Blackview SCM5 14-inch Portable Monitor Laptop Screen Extender with Speaker
Hurry up, only 7 items left in stock.
✔14" IPS 1080P FHD, Double Your Laptop Screen
✔TÜV SÜD Low Blue Light Certified
✔Built-in 1.5W BOX Speaker
✔Universal USB-C Ports, Fits 13”to 17.3" Laptops
Expand Your Workspace Crisp Visuals, Clear Audio,
Gentle on Eyes Simplify Your Setup,
Power Your Devices Adjust to Any View,
Stable for Any Task
Clear Audio, Gentle on Eyes
All-Round Clear View Premium FHD IPS panel delivers sharp, vivid visuals from any angle—elevating work, creativity, and entertainment on the go.
178°
Laptop
Desktop
Tablet
Smartphone
Game Console
Mac
Windows
Android
Linux
Chrome
PS4/5
Stable for Any Task
Adapt to All Needs Folds flat for easy storage and opens to your ideal viewing angle, adapting to any workspace or scenario.
Work · Create · Play · Learn. One Screen for All Scenarios. SCM5’s portable single screen turns your laptop, tablet, or smartphone into a dual-screen workstation, enabling seamless multitasking with zero clutter and maximum efficiency.
SCM5 Specification
ModelSCM5
ColorBlack
Size357.5×207.7×25.5mm
Weight995g
Display14" FHD IPS, 1920x1080 Resolution, 60Hz Refresh Rate, 300 nits Brightness, 157 PPI
Ports3× USB-C Ports (2× Full-Featured + 1× DP Alt Mode)
Included Cables1× Full-Featured USB-C to USB-C Cable (1m) + 1× USB-A to USB-C Cable (1m) + 1× HDMI to USB-C Cable (1m)
Speaker1.5W Single BOX Speaker
