Blackview XPLORE 2 Projector 5G AI Rugged Phone with 6.73" 3.2K AMOLED Display Dimensity 8300 20000mAh & Built-in Camping Light
Available in stock (32)
✔Up to 100-inch 480P Projector w/ Cooling Fan & Projection Clip
✔6.73" 120Hz 3.2K LTPO AMOLED Display
✔Built-in 467 Lumen Dual Camping Light
✔MediaTek Dimensity 8300 4nm 5G Octa-core & WiFi 6E
✔20000mAh Battery w/ 120W Fast Charging
✔50MP Main+20MP Night Vision Camera
✔IP68 &IP69K & MIL-STD-810H Certified
✔eSIM Support
The Blackview XPLORE 2 Projector combines flagship rugged performance with built-in mobile projection for work, travel, and outdoor entertainment. Its 6.73-inch 120Hz 3.2K AMOLED display, Dimensity 8300 processor, 20,000mAh battery, and 120W fast charging deliver strong everyday power. The integrated projector supports up to 100-inch 480P projection with 100LM brightness, while the dual 467LM camping light adds practical night use. With 5G, WiFi 6E, 50MP main camera, 20MP night vision, NFC, and premium rugged utility, it is made for users who need more than a phone.
| Model | XPLORE 2 Projector |
| Color | Black |
| Dimension | 186 * 87.8 * 29mm |
| Weight | 710g |
| OS | DokeOS 4.2 based on Android 15 |
| Display | 6.73-inch 3.2K AMOLED Display, 1440*3200 Resolution, 120Hz Refresh Rate, Corning® Gorilla® Glass 5 |
| CPU | Octa-core 5G MediaTek Dimensity 8300, 4nm, Up to 3.35GHz |
| RAM & ROM | 12GB RAM & 256GB ROM, LPDDR5X+UFS4.0 16GB RAM & 1TB ROM, LPDDR5X+UFS4.0 |
| TF Expansion | Up to 2TB TF Expansion |
| Battery | 20,000mAh; 120W Hyper Fast Charging |
| Front Camera | 50MP |
| Rear Camera | 50MP Main+20MP Night Vision |
| Speaker | Smart-K BOX Speaker |
| Navigation | L1+L5 GPS/GLONASS/BeiDou/Galileo |
| Card Slot | Dual: 2*SIM/1*SIM +1*TF Card |
| NFC | Support |
| Dual 5G VoLTE | Support |
| Wi-Fi&Bluetooth | Wi-Fi6E; BT 5.4 |
| Network Connectivity | 2G Band: B2/B3/B5/B8 3G Band: WCDMA: B1/B2/B4/B5/B6/B8/B19 (RXD) CDMA: BC0 4G Band: TDD:B34/B38/B39/B40/B41 FDD:B1/2/3/4/5/7/8/12/13/17/18/19/20/25/26/28A/28B/30/66 5G Band: N1/3/5/7/8/20/28/38/40/41/77/78/79 |
Is the Blackview XPLORE 2 a Rugged Phone for Outdoor Use?
Who Is the Blackview XPLORE 2 Rugged Phone Best For?
What Can You Use the Blackview XPLORE 2 Rugged Phone For?
What Makes the Blackview XPLORE 2 Different from Other Rugged Phones?
Is the Blackview XPLORE 2 a Good Rugged Phone for Camping?
How Durable Is the Blackview XPLORE 2 Rugged Phone?
Does the Blackview XPLORE 2 Rugged Phone Have a Large Battery?
Does the Blackview XPLORE 2 Rugged Phone Have a Built-In Projector?
How Large Can the Blackview XPLORE 2 Projector Display?
Is the Blackview XPLORE 2 Projector Good for Outdoor Movies?
Can the Blackview XPLORE 2 Projector Be Used for Presentations?
Does the Blackview XPLORE 2 Projector Work Well in the Dark?
Can the Blackview XPLORE 2 Replace a Portable Projector?
What Is the Difference Between the Blackview XPLORE 2 and the XPLORE 2 Projector?
The Blackview XPLORE 2 and XPLORE 2 Projector share many features, but there are some key differences between them. Here is a brief comparison of the two models to help you choose the one that best suits your needs.
XPLORE 2 vs. XPLORE 2 Projector
| Feature | Blackview XPLORE 2 | Blackview XPLORE 2 Projector |
| Rugged Protection | IP68, IP69K, MIL-STD-810H | IP68, IP69K, MIL-STD-810H |
| Display | 6.73-inch 3.2K AMOLED, 120Hz | 6.73-inch 3.2K AMOLED, 120Hz |
| Processor | Dimensity 8300 5G | Dimensity 8300 5G |
| Battery | 20,000mAh | 20,000mAh |
| Fast Charging | 120W | 120W |
| Rear Camera | 50MP main + 20MP night vision | 50MP main + 20MP night vision |
| Camping Light | 467 lumens | 467 lumens |
| Built-In Projector | No | Yes |
| Projection Size | No | Up to 100 inches |
| Projection Resolution | No | 480P |
| Projection Brightness | No | 100 lumens |
| Weight | 670g | 710g |
