Oscal TANK 1 6.78" 120Hz Main & 2.01" Secondary Display 20000mAh 170LM Flashlight & Night Vision Camera Rugged 5G AI Smartphone
Hurry up, only 8 items left in stock.
✔6.78" 120Hz Main & 2.01" Multi-functional Secondary Display
✔Built-in 170 Lumen Dual LED Flashlight
✔MediaTek Dimensity 7050 6nm 5G Octa-core
✔20000mAh Battery w/ 55W Fast Charging
✔64MP Main+20MP Night Vision Camera
✔IP68 &IP69K & MIL-STD-810H Certified
The Oscal TANK 1 is a heavy-duty rugged 5G phone built for long outdoor use, emergency readiness, and demanding work environments. Its 20,000mAh battery, 55W fast charging, 6.78-inch 120Hz 2.4K display, Dimensity 7050 processor, and dual display design make it powerful and versatile. A 64MP rear camera, 20MP night vision camera, 170LM flashlight, WiFi 6, dual 5G, IP68 & IP69K protection, and MIL-STD-810H durability make it a strong choice for field users and adventurers.
| Model | TANK 1 |
| Color | Black, Orange |
| Dimension | 184*83*29.5mm |
| Weight | 640g |
| OS | DokeOS 4.2 Based on Android 15 |
| Display | 6.78-inch 2.4K FHD+IPS, 1080 * 2460 Resolution, Corning® Gorilla® Glass 5, 120Hz Refresh Rate Secondary Screen: 2.01-inch, 240 * 296 Resolution |
| CPU | Octa-core 5G MediaTek Dimensity 7050, 6nm, Up to 2.4GHz |
| RAM & ROM | 12GB RAM & 256GB ROM, Up to 24GB RAM Expansion 16GB RAM & 512GB ROM, Up to 32GB RAM Expansion; |
| TF Expansion | Up to 2TB Expansion |
| Battery | 20,000mAh; 55W Fast Charging(Wired & Dock Charging) |
| Front Camera | 50MP (Samsung® ISOCELL JN1) |
| Rear Camera | 64MP Main+20MP Night Vision |
| Speaker | BOX Speaker with Smart-K |
| Navigation | GPS/GLONASS/BeiDou/Galileo/QZSS (L1+L5) |
| Card Slot | Dual: 2SIM/1SIM+1*TF Card |
| Glove Mode | Support |
| NFC | Support |
| Dual 5G | Support |
| Wi-Fi&Bluetooth | IEEE802.11a/b/g/n/ac/ax (2.4GHz/5GHz); BT 5.2 |
| Network Connectivity | 2G Band: B2/B3/B5/B8 3G Band: WCDMA: B1/B2/B4/B5/B6/B8/B19, CDMA: BC0/BC1/BC10 4G Band: TDD: B34/B38/B39/B40/B41 FDD: B1/2/3/4/5/7/8/12/13/17/18/19/20 /25/26/28/28A/28B/30/66 5G Band: N1/3/5/7/8/20/28/38/40/41/77/78 |
What protection does the OSCAL TANK 1 offer for outdoor use?
The OSCAL TANK 1 carries IP68 and IP69K ratings and meets the MIL-STD-810H military standard, making it well-suited for outdoor use. These ratings ensure effective resistance against dust, water immersion, and impacts that may occur during outdoor work or activities.
Before exposing the phone to dust or rain, please ensure that the SIM card slot cover and the charging port cover are securely closed. Also, check the device for any signs of damage before it comes into contact with water. Please note that water resistance may diminish over time due to daily wear and tear or accidental damage; Therefore, the device is not necessarily suitable for all types of underwater activities.
How can I charge the OSCAL TANK 1 when a wall outlet is unavailable?
If a wall outlet is unavailable, you can charge the OSCAL TANK 1 using a compatible power bank, a car USB charger, or a portable power station, provided you have the appropriate cables. These options are useful for keeping the device powered while traveling, camping, or engaging in other outdoor activities.
Charging speed depends on the power source and the specifications of the cable; for instance, a standard USB port may have a lower power output than the phone’s original charger, resulting in slower charging. It is advisable to plan ahead for your trip by ensuring you have sufficient backup power—such as a power bank—to maintain a reliable energy supply.
Is the OSCAL TANK 1 comfortable to carry every day?
The OSCAL TANK 1 weighs 640 grams, measures 29.5 mm in thickness, features a built-in 20,000mAh high-capacity battery, and boasts a rugged, durable design. It is a suitable addition to the everyday carry (EDC) kit for users who frequently haul outdoor gear or work equipment.
Using a waist pack or an easily accessible backpack compartment is an ideal way to carry it, ensuring both secure storage and quick retrieval. If you intend to carry it in a pocket, please verify beforehand that the pocket is large enough. For in-vehicle use, it is recommended to select a car mount capable of firmly supporting the device’s size and weight.
Can I uninstall or disable preinstalled apps on the OSCAL TANK 1?
Yes, you can uninstall or disable some pre-installed apps, though not all system apps can be removed. You can check for "Uninstall" or "Disable" options by opening the app's information page within "Settings."
If an app cannot be removed, consider adjusting its notification or app permissions instead. Please exercise caution: do not disable system components you are unfamiliar with just to free up space, as this could interfere with other device functions.
What should I do if my OSCAL TANK 1 stops working after getting wet?
Stop using the phone immediately, power it off, and—most importantly—do not attempt to charge it. Wipe the exterior of the phone dry with a cloth or paper towel, then place it on a table to air dry. Do not repeatedly try to restart the phone or insert any objects into the charging port.
If the phone remains unresponsive or continues to malfunction after these steps, please contact a professional technician for assistance. Be sure to inform them of the cause of the issue so they can accurately assess the problem.
How can I get official software support for the OSCAL TANK 1?
Open "Settings," locate the "System Update" option, and check if any updates are available for your OSCAL TANK 1. If an update is prompted, follow the on-screen instructions to download and install it. You can also use the search function within "Settings" to look for "System Update."
Before updating, please back up important files, connect to a stable Wi-Fi network, and ensure your device has sufficient battery power. Do not force the phone to shut down during the installation process; wait until the installation is complete. If no update prompt appears, it means there are currently no updates available for your rugged phone.
What can I do with the OSCAL TANK 1’s rear display?
The rear display allows you to check the time, view notifications and weather, control music playback, and answer or reject incoming calls. It also features a compass and serves as a viewfinder when taking selfies with the rear camera.
It provides a quick-glance interface when the back of the phone is facing you—for instance, you can pause music or check caller information without needing to flip the phone over. However, for tasks like reading, typing, browsing the web, or using full-scale applications, the main screen is a better choice, as it offers more space for interaction.
How does the OSCAL TANK 1’s speaker perform for calls and music?
The speaker on the OSCAL TANK 1 is suitable for hands-free calls, voice navigation, and casual music listening. While it provides sufficient volume, a high volume level does not necessarily equate to deep bass or nuanced audio quality. Sound quality can also be influenced by the source material, the volume setting, and the surrounding environment.
For calls, hold the phone close to your ear and use it in a relatively quiet environment. When playing music, we recommend adjusting the volume gradually to a level that suits your preference. For higher sound-quality standards, we recommend using headphones or an external Bluetooth speaker for a better listening experience.
Is the OSCAL TANK 1’s main camera suitable for everyday photos?
Yes. The 6400MP main camera on the OSCAL TANK 1 is well-suited for daily use, allowing you to easily capture landscapes, objects, documents, or memorable moments from your family life.
Before taking a photo, clean the lens; tap on your subject to focus, and keep the phone steady. When photographing documents or product labels, move closer and ensure the text appears sharp before pressing the shutter. When shooting photos of people or pets indoors, increasing the ambient light and taking multiple shots will improve your chances of getting a clear, high-quality image.
What can I see with the OSCAL TANK 1’s night vision camera?
The night-vision camera lets you see people, animals, and objects in dark environments. It is useful for viewing poorly lit areas or for making observations at a campsite when the main camera cannot capture sufficient detail.
When using the night-vision camera, keep the phone steady and point it toward the area you wish to view. Distance, obstacles, and reflective surfaces may affect image quality. Additionally, the camera cannot measure temperature or "see through" walls.
Is the OSCAL TANK 1’s charging dock sold separately?
Yes, you must purchase the charging dock for the OSCAL TANK 1 separately. It supports a 55W charging dock, which allows you to charge the phone simply by placing it onto the dock.
Please ensure that you select a charging dock compatible with the TANK 1 and verify whether an adapter and cables are included in the package. Additionally, keep the charging contacts clean and dry, and ensure the phone is positioned correctly on the dock.
Does the OSCAL TANK 1 need wired headphones to use FM radio?
Yes. The built-in FM radio requires wired headphones, which act as an antenna to receive broadcast signals. Please note that Bluetooth headphones cannot function as an antenna.
Simply connect wired headphones and open the FM radio app to search for local stations. Ensure you use compatible wired headphones (or a compatible adapter, if necessary). Please be aware that signal reception may be affected by factors such as your geographical location or the presence of buildings.
Who is the OSCAL TANK 1 rugged phone designed for?
The OSCAL TANK 1 is ideal for field technicians, construction workers, farmers, camping enthusiasts, and anyone who spends long periods away from power sources. It is also a great choice for users who prioritize battery capacity and robust, durable protection.
This rugged phone combines communication, photography, night vision, and illumination features, making it well-suited for a variety of professional and outdoor activities—from coordinating work tasks over the phone to capturing photos while camping.
What can I use the OSCAL TANK 1’s built-in flashlight for?
The built-in flashlight on the OSCAL TANK 1 can be used for locating gear, inspecting dark corners, setting up camp, or providing temporary illumination. When a dedicated flashlight is unavailable, the phone’s built-in light serves as a convenient alternative to help you get the job done.
To use it, simply direct the beam toward the area you wish to examine; if shadows interfere with close-range tasks, adjust the angle to minimize them. Once you have finished your task, remember to turn off the flashlight to conserve battery power.
