Blackview XPLORE 1 Walkie Talkie 5G Rugged Phone with Walkie-talkie 6.78-inch 120Hz Main & 2.01" Secondary Display 20000mAh Battery
Available in stock (13)
✔Built-in Hardware Walkie Talkie w/ 2-in-1 Dual-Band Antenna & AES Encrypted Secure Talk
✔20,000mAh Massive Battery & Support 45W Dock Charging
✔64MP Main+50MP Front+20MP Night Vision Camera
✔6.78" 120Hz Main & 2.01" Multi-functional Secondary Display
✔6nm 5G MediaTek Dimensity 7050 Octa-core
✔Leading IP68 &IP69K & MIL-STD-810H Certified
The Blackview XPLORE 1 Walkie Talkie is built for teams, explorers, and field users who need communication beyond a regular smartphone. It combines a built-in hardware walkie talkie with a 2-in-1 dual-band antenna, AES encrypted secure talk, and rugged 5G performance. A 6.78-inch 120Hz main display, 2.01-inch secondary screen, 20,000mAh battery, 45W dock charging support, 64MP main camera, 50MP front camera, 20MP night vision, and IP68 & IP69K protection make it ready for remote work and outdoor coordination.
With AES-Secured Walkie-Talkie Beyond Signals, Conquer Darkness, Power the Journey
Walkie Talkie
Night Vision Camera
Massive Power Bank
Infrared Remote Control
Dual-Band 5-System Navigation
Dual-Mode UHF/ VHF Walkie Talkie Safer ↑ Wider ↑ Stronger ↑More Convenient ↑
Works Anywhere
Instant Response
20-Hour Call
Locked & Secure
Crisp, Clear Sound
Buildings
Factories
Indoors Wider Coverage
Mountains
Fields
Open Areas
No Antenna Swap
Talk Longer, Go Further
Group Call & All Call Your Voice, Only Heard by Target Seamlessly switch between one-on-one private chats to team coordination of 100+ members, or full-channel broadcasting. Ideal for outdoor work, security, and construction, your message always reaches exactly who it should.
Private Call for one-to-one communication
Group Call for team coordination
All Call to broadcast instantly to everyone on the channel
efficiently, anytime, anywhere.
Even in a Factory Stop struggling with unclear calls. 2W high-volume audio with noise reduction cuts through crowds, wind, and machinery noise.
Speaker
Output Power
Loudness
Crowds Noise
Machinery Noise
Peers
Only voice is Heard
Never miss Critical Words
Focused, Efficient
Resistance, 1.5m Death-broke Drop-proof,
Protection, 6m Free-fall Durability Beyond the Limits, Conquer Every Extreme
Touch
Sensitivity
Videos Underwater with Ease
Every Chosen Material, Rigorously Tested and Proven,
Fearless of Any Challenge
aperture earpiece mesh
USB Port with Plug
camera and side buttons
5 Screen 2x improved scratch &
drop resistance
Aluminum Alloy Shell
Unscratched
500kg of Pressure
5000+ Times
10,000+ Times
1000+ Times
Certification
Drop-proofness
Please note that real-world performance may vary.
device that uses an IR remote, including
TV
Air conditioner
Set-top box
DVD player
Projector
Fan
IR-controlled lighting
Others
Immersive Visual Experience from Every Detail Dual Screens, Doubled Efficiency
for Any Adventure Power Beyond Limits,
Charge Quicker than Ever
≈ 4x mobiles of regular battery capacity
Computing 2.0
Protection Extended Battery Life
Protection Algorithm
a seamless power-up experience.
Charging
Speed Dock Charging 45W
Charging Dock
Accelerator
Higher Efficiency
& Wider Coverage
Energy-saving AI Features
6*A55@2.0GHz UP to 2.4GHz Clock Speed ARM Mali-G68 MC4
Dual-band
WiFi 6
WiFi 5 Tech
16GB RAM + 32GB Expansion
Every Moment, Vividly Recorded
Capture Clearly Day or Night
(f/1.79)1/2″
6P
SONY® IMX376
(f/1.8)1/2.8″
6P
Samsung® JN1
(f/1.8)1/2.76″
5P
super pixel to enhance
light sensitivity
of Light and Color
Information
More Accurate
Autofocus
Control
Seamless Brightness
Transition
See Every Detail Effortlessly capture crisp, clear, and highly detailed images even in low light or complete darkness. Whether you’re documenting nocturnal wildlife, navigating challenging terrains, or assisting in field rescues, count on it to deliver sharp, illuminating photos every time.
Wildlife Activity Capture every detail of wildlife for worry-free observation
to enhance the safety
During Earthquake Deliver clear images
to rapidly target location
Effortless Clarity
Smart Shooting Assistance Perfect Shoots, Easy Control
Smarter to Operate Powered by DeepSeek-R1,
ChatGPT, Gemini AI 2.0 Flash
Assistance
Ideas Unleashed
Composition
Parsing
DeepSeek-R1
Assistant
Make Every Post Go Viral
Useful Features to Explore, More Seamless and Effortless Every Day
Dual-band GPS+Beidou+
Glonass+Galileo+QZSS
Quick, Professional, and Always Here for you
Online Support Get help anytime,
anywhere.
Repair Centers Expert technicians,
genuine parts.
Android Updates Always fresh, secure,
and up to date.
Warranty Peace of mind for the
long haul.
ModelXPLORE 1 Walkie Talkie
ColorBlack, Orange
Dimension184*83*29.5mm
Weight695g (with Antenna) / 680g (without Antenna)
OSDokeOS5.0 Based on Android 15
Display6.78-inch 2.4K FHD+IPS, 1080*2460 Resolution,
Corning® Gorilla® Glass 5,120Hz Refresh Rate,
Secondary Screen: 2.01-inch, 240*296 Resolution -
CPUOcta-core 5G MediaTek Dimensity 7050, 6nm, Up to 2.4GHz
RAM & ROM12GB RAM & 256GB ROM, LPDDR5+UFS3.1
16GB RAM & 512GB ROM, LPDDR5+UFS4.0 -
TF ExpansionUp to 2TB Expansion
Battery20,000mAh; 55W Fast Charging
Front Camera50MP (Samsung® ISOCELL JN1)
Rear Camera64MP Main+20MP Night Vision
Speaker1PC 1134 Smart-K BOX Speaker
Rugged RatingIP68 &IP69K& MIL-STD-810H
NavigationGPS/GLONASS/BeiDou/Galileo/QZSS( L1、L5)
Card SlotDual; 2*SIM/1*SIM +1*TF Card
Glove ModeSupport
NFCSupport
Dual 5G VoLTESupport
Network Connectivity2G Band: B2/B3/B5/B8
3G Band:
WCDMA: B1/B2/B4/B5/B6/B8/B19,
CDMA: BC0/BC1/BC10
4G Band:
TDD: B34/B38/B39/B40/B41
5G Band: N1/3/5/7/8/20/28/38/40/41/77/78
| Design | |
| Product | Blackview XPLORE 1 Walkie Talkie |
| OS | DokeOS 5.0 Based on Android 15 |
| Color | Black, Orange |
| Weight | 695g (with Antenna) / 680g (without Antenna) |
| Dimensions | 184×83×29.5mm |
| Screen | |
| Main Display | |
| LCD panel | BOE I680EBQ-12Q01X |
| IC | ILI7807S-10000IA |
| Panel Type | IPS |
| Display Resolution | FHD+ |
| Screen Size | 6.78 Inch |
| Screen Resolution | 1080*2460 20:9 |
| Screen to Body Ratio (%) | 86% |
| PPI/DPI | PPI: 396 |
| Refresh frequency | 120HZ |
| Glass | Corning® Gorilla® Glass 5 |
| Secondary Display | |
| Screen Size | 2.01 Inch |
| Screen Resolution | 240*296 |
| Glass | Panda Glass |
| Connectivity | |
| Bluetooth | V5.2 |
| 2G | B2/B3/B5/B8 |
| Two-way Radio Walkie-talkie | AES-Secured, Dual Mode Compatibility(Digital + Analog), 2-in-1 Dual-Band Antenna (UHF + VHF) UHF Band (400~480MHz) VHF Band (136~174MHz) |
| Hardware | |
| CPU | MediaTek Dimensity 7050 (6nm), Octa-core, Up to 2.4GHz |
| CPU Clock | ARM Cortex-A78 cores @ 2.4GHz*2, ARM Cortex-A55 cores @ 2.0GHz*6 |
| GPU | ARM Mali-G68 MC4 |
| RAM | 12GB/16GB |
| RAM Type | LPDDR5 |
| ROM | 256GB/512GB |
| ROM Type | UFS3.1 |
| TF Card Slot | YES |
| USB | TYPE-C |
| Camera | |
| Front Camera | 50MP |
| Front Camera Aperture | f2.45 |
| Rear Camera | 64MP main camera 20MP Night Vision Camera |
| Rear Camera Sensor | OV64B40-GA5A-002A + IMX376 |
| Rear Camera Aperture | f1.79 |
| Rear Flash | Yes |
| Video | 4K Video Recording |
| Power | |
| Battery Capacity | 20,000mAh, 55W Fast Charge |
| Max Charging Current | 20V/2.75A |
| Multi-media | |
| Image | jpeg\png\gif\bmp |
| Features | |
| Motor | Flat motor |
| Sensors | G/P/L-sensor |
| Gyroscope | YES |
| Magnetic | YES |
| Air pressure sensor | NO |
| Hall | NO |
| Compass | YES |
| Fingerprint | YES |
| RGB | NO |
| NFC | YES |
| Hotkont | NO |
| Coulomb Counter | YES |
| Wireless Charging | NO |
| FM | YES |
| OTG | YES |
| Infrared Remote Control | YES |
| Accessories | |
| User Manual | x1 |
| USB Cable | x1 |
| Antenna | x1 |
Can the XPLORE 1 Walkie Talkie Rugged Phone Work Without Cellular Service?
What Walkie-Talkie Frequencies Does the XPLORE 1 Rugged Phone Support?
Does the XPLORE 1 Walkie Talkie Rugged Phone Support Digital and Analog Radio?
Can the XPLORE 1 Walkie Talkie Rugged Phone Connect with Other Walkie-Talkies?
How Far Can the Blackview XPLORE 1 Walkie Talkie Rugged Phone Communicate?
Does the XPLORE 1 Walkie Talkie Rugged Phone Support Encrypted Communication?
How Long Does the XPLORE 1 Walkie Talkie Rugged Phone Battery Last?
Does the Blackview XPLORE 1 Walkie Talkie Rugged Phone Support 5G?
Is the XPLORE 1 Walkie Talkie Rugged Phone Waterproof, Dustproof, and Drop-Resistant?
Does the XPLORE 1 Walkie Talkie Rugged Phone Have Night Vision?
Does the XPLORE 1 Walkie Talkie Rugged Phone Support GPS Navigation?
Can the XPLORE 1 Walkie Talkie Rugged Phone Be Used While Wearing Gloves?
What Outdoor Activities Is the XPLORE 1 Walkie Talkie Rugged Phone Suitable For?
What Is the Difference Between the Blackview XPLORE 1 and XPLORE 1 Walkie Talkie?
The main difference between the XPLORE 1 and XPLORE 1 walkie-talkies is that the walkie-talkie version includes additional dedicated UHF/VHF radio communication capabilities to meet the needs of users who require direct two-way communication. Below is a brief comparison table:
XPLORE 1 vs. XPLORE 1 Walkie Talkie
| Feature | Blackview XPLORE 1 | Blackview XPLORE 1 Walkie Talkie |
| 5G Support | Yes | Yes |
| Battery | 20,000mAh | 20,000mAh |
| Main Camera | 64MP | 64MP |
| Night Vision Camera | 20MP | 20MP |
| Main Display | 6.78-inch 120Hz | 6.78-inch 120Hz |
| Secondary Display | 2.01-inch | 2.01-inch |
| Rugged Protection | IP68 / IP69K / MIL-STD-810H | IP68 / IP69K / MIL-STD-810H |
| Built-in Walkie-Talkie | No | Yes |
| UHF / VHF Radio | No | Yes |
| Digital & Analog Radio | No | Yes |
| Dual-Band Antenna | No | Yes |
| PTT Button | No | Yes |
| AES Encrypted Communication | No | Yes |
| Best For | Users who want a rugged phone with a large battery and outdoor features | Users who need both a rugged phone and direct two-way radio communication |
Who Is the Blackview XPLORE 1 Walkie-Talkie Rugged Phone Best For?
