Oscal Pilot 6 Thermal Imaging 4G Rugged Phone with 6.78-inch 120Hz Display 108MP Camera 98dB Loud Speaker & 93 Lumens LED Torch
Available in stock (25)
✔160×120 Thermal Vision Camera, -15℃ to +550 ℃ Thermal Detect
✔4.5W 98 dB Smart-PA Loud speaker
✔Super-Bright 93 Lumens LED Torch
✔108MP Samsung® HM6 Main Camera
✔10,000mAh Battery, 27W Wired Charging & 15W Wireless Charging
✔ IP69K/IP68 & MIL-STD-810H Certified
The OSCAL PILOT 6 is built for users who need thermal vision, loud audio, and rugged durability in one field-ready phone. Its 6.78-inch 120Hz FHD+ display, MediaTek Helio G100 performance, and 10,000mAh battery with 27W wired and 15W wireless charging support long outdoor use. A 160×120 thermal camera, 108MP Samsung main camera, 98dB speaker, and 93-lumen LED torch make it useful for inspections, repairs, camping, and emergencies, while IP68 & IP69K protection keeps it ready for harsh conditions.
-15°C to 550°C Measurement Range
61° × 47° Thermal Field of View
Smart Alerts & Supplementary Light
Pro Video Mode
ImageX AI Editing
SOS Alarm
MIL-STD-810H
50MP Samsung® JN1 Selfie Camera
Underwater Camera
Up to 2TB TF Expansion
Glove Mode 2.0
Ultimate Strength
Light & Tough
Capture Every Detail at Its Peak
-15°C to 550°C Broader Measurement Range
61°×47° Wider Thermal View
160*120 High Resolution
1/1.67" Large Sensor
1.92μm Nonapixel Plus
Smart-ISO Pro
f/1.9 Aperture
6P Lens
1.28μm 4-in-1 Pixels
1/2.76" Sensor
5P Lens
See Beyond Sight PILOT 6 boasts a 160*120 ultra-clear thermal sensor for accurately capturing 0.7℃ tiny temperature changes, with an extra-wide -15℃~550℃ temperature range fitting cold chain to industrial high-temperature scenarios and a 61°×47° wide field of view that greatly boosts industrial inspection and field rescue efficiency. * The illustration is a schematic of the lens structure for functional demonstration only. The actual appearance and structure of the product shall prevail.
60 x 90
160 x 120
550°C
-15°C
9Hz
25Hz
Makes thermal images clearer and more detailed
Covers temperature detection needs in multiple scenarios
Makes thermal images smoother; captures dynamics more timely
P1 P2 P3
Works for various scenarios to deliver precise temperature data
· P1: 0.7°C
· P2: 1.7°C
· P3: 37.2°C
Enhances thermal image recognition efficiency and operational flexibility
Captures and analyzes thermal data precisely
· IR (Infrared)
· RGB (Visible Light)
· MIX (Mixed Mode)
· SPO (Spot)
· PIP (Picture-in-Picture)
61°x47°
61°x40°
Video
Time-lapse
Meets temperature measurement needs of targets in different shapes
· Spot
· Rectangle
· Circle
· Horizontal/Vertical Line
With a wider horizontal FOV of 61° × 47°, this device covers a significantly larger detection area in a single imaging pass, reducing the need for multiple scans and ensuring comprehensive coverage of your target scene.
Adapts to thermal data recording needs in different scenarios
· Photo
· Video
· Time-lapse
Thermal Imager
Temp Params Customizable
Detail Boost Sharpens contrast & edges
Spot equipment anomalies via thermal imaging to prevent shutdowns.
Locate insulation leaks/air gaps to improve energy efficiency.
Inspect lines/PV panel hotspots to ensure stable power supply.
Detect hidden heat loss/leaks in walls/floors during renovation.
Monitor stove/pan temps to avoid overheating risks.
Locate hidden pipe leaks via thermal imaging to reduce repair costs.
Identify targets clearly in no-light/bad weather for safety.
Detect nearby animals/obstacles with thermal imaging to boost camping safety.
Locate trapped individuals quickly in dark/complex terrains.
Clear Details Even in Low-Light Outdoors.
True Colors in Complex Outdoor Lighting.
Max Sharpness for Outdoor Shots.
Perfect Exposure for Changing Outdoor Light. It adjusts exposure parameters smartly to avoid overexposure/underexposure, delivering richer contrast.
Capture the fleeting moment with PILOT 6’s Motion Photo—preserving movement, sound, and the split-second energy that traditional photos often miss.
One Snap for All Scenarios. The PILOT 6 is more than a phone—snap a photo to scan, recognize, translate, and search via Google Lens. From outdoor object checks to instant translations, it simplifies life effortlessly.
Instant Unlock for Outdoor Scenarios. When wearing gloves, or with wet/dusty hands outdoors, unlock instantly via face recognition—no screen contact needed, for smoother, faster operation.
Clearer Quality, Lower Noise. 4-in-1 pixel fusion boosts brightness and clarity. Capture sharper details with less noise in outdoor low-light or backlit shooting.
ImageX App
Blemish Remover
Outpainting
Clarity Enhancement
Scratch Removal
Sky Replacement
Background Replacement
Up to 18 Advanced Image Editing Algorithms
Booming Speaker
Max Loudness
Nonstop Power
Greater Security
Flashlight
Increased Safety
Max Brightness
Prolonged Runtime
Toughness, Proven.
Thinner and slimmer than traditional rugged devices while never compromising on
durability. With IP68/P69K rating protection and MIL-STD-810H certification, PILOT 6 is engineered with
its exclusive protective structure to resist dust, extreme weather, and accidental drops. Crafted with
aluminum alloy, this device stands up to any harsh challenge.
True Dropproof
True Waterproof
True Crushproof
Enhanced touch stays responsive with gloves. From winter commutes to quick stops on rides, OSCAL PILOT 6 answers effortlessly.
Customize the side key to access your favorite functions with a single, double, or long press — from launching the underwater camera and turning on the flashlight to sending an SOS alert, all at your fingertips.
Video Record
Flash light
Screen shot
Undarwater Camera
Open File
SOS
Pinpoint accuracy wherever you explore, powered by four global satellite networks. GPS, GLONASS, BeiDou, and Galileo work in tandem to deliver reliable positioning—even in remote or obstructed areas.
Packed with practical tools for every situation — from compass and sound meter to plumb bob and magnifier — PILOT 6 turns your phone into a handy all-in-one toolkit for work and adventure.
Resolution
120Hz
Refresh Rate
Brightness
quality streaming right in your pocket, bringing you
immersive, high-definition entertainment anywhere.
Night Light Mode
Dark Mode (Enhance&Moderate&Gentle)
≈796K+Songs
≈303K+ Photos
≈5.1K+ Short Videos
Game
Video
Web
Calling
Music
*Data from OSCAL Labs. Actual battery performance may vary slightly based on usage
environment and device status.
It can fully charge the battery in about 60 minutes, and can quickly replenish energy during lunch breaks
No cable constraints, can be charged by placing it at will during construction site breaks and camping.
*Wireless charging base is not included and needs to be purchased separately.
Earphones
Phone
Camera
Watch
Others
Use two SIM cards or one SIM + TF card — perfect for balancing work, travel, or adventure.
Tap to connect for access control, payments, and file transfer—simplify your work and life.
Built for speed and reliability — smooth sharing, clear calls, and instant pairing, every time.
Control your TV, AC and more from anywhere—adjust the couch, turn off forgotten appliances, or set the mood for movie night.
Easier to Use.
AI Chat App
VidGen APP
Soundle APP
OSCAL PILOT 6 Specifications
1. The product’s infrared detector is sensitive—do not point it at strong radiation sources (e.g., sun, laser beams), as permanent damage may occur. We are not liable for improper use.
2. This is not a medical device; temperature data is for reference only and not intended for disease diagnosis, treatment or prevention.
3. Avoid prolonged use in environments above +40℃; the app requires 1-3 minutes of preheating after launch for accurate data.
4. This product detects 8-14μm infrared wavelengths only—it cannot see through water or ordinary glass, and only measures surface temperatures of clothing or skin.
5. Temperatures of exposed human skin vary with the environment: they usually stay below 36℃ at room temperature, and may drop below 10℃ in cold outdoors or exceed 40℃ after sun exposure—both are normal.
Color
RAM & ROM
RAM Expansion
TF Expansion
Battery
Thermal Imaging Camera
Front Camera
Rear Camera
Speaker
Rugged Rating
Navigation
Card Slot
Glove Mode
NFC
WiFi
Wireless BT
Network Connectivity
Black, Orange
410.8g
DokeOS 5.0 Based on Android 16
6.78-inch, 1080*2460 Resolution, Corning® Gorilla® Glass 5, 120Hz Smart Refresh Rate
Octa-core MediaTek Helio G100, 6nm, Up to 2.2GHz
12GB RAM & 256GB ROM, LPDDR4X+UFS2.1
Up to 36GB
Up to 2TB
10,000mAh, 27W Fast Charging
160×120 Higher Resolution, 15°C to +550°C Temperature Measurement,
25Hz Frame Rate, <50mK Thermal Sensitivity
50MP Samsung® ISOCELL JN1 Selfie Camera
108MP Samsung® ISOCELL HM6 Main Camera
4.5W 98dB Smart-PA BOX Speaker
IP68 & IP69K & MIL-STD-810H
GPS+GLONASS+Galileo+Beidou/QZSS(L1)
Dual; 2* SIMs / 1* SIM + 1* TF Card
Support
Support
802.11 ac/a/b/g/n(2.4GHz,5GHz)
BT5.2
2G Band: B2/B3/B5/B8
3G Band: B1/2/4/5/8
4G Band: B1/2/3/4/5/7/8/12/13/17/18/19/20/26/28A/28B/66+B38/40/41
| Model | OSCAL PILOT 6 |
| Color | Black, Orange |
| Dimension | 182.8*82*18.1mm |
| Weight | 410.8g |
| OS | DokeOS 5.0 Based on Android 16 |
| Main Display | 6.78-inch, 1080*2460 Resolution, Corning® Gorilla® Glass 5, 120Hz Smart Refresh Rate |
| CPU | Octa-core MediaTek Helio G100, 6nm, Up to 2.2GHz |
| RAM & ROM | 12GB RAM & 256GB ROM, LPDDR4X+UFS2.1 |
| RAM Expansion | Up to 36GB |
| TF Expansion | Up to 2TB |
| Battery | 10,000mAh, 27W Fast Charging |
| Thermal Imaging Camera | 160×120 Higher Resolution, 15°C to +550°C Temperature Measurement, 25Hz Frame Rate, <50mK Thermal Sensitivity |
| Front Camera | 50MP Samsung® ISOCELL JN1 Selfie Camera |
| Rear Camera | 108MP Samsung® ISOCELL HM6 Main Camera |
| Speaker | 4.5W 98dB Smart-PA BOX Speaker |
| Navigation | GPS+GLONASS+Galileo+Beidou/QZSS(L1) |
| Card Slot | Dual; 2* SIMs / 1* SIM + 1* TF Card |
| Glove Mode | Support |
| NFC | Support |
| WiFi | 802.11 ac/a/b/g/n(2.4GHz, 5GHz) |
| Wireless BT | BT5.2 |
| Network Connectivity | 2G Band: B2/B3/B5/B8 3G Band: B1/2/4/5/8 4G Band: B1/2/3/4/5/7/8/12/13/17/18/19/20/26/28A/28B/66+B38/40/41 |
