Blackview TERRA 20 20000mAh Outdoor Rugged Power Bank
Out of stock
✔20000mAh High-Capacity Backup Power
✔5 Charging Output Ports
✔Built-in Dual Ultra-Bright Flashlights
✔ Rugged Outdoor Protection: Shock-Resistant, Water & Dust Protection
Charge Anywhere.
Power It All This isn’t just a power bank — it’s your backup when everything else stops. Blackview TERRA 20 powers up to 5 devices at once with a 20,000mAh battery and built-in cables — no extra gear needed. From outdoor adventures to outages , stay powered, visible, and in control.
Upgraded
Efficiency Upgraded
Power Upgraded
Emergency Readiness Upgraded
Built-in cables for every device
No extra cables needed
Need to carry extra cables
Limited compatibility
One-Press Activation
Max Brightness
Runtime
Beam Distance
Reinforced internal structure
Screw-secured top and bottom shells
shock absorption Built with silicone, rounded corner,
and robust inner build to handle everyday drops.
Sealed Port Cover Design
Silicone Sealing Material
Tight Structural Fit to Reduce Gaps
and protective design help keep out of rain, dust, and dirt.
20W PD Fast Charging
Power for Every Situation. 8-Layer Safety Protection
Protection Over-discharge
Protection Over-current
Protection Over-voltage
Protection
Protection Over-temperature
Protection Power Surge
Protection Electromagnetic
Protection
at a Glance Designed with 4-level LED battery indicator, TERRA 20 display the remaining battery level at a glance, so you won’t miss the charging time and stay powered at all time.
75%~100%
50%~75%
25%~50%
0%~25%
Output Ports (Charge Your Devices)
Input Ports (Recharge the Power Bank)
Device Details
TERRA 20 — Built for Power. Designed for Convenience.
From outdoor adventures to unexpected outages, stay powered, connected, and
prepared—wherever life takes you.
Blackview TERRA 20 Specifications
Capacity
Battery Type
Dimensions
Weight
USB-C Input
Micro USB Input
USB-A Input (with Built-in Cable)
USB-C Output
USB-C Output (with Built-in Cable)
USB-A Output
Lightning (with Built-in Cable) Output
Micro USB (with Built-in Cable) Output
Ports
Efficiency
Cycle Life
Charging Time
20000mAh / 74Wh (Rated)
Polymer Battery
173 × 87.8 × 33.4 mm
468g
5V⎓3A, 9V⎓2A
5V⎓2A, 9V⎓2A
5V⎓2A
5V⎓3A, 9V⎓2.22A, 12V⎓1.67A
5V⎓3A, 9V⎓2A, 10V⎓2.25A, 12V⎓1.5A
5V⎓2A
5V⎓2A
≥300 Cycles
≈10 Hours (5V/2A)
