Blackview XPLORE 1 Walkie Talkie 5G Rugged Phone with Walkie-talkie 6.78-inch 120Hz Main & 2.01" Secondary Display 20000mAh Battery
Available in stock (13)
✔Built-in Hardware Walkie Talkie w/ 2-in-1 Dual-Band Antenna & AES Encrypted Secure Talk
✔20,000mAh Massive Battery & Support 45W Dock Charging
✔64MP Main+50MP Front+20MP Night Vision Camera
✔6.78" 120Hz Main & 2.01" Multi-functional Secondary Display
✔6nm 5G MediaTek Dimensity 7050 Octa-core
✔Leading IP68 &IP69K & MIL-STD-810H Certified
The Blackview XPLORE 1 Walkie Talkie is built for teams, explorers, and field users who need communication beyond a regular smartphone. It combines a built-in hardware walkie talkie with a 2-in-1 dual-band antenna, AES encrypted secure talk, and rugged 5G performance. A 6.78-inch 120Hz main display, 2.01-inch secondary screen, 20,000mAh battery, 45W dock charging support, 64MP main camera, 50MP front camera, 20MP night vision, and IP68 & IP69K protection make it ready for remote work and outdoor coordination.
| Design | |
| Product | Blackview XPLORE 1 Walkie Talkie |
| OS | DokeOS 5.0 Based on Android 15 |
| Color | Black, Orange |
| Weight | 695g (with Antenna) / 680g (without Antenna) |
| Dimensions | 184×83×29.5mm |
| Screen | |
| Main Display | |
| LCD panel | BOE I680EBQ-12Q01X |
| IC | ILI7807S-10000IA |
| Panel Type | IPS |
| Display Resolution | FHD+ |
| Screen Size | 6.78 Inch |
| Screen Resolution | 1080*2460 20:9 |
| Screen to Body Ratio (%) | 86% |
| PPI/DPI | PPI: 396 |
| Refresh frequency | 120HZ |
| Glass | Corning® Gorilla® Glass 5 |
| Secondary Display | |
| Screen Size | 2.01 Inch |
| Screen Resolution | 240*296 |
| Glass | Panda Glass |
| Connectivity | |
| Bluetooth | V5.2 |
| 2G | B2/B3/B5/B8 |
| Two-way Radio Walkie-talkie | AES-Secured, Dual Mode Compatibility(Digital + Analog), 2-in-1 Dual-Band Antenna (UHF + VHF) UHF Band (400~480MHz) VHF Band (136~174MHz) |
| Hardware | |
| CPU | MediaTek Dimensity 7050 (6nm), Octa-core, Up to 2.4GHz |
| CPU Clock | ARM Cortex-A78 cores @ 2.4GHz*2, ARM Cortex-A55 cores @ 2.0GHz*6 |
| GPU | ARM Mali-G68 MC4 |
| RAM | 12GB/16GB |
| RAM Type | LPDDR5 |
| ROM | 256GB/512GB |
| ROM Type | UFS3.1 |
| TF Card Slot | YES |
| USB | TYPE-C |
| Camera | |
| Front Camera | 50MP |
| Front Camera Aperture | f2.45 |
| Rear Camera | 64MP main camera 20MP Night Vision Camera |
| Rear Camera Sensor | OV64B40-GA5A-002A + IMX376 |
| Rear Camera Aperture | f1.79 |
| Rear Flash | Yes |
| Video | 4K Video Recording |
| Power | |
| Battery Capacity | 20,000mAh, 55W Fast Charge |
| Max Charging Current | 20V/2.75A |
| Multi-media | |
| Image | jpeg\png\gif\bmp |
| Features | |
| Motor | Flat motor |
| Sensors | G/P/L-sensor |
| Gyroscope | YES |
| Magnetic | YES |
| Air pressure sensor | NO |
| Hall | NO |
| Compass | YES |
| Fingerprint | YES |
| RGB | NO |
| NFC | YES |
| Hotkont | NO |
| Coulomb Counter | YES |
| Wireless Charging | NO |
| FM | YES |
| OTG | YES |
| Infrared Remote Control | YES |
| Accessories | |
| User Manual | x1 |
| USB Cable | x1 |
| Antenna | x1 |
Can the XPLORE 1 Walkie Talkie Rugged Phone Work Without Cellular Service?
What Walkie-Talkie Frequencies Does the XPLORE 1 Rugged Phone Support?
Does the XPLORE 1 Walkie Talkie Rugged Phone Support Digital and Analog Radio?
Can the XPLORE 1 Walkie Talkie Rugged Phone Connect with Other Walkie-Talkies?
How Far Can the Blackview XPLORE 1 Walkie Talkie Rugged Phone Communicate?
Does the XPLORE 1 Walkie Talkie Rugged Phone Support Encrypted Communication?
How Long Does the XPLORE 1 Walkie Talkie Rugged Phone Battery Last?
Does the Blackview XPLORE 1 Walkie Talkie Rugged Phone Support 5G?
Is the XPLORE 1 Walkie Talkie Rugged Phone Waterproof, Dustproof, and Drop-Resistant?
Does the XPLORE 1 Walkie Talkie Rugged Phone Have Night Vision?
Does the XPLORE 1 Walkie Talkie Rugged Phone Support GPS Navigation?
Can the XPLORE 1 Walkie Talkie Rugged Phone Be Used While Wearing Gloves?
What Outdoor Activities Is the XPLORE 1 Walkie Talkie Rugged Phone Suitable For?
What Is the Difference Between the Blackview XPLORE 1 and XPLORE 1 Walkie Talkie?
The main difference between the XPLORE 1 and XPLORE 1 walkie-talkies is that the walkie-talkie version includes additional dedicated UHF/VHF radio communication capabilities to meet the needs of users who require direct two-way communication. Below is a brief comparison table:
XPLORE 1 vs. XPLORE 1 Walkie Talkie
| Feature | Blackview XPLORE 1 | Blackview XPLORE 1 Walkie Talkie |
| 5G Support | Yes | Yes |
| Battery | 20,000mAh | 20,000mAh |
| Main Camera | 64MP | 64MP |
| Night Vision Camera | 20MP | 20MP |
| Main Display | 6.78-inch 120Hz | 6.78-inch 120Hz |
| Secondary Display | 2.01-inch | 2.01-inch |
| Rugged Protection | IP68 / IP69K / MIL-STD-810H | IP68 / IP69K / MIL-STD-810H |
| Built-in Walkie-Talkie | No | Yes |
| UHF / VHF Radio | No | Yes |
| Digital & Analog Radio | No | Yes |
| Dual-Band Antenna | No | Yes |
| PTT Button | No | Yes |
| AES Encrypted Communication | No | Yes |
| Best For | Users who want a rugged phone with a large battery and outdoor features | Users who need both a rugged phone and direct two-way radio communication |
Who Is the Blackview XPLORE 1 Walkie-Talkie Rugged Phone Best For?
