Details
Specifications
ModelXPLORE 6
ColorBlack
Dimension179.5*85.4*18.2mm
Weight428g
OSDokeOS 5.3 Based on Android 16
Display6.73-inch 3.2K AMOLED Display, 1440*3200 Resolution, 85% Screen-to-Body Ratio
Corning® Gorilla® Glass Victus® 2, 120Hz Refresh Rate; 1.47” AMOLED Sub-Display
CPUOcta-core 5G MediaTek Dimensity 9400+, 3nm, Up to 3.63GHz
RAM & ROM18GB RAM & 512GB ROM, LPDDR5X+UFS4.1
18GB RAM & 1TB ROM, LPDDR5X+UFS4.1
Battery12,000mAh; 120W Hyper Fast Charging + 80W Wireless Charging
Front Camera50MP
Rear Camera50MP Main+50MP Ultra-Wide Angle+50MP Periscope Telephoto
Speaker2W Box Speaker
Rugged RatingIP68 & IP69K & MIL-STD-810H
Navigation(L1、L5)GPS+GLONASS+Galileo+Beidou+QZSS+NavIC
Card SlotDual; 2*SIMs
NFCSupport
Dual 5G VoLTESupport
Wi-Fi&BluetoothWi-Fi 7; BT 5.4
Network Connectivity2G Band: B2/B3/B5/B8
3G Band:
WCDMA: B1/B2/B4/B5/B6/B8/B19 (RXD)
4G Band:
TDD:B34/B38/B39/B40/B41
FDD:B1/2/3/4/5/7/8/12/13/17/18/19/20/25/26/28A/28B/66
5G Band: N1/2/3/5/7/8/20/26/28/38/40/41/66/77/78
In the Box
What's in the box
Reviews
FAQ
What is the Blackview XPLORE 6?
The Blackview XPLORE 6 is a rugged 5G smartphone designed for outdoor activities, demanding work environments, and everyday use. It features a MediaTek Dimensity 9400+ processor, a 12,000mAh battery, a 6.73-inch 3.2K AMOLED display, and meets IP68, IP69K, and MIL-STD-810H protection standards.
Additionally, it features a 50-megapixel camera system with a periscope telephoto lens, a 1.47-inch rear display, 120W fast charging, and Android 16, ensuring a great experience whether you’re using it for daily tasks or working outdoors.
Who Is the Blackview XPLORE 6 Best For?
The Blackview XPLORE 6 is ideal for outdoor enthusiasts, hikers, campers, travelers, outdoor photographers, wildlife observers, and outdoor workers. With its rugged protection and 12,000 mAh battery capacity, it provides reliable protection and battery life for long trips, outdoor activities, and demanding work environments.
It’s also well-suited for expedition guides, field engineers, geologists, extreme-weather researchers, and photographers working in extreme environments. Not only does it support demanding field applications and multitasking, but its 50-megapixel camera system and periscope telephoto lens also help document work sites, environmental conditions, and outdoor scenes, while allowing for clearer observation of distant objects.
Why Choose Blackview XPLORE 6?
The Blackview XPLORE 6 is powered by the Dimensity 9400+ processor and features a 12,000mAh battery with 120W fast charging, as well as IP68, IP69K, and MIL-STD-810H protection ratings. It handles multitasking with ease and supports extended outdoor use, making it suitable not only for humid, dusty, or harsh environments but also for hiking, camping, travel, field research, and outdoor work.
It also features a 50-megapixel camera system and a periscope telephoto lens, making it easier to capture landscapes and distant subjects and offering greater flexibility for everyday and outdoor photography, wildlife observation, field surveys, and environmental documentation. If these are the kinds of situations you often find yourself in, the XPLORE 6 is a great fit.
Is the Blackview XPLORE 6 good for outdoor activities?
Yes. The Blackview XPLORE 6 isn’t just ideal for outdoor activities like hiking, camping, rock climbing, trekking, road trips, and exploring nature—it’s also effectively waterproof, dustproof, shock-resistant, and drop-resistant. Plus, its 12,000mAh battery capacity ensures you’ll have plenty of power for extended outdoor adventures.
In addition, the XPLORE 6 features a 6.73-inch 3.2K 120Hz AMOLED display, a Dimensity 9400+ processor, and a camera system with a periscope telephoto lens. Whether you’re checking maps on mountain trails, taking landscape photos, capturing distant wildlife, or staying connected during camping trips, it offers rugged protection along with everyday smartphone functionality.
Is the Blackview XPLORE 6 suitable for hiking and camping?
Yes. The Blackview XPLORE 6 is perfect for hiking and camping. It features robust protection and a high-capacity 12,000mAh battery, allowing extended outdoor use. Its durable build also withstands dust, water, bumps, and changing environmental conditions encountered while hiking or at campsites, making it more practical than a standard smartphone in harsh outdoor conditions.
While hiking or camping, the XPLORE 6 can also be used for navigation, viewing maps, taking photos and videos, staying in touch, and entertainment at the campsite. Its main camera, ultra-wide-angle camera, and periscope telephoto camera provide even greater flexibility, allowing users to capture mountain views, campsites, wildlife, and distant landscapes.
Is the Blackview XPLORE 6 suitable for outdoor work and fieldwork?
Yes. The Blackview XPLORE 6 is not only suitable for outdoor work but also for field operations. In these situations, it can easily handle dust, water, accidental drops, rough handling, or situations without power, while providing extra protection. It also features a 12,000mAh battery that supports extended outdoor use.
Beyond outdoor work and field operations, the Blackview XPLORE 6’s Dimensity 9400+ processor and 18GB of RAM provide the performance needed for communication, navigation, document processing, photography, and video recording. As a result, it’s also suitable for construction workers, surveyors, maintenance crews, field researchers, agricultural workers, and other professionals who use their phones outdoors.
Is the Blackview XPLORE 6 good for birdwatching and wildlife photography?
Yes. The Blackview XPLORE 6 is also an excellent choice for birdwatching and wildlife photography because it features a 50-megapixel periscope telephoto camera capable of capturing subjects at a distance. This feature comes in handy when you’re too far away from birds or wildlife to get a clear shot with a smartphone’s wide-angle camera, or when getting too close might startle the animals.
Its optical image stabilization reduces camera shake during shooting, while the ultra-wide-angle camera is ideal for capturing landscapes or natural habitats. Combined with a 12,000mAh battery and a rugged, durable body, the XPLORE 6 is well-suited for extended shooting sessions in outdoor environments such as forests, mountains, wetlands, and parks.
Is the Blackview XPLORE 6 suitable for travel and outdoor adventures?
Yes. The Blackview XPLORE 6 is ideal for travel and outdoor adventures, especially in remote areas such as mountainous forests and seaside camping sites where you’re off the grid. Its large battery capacity ensures you have ample power and provides extended battery life. In addition, it’s perfect for outdoor activities like road trips, backpacking, hiking, camping, and exploring nature.
While traveling, you can use the XPLORE 6 for navigation, photography, communication, video recording, entertainment, and checking your itinerary. Therefore, it’s the perfect companion for trips that combine everyday travel with outdoor activities.
Can the Blackview XPLORE 6 be used in harsh environments?
Yes. The Blackview XPLORE 6 rugged smartphone is specifically designed for more demanding environments. Its rugged construction not only provides extra protection but also withstands common outdoor challenges such as water, dust, mud, accidental drops, impacts, and rough handling, making it ideal for frequent outdoor work or activities.
This protection is particularly useful when traveling in harsh outdoor environments. However, rugged does not mean indestructible. It is recommended that you adhere to the XPLORE 6’s specified protection limits and avoid intentionally exposing the phone to conditions beyond its rated tolerance.
Is the Blackview XPLORE 6 good for photography?
Yes. The Blackview XPLORE 6’s 50-megapixel periscope telephoto camera is particularly well-suited for photographing and observing distant subjects, including birds, wildlife, landscapes, and other far-off scenes. It offers users greater flexibility for birdwatching, wildlife photography, outdoor exploration, and long-distance shooting.
The XPLORE 6 also supports an optional external telephoto extender, which, when attached to the phone, enhances its long-distance shooting capabilities.
How durable is the Blackview XPLORE 6?
The Blackview XPLORE 6 features IP68 and IP69K protection ratings and has passed MIL-STD-810H testing, making it capable of withstanding rain, dust, dirt, accidental drops and impacts commonly encountered during outdoor use.
Whether you’re hiking, camping, travelling or working in the field, the XPLORE 6 is designed to cope with more challenging or harsh environments. However, prolonged wear and tear or severe impacts may reduce its protective performance; it is therefore recommended that you avoid using the device beyond its specified protection limits.
How long does the Blackview XPLORE 6 battery last?
The actual battery life of the Blackview XPLORE 6 depends on how you use the phone. It has a 12,000mAh battery, which makes it a good fit for long hikes, camping, travel, fieldwork, GPS navigation, and taking photos or videos.
Using 5G, GPS, high screen brightness, gaming, the camera, video recording, or background apps for a long time will use more power than light everyday use. The XPLORE 6 also supports 120W fast charging, so the battery can charge up faster when needed. This is also useful for long periods outdoors or when you are far from a power source.
How powerful is the Blackview XPLORE 6?
The XPLORE 6 delivers an experience that far exceeds the basic performance of ordinary rugged smartphones. It is powered by the MediaTek Dimensity 9400+ chipset and features 18GB of RAM, providing the processing power and memory needed for resource-intensive apps, multitasking, gaming, high-resolution photography, video recording, and other demanding tasks.
In addition, it features a 6.73-inch 3.2K AMOLED display with a 120Hz refresh rate and offers up to 1TB of storage. This ensures your phone not only boasts rugged protection but also delivers top-tier performance and display quality without compromise.
What is the secondary screen on the Blackview XPLORE 6 used for?
The Blackview XPLORE 6 is equipped with a 1.47-inch secondary screen, allowing users to access selected information and features without having to rely on the larger main screen for every interaction. It enables users to quickly view information without having to open and navigate the full main screen.
While traveling, exercising, working, or participating in outdoor activities, the secondary screen can also be used to take photos, which is very convenient for taking selfies when traveling alone. However, the secondary screen is a supplement to the 6.73-inch AMOLED main screen, not a replacement. For maps, apps, photography, gaming, videos, and other tasks, it’s recommended to use the main screen instead.
Is the Blackview XPLORE 6 worth buying?
Yes, it is. If you value durability, long battery life, powerful performance, and versatile photography, the XPLORE 6 is worth considering. Not only is it built to be rugged, but it also features the Dimensity 9400+ chipset, 18GB of RAM, a 3.2K 120Hz AMOLED display, a 12,000mAh battery, 120W fast charging, and a periscope telephoto camera.
If you only plan to use it for calls, social media, and occasional photos, you probably don’t need a rugged model. However, if you enjoy hiking, camping, photography, frequent travel, or working outdoors—especially in harsh environments—the XPLORE 6 is the ideal choice.
Blackview XPLORE 6 vs. XPLORE 2: What are the differences?
The Blackview XPLORE 6 and XPLORE 2 are both rugged smartphones designed for outdoor use, but they differ in performance, battery capacity, and camera capabilities. The table below shows their key differences.
Feature Blackview XPLORE 6 Blackview XPLORE 2
Processor Dimensity 9400+ Dimensity 8300
RAM 18GB 12GB / 16GB
Storage 512GB / 1TB 256GB / 1TB
Display 6.73" 3.2K AMOLED, 120Hz 6.73" 3.2K AMOLED, 120Hz
Battery 12,000mAh 20,000mAh
Fast Charging 120W 120W
Rear Camera 50MP Main + 50MP Ultra-wide +
50MP Main + 20MP Night Vision
Telephoto Extender Compatible with Optional Telephoto Extender Not Supported
Front Camera 50MP 50MP
OS Android 16 Android 15-based DokeOS 4.2
Does the Blackview XPLORE 6 Support a Teleconverter Lens?
Yes. The Blackview XPLORE 6 supports an external teleconverter, which works in conjunction with the phone’s built-in periscope telephoto camera. Once installed, shooting operations can be controlled and managed through the phone’s camera app.
The teleconverter further extends the shooting distance, helping you capture distant subjects more clearly. It can be used for landscape photography, birdwatching, and wildlife photography, as well as concerts, outdoor events, and other long-distance shooting scenarios.
