Color_White | Blackview AirBuds 2 True Wireless Stereo Earbuds - Blackview Store
Blackview AirBuds 2 Long Battery Life TWS True Wireless Stereo Earphones
Sale price £30.00 Regular price £38.00
AirBuds 2
  • 5.0
  • Master-slave Switch
  • Up to 20hrs Battery Life
  • 8mm Dynamic Coil Unit
  • Effective Noise Isolating
  • Voice Assistant
  • Tap to Control
  • Fit & Comfortable Wearing
Modern Design &
Delicate Appearance
Unique flip design and oxidized aluminum alloy case, super cool.
90° Rotation
  • Long press the button
    for 3s for reconnecting.
    Long press it for 10s to
    restore default setting.
Master-slave Switch,
Either Can Be Master
Both the left and the right earbud can connect to device independently. Pick up to use. No more signal dropouts. After the first pairing, they can connect automatically to the device next time.
Master
Master
Faster & Stabler Connection
Automatic connection in seconds and super fast data transfer speed. Ultra-low latency for gaming and better power-saving performance.
  • Operation
    range
  • 10m
    360°
Enjoy More Details
With the 8mm composite diaphragm dynamic coil unit, AirBuds 2 ensures crisp treble, natural alto and deep bass as well as richer details, delivering superior Hi-Fi stereo sound across the entire frequency range.
Effective Noise Isolating,
Better Experience
Effective at blocking high-frequency noise for clear calls and better enjoying music even in noisy environment.
Up to 20hrs Battery Life All-day Listening
A fully charged case can charge AirBuds 2 more than twice and offers up to 20hrs battery life. Up to 6-hour listening time with a full charge, no need to charge frequently.
  • 6Hr
    of playback in a
    single charge
  • 20Hr
    of playback together
    with charging case
  • * 380mAh charging case included.
  • * The actual battery life varies depending on the music type, volume, etc.
Voice Assistant
Always at Your Service
Wake up your voice assistant via simple tap control. Tell it what you need without taking out your phone. Focus more on your work or exercise.
Open Google map.
Call dad.
How is the weather today?
Easy Touch Control
Play/pause music, answer/end a call simply by tapping the earbuds. Easy control without operating the device.
  • Volume+ / Volume-
  • Play / pause music
  • Answer / end a call
  • Next song / previous song
  • Reject a call
  • Activate voice assistant
IPX7 Waterproof
Waterproof structure design provides effective protection against sweat, perfect for gym workouts, running, hiking, etc. Enjoy the pleasant sound quality whenever and wherever you like.
*Wiping up sweat and grime after your workout can prolong the life span of your earbuds.
In-ear Design,
Fits Just Right
AirBuds 2 ensures a comfortable and secure fit with the in-ear design fitting your ear canal snugly. Easy to wear and never falls out.
* We provide different size of eartips in the package to perfectly fit your ear.
