Blackview BL7000 Pro 6.78-inch 8+256GB/512GB MediaTek Dimensity 6300 50MP+20MP Night Vision Camera 7500mAh 5G AI Rugged Phone
Hurry up, only 1 item left in stock.
✔5G 6nm MediaTek Dimensity 6300 CPU
✔6.78-inch 2.4K Display w/ 120Hz Smart Al Refresh Rate
✔50MP AI Main & 20MP Night Vision Cameras
The Blackview BL7000 Pro is a 5G AI rugged phone designed for users who need strong imaging, reliable endurance, and field-ready durability. Its 6.78-inch 120Hz FHD+ display, Dimensity 6300 processor, 7500mAh battery, and 33W fast charging keep daily work and outdoor tasks moving smoothly. With a 50MP main camera, 20MP night vision camera, 32MP front camera, 2K video recording, NFC, glove mode, 5G bands, GPS with QZSS, IP68 & IP69 protection, and MIL-STD-810H durability, it is ready for tough environments.
Why Choose Blackview BL7000 Pro?
Privacy & Security Upgrade↑ AI Intelligence Upgrade↑
*Test results based on Blackview laboratory conditions. Actual performance may vary in real-world use.
Stronger Seals. Greater Adventures
Aviation-grade aluminum alloy side keys fitted with silicone waterproof rings, delivering excellent rust and corrosion resistance with long-lasting sealing stability.
even in oily workshops or kitchens. Stay safe and operational during
rainy hikes or sudden downpours. Hold strong against cracks in
crowded commutes or
packed backpacks.
MediaTek HyperEngine Gaming Engine
Built-in gaming engine enhances in-game fluency. It improves power efficiency by 11% and boosts frame rate by 13% under heavy gaming loads.
50% Improved GPU Performance
10% Smoother Gaming Motion
Expandable Storage Massive Storage, Endless Possibilities Plenty of room for all your content. Featuring 512 built-in storage and 2TB expandable space, save all your photos, videos, games and files freely, never run out of memory again.
750nits Adaptive Brightness
Visible Even in Harsh Sunlight
Up to 750 nits adaptive brightness ensures outstanding screen performance. It remains clear and readable even under direct sunlight, delivering vivid visuals in all outdoor lighting conditions.
Multiple Eye-comfort Modes
All-day Eye Protection
Multi eye-care modes cut blue light and ease eye fatigue. Switch freely between tailored modes for relaxed reading, working and night browsing.
Reading Mode
Night Light
*The data is tested by Blackview Lab. The actual use shall prevail as it depends on different environments.
Intelligent Deep Power-Saving Mode
Intelligent Idle Power Control, Near Zero Overnight Drain
Smart standby management auto enables deep power-saving when the device is idle. It minimizes overnight battery consumption and extends all-day usage time, while preserving full performance without compromise.
33W Fast Charging
Rapid Recharge, No More Waiting
Quickly top up your BL7000 Pro and stay ready for busy days and outdoor journeys.
*The charger dock is sold separately.
dim environments.
autofocus in low light and
dynamic scenes.
Emergency Situations
Keep your phone ready to capture important moments during night-time emergencies or low-light scenarios.
AI Smart Google Lens
Identify Instantly, Explore Freely
Smart Google Lens supports instant recognition of objects, landmarks and texts. Simplify outdoor exploration and daily identification in any tough scenario.
Your Personal AI Companion Smart Q&A, document parsing and homework tutoring are all at your fingertips. Get instant, reliable answers anytime, perfectly fitting outdoor life and daily study needs.
Edit Smart, Create Bold Packed with 18 built-in AI tools, AI Photos lets you erase clutter, enhance clarity, animate photos and swap backgrounds with one tap. Edit daily shots and create artistic works effortlessly in just seconds.
AI Remove Objects
AI Remove Objects
AI OutPainting
AI Replace Background
AI Retouching
AI Animate
Relive Your Epic Journeys, Unleash Your Story Support text-to-video and image-to-video generation. Turn your travel photos and creative ideas into vivid funny clips in seconds, immortalizing every outdoor adventure.
Unleash Your Inner Musician Zero-threshold music creation for everyone. Generate exclusive melodies and complete original tracks with just a tap, letting your musical creativity flow freely anytime.
*Doke AI 2.0 is free to use. Images shown are for illustrative purposes only.
Privacy & Security Upgrade↑ AI Intelligence Upgrade↑ Equipped with the cutting-edge DokeOS 5.0 built on Android 16, BL7000 Pro steps up from the last-gen DokeOS 4.1 (Android 15). It achieves comprehensive upgrades in system fluency, efficiency, personalization, privacy security and AI intelligence, for an overall smoother, safer and smarter interactive experience.
Explore More
5-in-1 Navigation
Global Positioning, Pinpoint Accuracy
Faster signal locking, higher precision, and stable performance in dense cities, forests, and wild areas. Ideal for outdoor off-road adventures.
ToolBag App
All-in-One Utility Kit
Integrates multiple practical tools in one app, no need for extra gadgets. Meets daily measurement, outdoor exploration and routine use demands anytime.
Blackview BL7000 Pro Specification
ModelBL7000 Pro
ColorBlack, Orange
Dimension182.2*86*14.5mm
Weight357g
OSDokeOS 5.0 Based on Android 16
Display6.78-inch
1080*2460 resolution
120Hz Refresh Rate -
CPU5G MediaTek Dimensity 6300; Up to 2.4GHz
RAM & ROM8GB + 512GB / 8GB + 256GB
RAM ExpansionUp to 24GB
TF Expansion2TB
Battery7500mAh Battery; 33W Fast Charging &
6W OTG Reverse Charging -
Front Camera32MP
Rear Camera50MP (Samsung® JN1); 20MP(Night Vision)
Speaker1w; Smart-K
Rugged RatingMIL-STD-810H; IP68&IP69 Ratings
NavigationGPS/GLONASS/BeiDou/Galileo/QZSS
Card Slot2; 2*SIM/ 1*SIM+1*TF
Glove ModeSupport
NFCSupport
Wi-Fi802.11 b/g/n/a/ac
Wireless BTV5.2
Network Connectivity2G Band: B2/B3/B5/B8
3G Band:
WCDMA: B1/B2/B4/B5/B6/B8/B19
CDMA: BC0/BC1/BC10
4G Band:
TDD: B34/B38/B39/B40/B41
FDD: B1/B2/B3/B4/B5/B7/B8/B12/B13/B17/
B18/B19/B20/B25/B26/B28A/B28B/B30/B66
5G Band:
N1/3/5/7/8/20/28/38/40/41/77/78/79
| Design | |
| Product | BL7000 Pro |
| OS | DokeOS 5.0 Based on Android 16 |
| Color | Black, Orange |
| Weight | 357g |
| Dimensions | 182.2*86*14.5mm |
| Display | |
| LCD panel | BOE |
| IC | ILI7807S |
| Panel Type | IPS |
| Display Resolution | FHD+ |
| Screen Size | 6.78 Inch |
| Screen Resolution | 1080*2460 20:9 |
| Screen to Body Ratio (%) | 86% |
| PPI/DPI | PPI: 396 |
| Refresh frequency | 120HZ |
| Glass | Corning® Gorilla® Glass 5 |
| Connectivity | |
| WIFI | 802.11 b/g/n/a/ac |
| Bluetooth | V5.2 |
| 2G | B2/B3/B5/B8 |
| Hardware | |
| CPU | MediaTek Dimensity 6300 (6nm), Octa-core, Up to 2.4GHz |
| CPU Clock | ARM Cortex-A76 cores @ 2.4GHz*2, ARM Cortex-A55 cores @ 2.0GHz*6 |
| GPU | Arm Mali-G57 MC2 |
| RAM | 8GB |
| RAM Type | LPDDR4X |
| ROM | 256GB/512GB |
| ROM Type | UFS2.2 |
| TF Card Slot | YES |
| USB | TYPE-C |
| Camera | |
| Front Camera | 32MP |
| Front Camera Sensor | GC32E1-WA1XA |
| Front Camera Aperture | f2.2 |
| Rear Camera | 50MP main camera 20MP Night Vision Camera |
| Rear Camera Sensor | Samsung® JN1 + IMX376 + GC6133 |
| Rear Camera Aperture | f1.8 |
| Rear Flash | Yes |
| Video | 2K Video Recording |
| Power | |
| Battery Capacity | 7500mAh, 33W Fast Charge |
| Max Charging Current | 3A |
| Multi-media | |
| Video | HEVC, VP9, H.264, H.263, MPEG-4, MPEG-2, VP8, HEIF |
| Audio | WAV, MP3, AAC, AMR-NB, AMR-WB, MIDI, Vorbis, APE, AAC-plus v1, AAC-plus v2, FLAC, WMA, ADPCM, ALAC |
| Image | JPEG, WBMP, SVG-Tiny, EXIF |
| Features | |
| Motor | Flat motor |
| Sensors | G/P/L-sensor |
| Gyroscope | YES |
| Magnetic | YES |
| Air pressure sensor | NO |
| Hall | NO |
| Compass | YES |
| Fingerprint | YES |
| RGB | YES |
| NFC | YES |
| Hotkont | NO |
| Coulomb Counter | NO |
| Wireless Charging | NO |
| FM | YES |
| OTG | YES |
| Accessories | |
| User Manual | x1 |
| USB Cable | x1 |
