Blackview W60 2.01-inch 900mAh LED Flashlight Campass Outdoor Smart Watch
Available in stock (31)
✔ 2.01-inch Big Screen
✔900mAh Battery, Up to 30 Days Usage
✔Built-in LED Flashlight & Compass Function
✔Heart Rate & Oxygen Monitor
Blackview W60 is built for users who want a rugged smartwatch with long battery life and practical outdoor tools. Its large 2.01-inch screen makes information easy to check, while the lightweight 61g body keeps it comfortable for daily wear. With up to 30 days of typical use, Bluetooth calling, IP68 protection, a built-in LED flashlight, and a compass, W60 is ready for camping, outdoor work, long trips, and demanding routines. For users who value durability, endurance, and useful everyday tools over a slim fashion-first design, Blackview W60 is a dependable smartwatch made for real life.
Blackview W60
Big Hero in Bluetooth
Calling Rugged
Smartwatch
Bigger 2.01" Screen, Bigger 900mAh
Battery, Bigger LED Flashlight!
NO.1
The World's First Rugged Smart Watch with LED Flashlight
NO.2
High-Quality, Ultra-Stable Bluetooth Calling Tech
NO.3
The Largest 2.01" Super-clear Display & Longest 900mAh Battery Ever
NO.4
Smarter, More Functional, More Personalized
NO.1
THE WORLD'S FIRST
RUGGED SMART WATCH
WITH LED FLASHLIGHT
Working in Extreme Conditions
Rugged
PANDA®
Glass
Withstand up to
7KG of Pulling Force
All-new Colorfast
Oil-filling
Craftsmanship
IP68 Waterproof
& Dust-proof
Weight-bearing
Capability of up to 7kg
Up to 5m DeathBroke Drop-proofness
Built-in LED flashlight
Always in the right direction
Salt Spray & Alcohol &
Cosmetics-resistant
All-new Colorfast Oil-filling Craftsmanship
The fonts on W60 are manufactured by an all-new oil-filling process, providing outstanding salt spray resistance . Therefore, whether you are sweating profusely at the gym, or cooking in a smoky kitchen, you don't need to take off the W60. Even alcohol or cosmetics will not easily fade its bright fonts, ensuring its durability.
Anti-Fingerprint & Anti-Impact
Even for Sharp Objects
Thicker PANDA@ Glass
Thicker PANDA@ Glass is more durable and can effectively resist scratches and accidental collisions. Occasional bumps and knocks will not have any impact on W60’s understated body. Meanwhile, the anti-fingerprint technology makes the screen less prone to fingerprints and smudges, keeping it clean and enhancing elegance and sophistication.
30% More Robust Structure
Withstand up to 7KG of Pulling Force
The sturdy watch strap and case of the W60 allow it to withstand tensile forces of up to 7kg without damage . Therefore, when you are weight lifting at the gym, rock climbing, or participating in other strenuous activities, you don't need to worry about the watch getting snapped off. It will continuously and reliably record your heart rate and blood oxygen levels, becoming a powerful assistant on your adventures.
Water and Dust Won't Stop Us
IP68 Waterproof & Dust-proof
You can be confident that water droplets from handwashing or light rain will not damage the W60 with its up to 10-meter waterproof. Besides, its IP68 rating ensures complete protection against dust ingress. Whether you are engaging in outdoor activities such as hiking and cycling, or cleaning your room, you can be assured that dust contamination will not be a concern.
Sweating in the gym
Splash-proof when washing hands
Meet light rain on the way home
Watch fell into a creek while hiking
Always be Durable
Up to 5m Death Broke
Drop-proofness
Whether you make a mistake in daily life or travel where accidents may occur, your watch may be damaged by falling from heights or suffering impacts. Equipped with rugged PANDA® Glass and wear-resistant zinc alloy body, Blackview W60 is designed to withstand drops from up to 5m.
* The above data comes from Blackview laboratory, which may
vary due to different conditions.
Knocked off the watch
on the table
Flung the watch off
while jogging
Dropped on the ground
while climbing
Remain Operational From
-30℃ to 70℃
Free Your Hands, Light Your Way
When it gets dark, the built-in LED flashlight with 3 levels of brightness adjustment helps keep you going. No need to rummage through your bag when you need a torch, Blackview W60’s wrist-based torch is useful everywhere from SOS in twilight hikes to illumination in midnight bathroom runs.
Constant light Mode
Flash mode
Flashlight Button in
International Orange
Turn on/Turn off
Turn on/Turn off
Find lost items under the bed
Stay visible while running or biking in the dark
Light your way to the bathroom at midnight
Send out distress signals in poor signal areas
It’s Where The
True North
Compass
If you frequently find yourself losing direction, it might be worth considering a watch with compass-Blackview W60. No handheld compass is required! Go and explore the world- it’s what you do. Indicate the right direction for you — it’s what we do.
NO.2
HIGH-QUALITY, ULTRA-STABLE
BLUETOOTH CALLING TECH
Always Stay Connected
Silky-smooth Operation
on your Wrist
Actions ATS3085L
Blackview W60, powered by Actions Technology's ATS3085L , provides advanced features, extended battery life, and seamless connectivity while supporting dual-mode Bluetooth that separates calls from other data, resulting in smoother operation and lower power consumption.
Smoother Operation
Lower Power Consumption
Higher Frame Rate
More Stable &
Clearer Two-way
Calling
Actions ATS3085L
W60 supports dual-mode Bluetooth technology . The classic Bluetooth is mainly used to transmit audio signals while Bluetooth low energy is more suitable for small data transmission. At the same time, by transmitting audio signals and other data separately, the W60 avoids interference between different signals, ensuring more stable and higher-quality calls throughout.
Easier to Answer & Make Calls on your Wrist Even for Emergency Assistance
Higher-Quality Call Dialing & Answering
Do you find it difficult to receive phone calls when you are riding your motorcycle on a mountain road or driving on the highway? Connect W60 to your phone via Bluetooth, and with a simple tap, you can effortlessly answer or reject calls, ensuring contact in every urgent moment.
Make 8 Call Logs and 100 Contact Stored on Your Wrist!
*The Bluetooth Connectivity with up to 10 Meters.
Make an emergency call when
a car accident occurs
Answer calls from lovers
when busy cooking at home
Answer calls from important clients
while taking outdoor exercise
Answer/Make calls while riding
bicycles/motorcycles/driving cars
Keep Talking Without Phone
Built-in Large Speaker&Microphone
Stay connected on the go with hands-free calls directly from your wrist, thanks to the built-in microphone and speaker in W60! Compared to its predecessor, the W60 features an upgraded Triple Magnet Speaker, with three magnetic circuits for high, mid, and low frequencies. Not only does it excel in both high and low tones, but it also delivers a more balanced sound quality.
Voice Control at Your Command
Voice Assistant
Got your hands full? No sweat. Tap and say hi, then use your paired smartphone’s voice assistant via Blackview W60 to get weather updates, set timers, and play music as you like.
Move to the Rhythm of Music
Music Control
Easily control music playback on your phone through Bluetooth connection with W60. Sweat profusely at the gym while syncing with the rhythm of your music!
NO.3
THE LARGEST 2.01" SUPER-CLEAR DISPLAY
& LONGEST 900mAh BATTERY EVER
Our Largest Watch Screen
and Battery Yet
900mAh Battery
Standby>100 Days
Normal>30 Days
Up to 1000nits Brightness
Sharper Viewing Even in Sunlight
100% Charge in just 2.5hrs
Keep up with the Fast-paced Lifestyle
68% Screen-to-body Ratio
Wider 2.01"
Viewing Area
280*320
Super-clear Display
Full Touch
Display, No Dead
Corners
2.01" Large Touch Display
Don’t fall asleep on life- Blackview W60's expansive 2.01" TFT display guides you into a world of boundless clarity on your wrist. Navigate apps easier than ever with a 44.5% larger screen than its predecessor. Information such as notifications, fitness, and other important messages will be clearly displayed on this vivid screen with 280 x 320-pixel resolution.
W60
2.01"
Predecessor
1.39"
1.45× Larger Display
Sharper Viewing
Even in Sunlight
Backed by W60’s display that boasts up to 1000 nits brightness, whether in bright daylight or dark night environments, you can clearly and easily view the information displayed on its screen. Simply lift your wrist to check missed calls, message notifications, sports status, and more, just like on a mini smartphone.
Charge once and
use for 30 days
900mAh Massive Battery
How long can the smartwatch last on a single charge? 3 days? 5 days? Or even 7 days? Double the battery capacity of ordinary watches, Blackview W60 boasts a high battery capacity of 900mAh, providing up to 30 days of usage on a single charge.
paced Lifestyle
It only takes 2.5 hours to fully charge the Blackview W60, which ensures that you will spend less time tethered to a charging cable and more time enjoying the full suite of functionalities that W60 offers. Keep up with your busy schedule, track your fitness goals, or stay connected with important calls and messages.
NO.4
SMARTER, MORE
FUNCTIONAL, MORE
PERSONALIZED
More Convenient &
Easier Photo Taking
Shake to Control Camera Remotely
With the Gloryfit Pro APP, you can transform W60 into a remote shutter for your phone's camera, which provides unparalleled convenience for taking photos. Whether you are taking group photos or stunning selfies, there is no need to stretch your arm to touch the shutter on your phone. Just gently shake the W60 to easily capture the moment.
Timely Attention
to your Well-being
24-hour SpO2 Monitoring
Blackview W60 is capable of tracking and recording your blood oxygen levels throughout the day . For fitness enthusiasts, seniors, or those who snore at night, monitoring blood oxygen indicators can provide valuable information about the health of your respiratory system, allowing for timely attention to your well-being.
Arrhythmia,
W60 Reports
24-hour Heart
Rate Monitoring
With the advanced VC30F sensor, you can monitor your heart rate more accurately anytime, anywhere, and timely discover potential disease risks. At the same time, sports enthusiasts can also formulate the optimal training plan for themselves by observing their heart rate changes.
Biometrics
recognition
feature
Designed to prevent non-biological touches, thus reducing power consumption.
Control Breathing
Rhythm, Increase
Lung Capacity
Breathing Exercise
Simply activate the breathing exercise on W60, and the watch will guide you through scientific deep breathing, helping you better control the rhythm of breathing and relax your body. Especially for professional athletes, breathing exercise can also increase their lung capacity, preparing for the next high-intensity training.
Scientifically Improve
Your Sleep Quality
Deep Sleep Tracking
Blackview W60 professionally interprets the characteristics of your sleep stages by accurately monitoring deep sleep, light sleep, awake time, and other sleep phases, analyzing your sleep quality to help you develop a better sleep habit.
Burn Your Calories!
Pedometer
Always reluctant to exercise and sit all afternoon? A pedometer can record your daily walks and runs and calculate how many calories you burn. It continuously motivates you to carry out daily activities, fosters a healthy lifestyle, and helps you achieve your daily fitness goals.
Satisfy the Need
for Any Sport
100+ Workout Modes
Life can definitely be healthier with sports, but Blackview W60 makes your life much healthier by keeping track of your exercise. With 100+ workout modes like badminton, fitness walking and more, W60 informs you of your running or jumping metrics or more detailed exercise data each time you train for a better body.
Today's Outfit?
At-a-glance
Intuitive Weather Widget
Get seven-day forecasts right at your wrist with W60, allowing you to plan attire and activities with ease. Say goodbye to weather surprises and hello to better planning.
Women's
Health Matters
Women's Special Day Alert
Blackview W60 cares for women's health by offering special alerts in case you are too busy dealing with daily routines to remember it’s your special day and you need to take care of yourself with more attention.
Menstrual period
Safe Period
Ovulatory period
Check Crucial Messages Promptly
Message Notification
W60 ingeniously incorporates message notification features, ensuring you seamlessly capture communication signals from vital contacts anytime, anywhere. Respond promptly to cherished familial messages or pivotal clients, leaving no room for regrets.
More Convenient Alerts
Sedentary
Reminder
Customized Watch Menus
Different Styles of UI
Blackview W60 is paired with a highly personalized UI. Go choose from seven different styles of menus as you like.
Six customizable menu lists
Four card switching effects
Feel Free to Switch Your Personality
100+ Multifarious Watch Faces
Blackview W60 comes with 7 exquisite built-in watch faces, and after effortlessly connecting to the app, you can freely download up to 100+ watch faces in any style. Customize your watch to your heart's content and make it as cool as you desire.
Satisfy the Need
for Any Sport
100+ Workout Modes
W60 offers black, green, and khaki three different stylish color options for you. Besides, according to the color you choose, it comes with extra black or green woven straps, meeting your needs for unique fashionable matches in daily life or sports scenes.
Know Your Language
Blackview W60 offers you more ways to localize itself with 15-language support. Whether you are an Italian or a Portuguese speaker, W60 will adjust itself to keep up with you more effortlessly.
Support Languages including:
English, Chinese, Traditional Chinese, German, French, Italian, Spanish, Portuguese, Russian, Arabic, Turkish, Hebrew, Indonesian, Thai, Malay, Bulgarian
Other Helpful Tools
Little Helpers All along the Journey
Stopwatch
Time your training programs or outdoor exercise.
Timer
Set a timer before you start baking, training etc.
Wake up the Screen by Raising Your Hand
Raise your hand and you get a woken-up screen already.
Green watch+ Green strap
Khaki watch+ Khaki strap
Typical Use >30 days
Standby > 100 days
| Blackview W60 | |
| Dimension | 50*44.5*14.3mm |
| Weight | 61g |
| Color | Black watch + Black strap Green watch+ Green strap Khaki watch+ Khaki strap |
| CPU | Actions ATS3085L |
| Screen Size | 2.01-inch |
| Resolution | Resolution |
| Battery | 900mAh Typical Use >30 days Standby > 100 days |
| Bluetooth | Ver 5.3 |
| Language | English, Chinese, Traditional Chinese, German, French, Italian, Spanish, Portuguese, Russian, Arabic, Turkish, Hebrew, Indonesian, Thai, Malay, Bulgarian |
