Blackview A50 6.088 inches Unisoc T310 Quad Core 3GB+64GB 4280mAh 13MP Camera 4G Smartphone
Note:
A50
More than You Expect
6.088" HD+ Display
Unisoc T310 Processor
5MP
Front Camera
3GB RAM + 64GB ROM
4280mAh Battery
13MP
Rear Camera
Android 11
Doke OS 2.0
Fingerprint
Unlock
6.088" HD + Display
Bigger & True-to-life Vision
Show more content in a frame on the large, expansive display for reading, catching up on some tasks, or web browsing without sliding back and forth. HD resolution gives an ideal clear vision.
6.088''
Screen Size
720*1560
HD+ Resolution
86.3%
Screen-to-body Ratio
380nit
Brightness
156g Light & 8.9mm Thin
Feature-packed Inside, Exquisite Outside
From super lightweight and ergonomic rounded curves to refined anti-fingerprint finish and stylish colors, it makes each grip a perfect fit in the palm and a relish for the touch and vision.
156g
Light
8.9mm
Thin
4280mAh Battery
Stay Energized for A Day
With full power before out and still powered on when back home, carry on your day ahead lively, whether for work or play, without any battery anxiety.
7.5hrs
Web
6hrs
Game
25hrs
Music
22hrs
Call
6hrs
Video
288hrs
*The data is tested by Blackview Laboratory. Battery life depends on the actual usage situations.
Quad-core Unisoc T310
Powerful to Your Demands
Powered by the Unisoc T310 to process quickly, run more apps simultaneously, and switch them seamlessly. A large storage room saves more content, including videos, music, eBooks, and files.
3GB
LPDDR4X RAM
64GB
ROM
Up to 1TB
Expandable
5MP Front + 13MP Rear
Awesome Photographs with the Taking
Every clip in life, from the hilarious travel time to bustle learning hour, is worth a video or photo shoot on the way. Derive immense satisfaction from your photographs in the album gallery.
13MP Sony® IMX258 Rear Camera
Doke OS 2.0
Based on Android 11, As Natural as Breathing
A50 adopts the Doke OS 2.0 based on Android 11 for better aesthetics, interaction, and efficiency.
Exquisite Wallpapers and App Icons
The all-new UI design combines style and viewing comfort.
System Manager
Support all-in-one controls such as trash cleaning and battery management.
Free up
More Space -
Smart
Power Saving -
Game
Speedup -
App
Management
Game Mode
Clean up RAM to save memory and block popups for interference-free gaming.
Before
After
Game
Other Apps
Cold Room
Freeze apps to avoid their stealthy background running and save memory.
Before
After
Screenshot/Long Screenshot
For important messages, make a screenshot or long screenshot and edit it easily.
Dual-window Entertainment
View different contents on the same screen to enable entertaining while working.
Rear-mounted
Fingerprint Sensor
Easy to reach and unlock within a snap.
Back Fingerprint Unlock
2+1 Card Slots
Have both — easy card switch & larger memory space.
Blackview A50
Colors
Summer Mojito
Twilight Blue
Ink Green
Phantom Black
Specifications
Model
A50
Dimension
156.4*72.9*8.9mm
Weight
156g
OS
Doke OS 2.0 (Based on Android 11)
Display
6.088" 720*1560 HD+ IPS
CPU
Quad-core Unisoc T310 2.0GHz
RAM & ROM
3GB RAM + 64GB ROM
Max TF Card Storage
1TB
Battery Capacity
4280mAh
Camera
5MP Front Camera
13MP Sony® IMX258 Rear Camera -
Navigation
GPS+GLONASS
Wi-Fi
802.11.b/ g/ n/ ac;
Network Connectivity
GSM spec: 2/3/5/8
WCDMA spec: B1/B8
TDD spec: B40
FDD spec: /B1/B3/B7/B8/B20
Dimensions
Height: 156.4mm
Width: 72.9mm
Thickness: 8.9mm
Weight: 156g -
Button/interface
