Blackview WAVE 2C 5-inch Unisoc SC9863A1 Octa-core 3000mAh Small 4G Smartphone
Hurry up, only 4 items left in stock.
✔5-inch display with a slim 11.1mm body
✔Unisoc SC9863A1 chipset with 3GB RAM and 32GB storage
✔2MP front camera and 5MP rear camera
✔Face unlock, 3.5mm headphone jack, and three satellite navigation systems
Blackview WAVE 2C is made for simple living, offering a compact palm-sized phone that feels light, comfortable, and easy to use. Its 5-inch display, 11.1mm slim body, 158.5g weight, Panda Glass screen, and Android 16 Go system support clear everyday operation. With Unisoc SC9863A1, 3GB RAM, 32GB ROM, up to 9GB RAM expansion, 1TB TF storage, 3000mAh battery, Google Lens, 2MP front camera, 5MP rear camera, face unlock, 3.5mm audio jack, and triple-satellite navigation, it keeps daily essentials simple.
| Model | WAVE 2C |
| Colors | Shadow Black / Blaze Orange |
| Dimension | 135.6*70.2*11.1 mm |
| Weight | 158.5 g |
| OS | Android 16 GO |
| Display | 5", 854*480 Resolution, 198 PPI, 400 nits Brightness, 60Hz Refresh Rate |
| CPU | Octa Core Unisoc SC9863A1 |
| RAM & ROM | 3GB RAM + 32GB ROM, Up to 9GB RAM Expansion |
| Expandable Storage | Up to 1TB TF Expansion |
| Battery | 3000mAh (5W Charger Power) |
| Front Camera | 2MP |
| Rear Camera | 5MP |
| Speaker | Single |
| Navigation | GPS+GLONASS+Galileo |
| Card Slot | 2 × SIMs + 1 × TF Card |
| BT Version | 4.2 |
| WiFi Version | 2.4G(802.11 b/g/n) |
| Connectivity | 2G Band: B2/B3/B5/B8 3G Band: B1/B2/B4/B5/B8(With Diversity) 4G Band: TDD: B38/B40/B41(With Diversity) FDD:B1/B2/B3/B4/B5/B7/B8/ B12/B17/B18/B19/B20/B26/ B28A/B28B/B66(With Diversity) |
