Blackview FORT 200 Slim & Wireless Charging 6.78-inch MediaTek Helio G100 Octa-core 5000mAh 108MP+13MP Night Vision Camera Rugged 4G Phone
Hurry up, only 3 items left in stock.
✔6.78-inch 268g & 11.5mm Slim
✔108MP Samsung® HM6 + 13MP Night Vision Camera
✔ Octa-core MediaTek Helio G100 Processor
✔5000mAh & 33W Fast Charging+15W Wireless Charging
✔IP68 & IP69K & MIL-STD-810H Certified
The Blackview FORT 200 is a slim rugged 4G phone built for users who want stronger imaging, smoother viewing, and outdoor-ready durability without carrying a bulky device. Its 6.78-inch 120Hz 2.4K display stays clear with 700-nit brightness, while the MediaTek Helio G100 keeps daily tasks, navigation, and field work responsive. A 108MP Samsung rear camera, 13MP night vision camera, 5000mAh battery, 33W fast charging, and 15W wireless charging make it practical for work and adventure. With IP68 & IP69K and MIL-STD-810H protection, it is ready for tough environments.
Rugged Imaging Flagship Slim in Hand. Sharp in Vision. Ready for the Unknown.
Slim. Bright. Unbelievably Clear See It Clear. See It Anywhere
Resolution
IPS Full View
Peak Brightness
PPI
AI Smart Refresh Rate
Screen-to-Body Ratio
Touch Sampling Rate
FORT 200 pushes up to 700 nits to stay bright and readable when lesser displays fade.
Others
500 nits
Feel the smoothness kick in with Blackview FORT 200’s 120Hz AI Smart Refresh Rate — saving power when you scroll, boosting fluidity when you game, and keeping every move ultra-responsive wherever you go.
Adjustable dark themes designed for reduced strain and longer battery life.
Soft amber tones with adjustable intensity to help your eyes relax comfortably at night.
A clean, kindle-like effect that stays comfortable for long reading.
See More. Capture Clearer. Lead the Class Capture It All — Sharper by Day, Visible by Night Built with the Industry’s Clearest Imaging Power.
1.28μm 4-in-1 Pixels
1/2.76" Sensor
5P Lens
1/1.67" Large Sensor
1.92μm Nonapixel Plus
f/1.9 Aperture
6P Lens
Brighter nights.
Less noise. More detail.
Sharper images.
Cleaner optics.
Wider dynamic range.
Truer colors.
Smarter exposure.
Better contrast.
Distance Hides Whether you're observing, inspecting, or documenting, 8× zoom brings distant details into sharp, usable clarity.
ISOCELL 2.0
Tetrapixel 4-in-1 Tech
Double Super PD
Stay aware in any environment with FORT 200’s 13MP Night Vision Camera — providing clear visibility when the lights go out and conditions get tough.
Spot animals clearly — even when darkness hides their movement.
Locate people and objects fast when every second matters.
Stay aware of what moves around your campsite after dark.
Catch the moment before it fades with FORT 200’s Motion Photo — capturing the movement, the sound, and the split-second energy that still photos usually miss.
Shoot with purpose using FORT 200’s sharper 2K video, and fine-tune your settings with Pro Mode when Auto mode can’t keep up with tough lighting or fast-moving moments.
AI Photos
Rain / Sand and Dust / Vibration / Shock / Acceleration / High Temperature / Low Temperature / Humidity / Altitude
Drop Proof
Death-Broke
Extreme Temps Operation
All-Angle Waterproofing
Ready for Every Challenge.
SIM Tray Waterproof Sealing
USB Port Waterproof Protection
Speaker Grill Water-Block Design
Microphone Port Waterproof Shielding
You Ready.
Camera
BOX Speaker
Phantom Black
Brightness
1.5m Death-Broke
-20°C to +55°C Extreme
Temps Operation
Side Key Function
Useful ToolBag
Remote
Control
Under Water Camera
2W Smart-K BOX Speaker
IP69K Ratings
MediaTek Helio G100
12GB RAM+36GB Expansion
Card Expansion
≈303K+ Photos
≈5.1K+ Short Videos
with 33W Fast Charging
6P Crystal Clear Lens
Smart-ISO Pro
8X Zoom
Double Super PD
with All-New Pro Mode
AI OutPainting
AI Blur Photo
System Manager
2.0
Camera 2.0
Global Network
Ready
Smart NFC
Access
More Power. More Speed. More Done. No Lag. No Limits. Just Power
Run Simultaneously
Next-Gen Expandable Tech
Faster App Loading
≈796K+Songs
≈303K+ Photos
≈5.1K+ Short Videos
5W Reverse Power Share
Battery Saver Algorithm
Super Power Saving Mode
Charging Protection
Every Day *Data from Blackview Lab. Actual results may vary based on usage and environment.
Notice the difference as FORT 200 adapts to your day — the all-new Deep Power-saving Mode identifies idle time even in daylight and reduces power use without you lifting a finger.
Smarter, Smoother, Designed to Know You Better. All-new DokeOS 5.0 (Android 16)
Convenience Upgrade
Personalization Upgrade
Privacy & Security Upgrade
AI Intelligence Upgrade
From DokeOS 4.2 to 5.0, everything has evolved — the speed you feel, the fluidity you see, the intelligence that anticipates your next move. It’s smoother, smarter, and more personal than ever, turning everyday moments into effortless experiences.
for Everyday Tasks
Cinematic looks in one tap.
Grids, watermarks, level,
and haptics instantly at hand.
Fine-tune color
temperature andmetering
with pro-level control.
Designed for reliable connectivity across
regions worldwide.
Unlock doors, pay instantly, and connect faster
with a single tap.
Blackview FORT 200 Specifications
120Hz Smart Refresh Rate, 86% Screen-to-body Ratio
13MP(Night Vision)
3G Band: WCDMA:B1/2/4/5/8
4G Band: FDD:B1/2/3/4/5/7/8/12/13/17/18/19/20/26/28A/28B/66
TDD:B38/40/41
| Design | |
| Product | Blackview FORT 200 |
| Color | Blaze Orange, Phantom Black |
| Dimensions | 178.4 × 83 × 11.5 mm |
| Weight | 268 g |
| OS | DokeOS 5.0 based on Android 16 |
| Display | |
| Main Display | 6.78-inch IPS display |
| Resolution | 1080 × 2460 |
| Refresh Rate | 120Hz |
| Touch Sampling Rate | 180Hz |
| Brightness | 700 nits peak brightness |
| PPI | 396 |
| Screen-to-Body Ratio | 86% |
| Glass | Panda Glass |
| Performance | |
| CPU | MediaTek Helio G100 |
| CPU Clock | 2 × Cortex-A76 2.2GHz + 6 × Cortex-A55 2.0GHz |
| GPU | Mali-G57 3D Graphics |
| RAM & ROM | 12GB RAM + 256GB ROM |
| Memory Type | LPDDR4X + UFS 2.2 |
| RAM Expansion | Up to 36GB expansion |
| TF Expansion | Up to 2TB |
| Camera | |
| Front Camera | 50MP Samsung® ISOCELL JN1 |
| Rear Camera | 108MP Samsung® ISOCELL HM6 main camera + 13MP night vision camera |
| Rear Camera Sensor | Samsung® ISOCELL HM6 + OV08B10 |
| Video Recording | 2K video recording with Pro Mode |
| Camera Features | Motion Photo, AI Photos, 8× Zoom, Pro Mode, Smart Google Lens |
| Battery & Charging | |
| Battery | 5000mAh |
| Charging | 33W fast charging, 15W wireless charging |
| Reverse Charging | 5W reverse power share |
| Audio | |
| Speaker | 2W Smart-K BOX speaker |
| Durability | |
| Water Resistance | 2m / 30 min deep submersion proof |
| Drop Resistance | Up to 6m drop proof |
| Hot-Water Resistance | 80°C hot-water resistance |
| Pressure Jet Defense | 10,000 kPa |
| Operating Temperature | -20°C to +55°C |
| Connectivity | |
| Network | Dual 4G SIM support |
| Wi-Fi | IEEE 802.11 a/b/g/n/ac, 2.4GHz / 5GHz |
| Bluetooth | BT 5.2 |
| NFC | Support |
| Card Slot | Dual: 2 × SIM / 1 × SIM + 1 × TF Card |
| USB | Type-C |
| Network Bands | |
| 2G | B2 / B3 / B5 / B8 |
| 3G | WCDMA: B1 / B2 / B4 / B5 / B8 |
| 4G | FDD: B1 / B2 / B3 / B4 / B5 / B7 / B8 / B12 / B13 / B17 / B18 / B19 / B20 / B26 / B28A / B28B / B66; TDD: B38 / B40 / B41 |
| 5G | No |
| Navigation | |
| Positioning | GPS / GLONASS / Galileo / BeiDou / QZSS |
| Sensors | |
| Sensors | G-sensor, P-sensor, L-sensor, gyroscope, compass, magnetic sensor, fingerprint sensor, RGB sensor |
| Extra Features | |
| Outdoor Features | Side key function, infrared remote control, ToolBag, underwater camera |
| AI Features | Doke AI 2.0, AI Chat, AI Photos, AI Video, AI Music, ImageX App |
| Other Features | Wireless charging, NFC, FM, OTG, fingerprint unlock, reading mode, night light, dark mode |
