Blackview AirBuds 1 Fingerprint Touch Bluetooth Earbuds Earpiece True Wireless TWS Earphones
Out of stock
✔True Wireless Stereo Earbuds
✔Up to 20hrs battery life
✔Voice assistant Smart control
AirBuds 1
True Wireless Stereo Headsets
Instant setup
Master-slave switch
5.0
Operation range 10m
390mAh charging case
Tap to operate
Multifunction control
Voice assistant
Smart control
8mm dynamic coil unit
DSP noise cancellation
Master-slave switch,
either can be master
Both the left and the right earbud can connect to device independently. Pick up to use. No more signal dropouts. After the first pairing, they can connect automatically to the device next time.
5.0 for faster,
more stable connection
The latest Bluetooth 5.0 chip enables AirBuds 1 to connect automatically in seconds. Twice faster data transfer than the previous generation, low-latency for gaming, better power-saving ability.
Operation range
10m | 360°
Natural, full and rich
sound you can feel
AirBuds 1 earbuds feature a large speaker with a 8mm dynamic coil unit, coupled with DSP noise cancellation technology, offering crystal-clear sound quality.
large speaker dynamic coil unit
A fully charged case provides good protection and storage, and offers up to 20hrs battery life, which can charge the earbuds more than twice. Each charge guarantees 6 hours of listening time.
* 390mAh charging case included
* The actual battery life varies depending on the music type, volume, etct
Your right-hand smart
assistant who listens back
Your voice assistant wakes up to your voice, letting you control your phone without lifting a finger. Adjust the volume or manage your calls while on the move. You talk, your voice assistant listens.
Apple
Siri -
Google
Assistant -
Amazon
Alexa
Tap to operate,
and control with ease
Operations such as to play/pause music, answer/end a call can be performed by simply tapping the earbuds. Easy control without operating the device.
Volume+ / Volume-
Long tap right/left earbud
Play / pause music
Tap either earbud once
Answer / end a call
Tap either earbud twice
Next song / previous song
Tap right/left earbud twice
Reject a call
Tap either earbud for 2 seconds
Activate voice assistant
Triple-tap either earbud
Comfortable in-ear design for a secure fit
The in-ear design fits the ear canal snugly. Easy to wear and never falls out. Enjoy smooth and uninterrupted sound whether you're running, playing sports or traveling.
Lightweight
& mini -
Secure
fit -
Comfortable
wearing
