Blackview R8 Women's Custom Stylish Smartwatch Blood Oxygen Monitor Ladies Girlfriend Fitness Android Smart Watch
Out of stock
Blackview R8
Get Fit, Go Ahead
Little
Alarm Clock -
1.09 '' Display 23g Only
24hrs SpO2 Detection
Sedentary Alert
Heart-rate Monitoring
4 Different Watch Faces
Call & Notification Alerts
Accurate Weather Forecast
1.09 -inch Display, But 23g Only
Reveal the Eternal Gracefulness
The zinc alloy case and Asahi Glass display are proven to be fall and crack-resistant after thousands of tests in the laboratory. The sophisticated pleat-like pattern on the circular case presents a timeless look at every sight. Curved edges of 2.5D glass feature the visual effect of water almost overflowing brim, making Blackview R8 truly brilliant down to the last detail.
8.8mm
23g
1.09”
Change the Look on
the Wrist Everyday
R8 with 4 sets of watch faces especially designed for women, turns your look on the wrist into a showcase for delicacy and exquisiteness. Match your everyday outfits with different watch faces.
Three Sets of UI
Customized Watch Menus
R8 is paired with a highly personalized UI. Go choose from a riveting cellular menu, circular plate-like interface or minimalist list-like UI. You can always find what suits your style.
Keep an Eye on Your Health
Around-the-clock SpO2 Detection
If you are having a headache or feeling dizzy, your SpO2 or blood oxygen saturation might be low. R8 equipped with VC32 sensor helps you instantly know your blood molecules deeper even in low temperature in 24 hours.
Make Every Heart Beat Count
How your heart beats every minute can reflect the health or your heart. R8 turns your every heartbeat into an easy-to-understand graphic so that you can be timely informed of if you have any cardiac problems.
Focus on Your Breathing Rhythm
Looking for a better way to alleviate your daily stress from city life or handle pressure from difficult tests in schools? R8 with a professional audio breathing guide makes you breathe more attentively to extricate yourself from unhealthy emotions.
25 Workout Modes
Redefine Your Exercise, Know Detailed Metrics
Exercising every day is beneficial to your health, but knowing how to maximize the benefit of exercise is more important. That’s why you need R8 to let you understand your precise workout data so as to improve the way you do sports or stop doing when you are getting enough of them.
- Outdoor Running
- Cycling
- Swimming
- Skipping
- Badminton
- Table Tennis
- Tennis
- Alpinism
- Walking
- Rugby
- Dancing
- Yoga
- Sit-ups
Never Miss out All the Way
Stay Notified
Don’t want to miss a call for a job interview invitation while you are doing shopping or the emergency calls from your kids or loved ones during work? R8 is equipped with call and notification alerts to enable you to stay connected with them whenever or wherever.
Time to Move and Stand up
A sitting-all-day lifestyle too often contributes to sore neck, stiff back or even fat hips. Change your harmful sedentary habit with R8 that offers smart alerts to remind you it’s time to stand up and relax your body.
Your Little Alarm Clock on the Wrist
R8 is built inside with an alarm clock alert. You can set an alarm for your important date with your meant-to-be or your long-expecting flight to a foreign city. R8 never lets you be absent from your significant moments in life.
Get You Prepared with Handy Tools
Find Your Phone or Watch
Connect your phone with R8 so it will never get lost and you can also find R8 with your phone.
Real-time Weather Forecast
With R8, simply raise your arm to check the real-time weather forecast in your city to decide whether to bring an umbrella or a raincoat right before you step out of your house.
IP68 Water-proof in Depth of 20 Meters
Work Even Deeper into Water
Water-proof in 20-meter-deep water, R8 allows you to be worry-free when you are sweating a lot during workout, or washing your hands after having fun on the beach. You can even wear an R8 to swim and check out the time in a pool.
190mAh Battery Capacity
Charge Less, Wear Often
Paired with a high-efficiency chipset and power-saving algorithm, R8 stays alive longer to make sure that each of your glimpse at it is a surprise. It lasts for 7-10 days for typical scenarios and can stand by for more than 45 days on a single charge.
7-10 Days
Typical Scenarios
45 Days
Stand By
Raise Your Arm to Wake up the Screen
Awakened by A Simple Lift
Every time you lift your arm, Blackview R8 women fitness stylish smartwatch wakes up automatically and intelligently to ensure longer battery life and smarter use. Awaken the watch by simply raising your arms when your hands are occupied.
Blackview R8
Dimension
φ41*12mm
Weight
23g
Color
Black watch + Black strap
Gold watch + Grey strap -
CPU
Realtek8762CK_VD
Screen Size
1.09 inches
Resolution
240*240 pixel
Battery
190mAh
Standby: >45 days
Typical Use: 7-10days -
Language
Chinese, English, Korean, Japanese, German, Russian,
French,Spanish, Italian, Portuguese, Polish and Czech
