun exposure—both are normal.
Model
Color
Dimension
Weight
OS
Main Display
CPU
RAM & ROM
RAM Expansion
TF Expansion
Battery
Thermal Imaging Camera
Front Camera
Rear Camera
Speaker
Rugged Rating
Navigation
Card Slot
Glove Mode
NFC
WiFi
Wireless BT
Network Connectivity
OSCAL PILOT 6
Black, Orange
182.8*82*18.1mm
410.8g
DokeOS 5.0 Based on Android 16
6.78-inch, 1080*2460 Resolution, Corning® Gorilla® Glass 5, 120Hz Smart Refresh Rate
Octa-core MediaTek Helio G100, 6nm, Up to 2.2GHz
12GB RAM & 256GB ROM, LPDDR4X+UFS2.1
Up to 36GB
Up to 2TB
10,000mAh, 27W Fast Charging
160×120 Higher Resolution, 15°C to +550°C Temperature Measurement,
25Hz Frame Rate, <50mK Thermal Sensitivity
4.5W 98dB Smart-PA BOX Speaker
IP68 & IP69K & MIL-STD-810H
GPS+GLONASS+Galileo+Beidou/QZSS(L1)
Dual; 2* SIMs / 1* SIM + 1* TF Card
Support
Support
802.11 ac/a/b/g/n(2.4GHz,5GHz)
BT5.2
2G Band: B2/B3/B5/B8
3G Band: B1/2/4/5/8
4G Band: B1/2/3/4/5/7/8/12/13/17/18/19/20/26/28A/28B/66+B38/40/41
